Question about Bahama Sounds PTL100-G Main / Stereo Speaker
Rock Speakers 2 Speakers do not work. We have 4 total and 2 are not working.
  • 682 Answers
Check speaker cable for open circuit cable-repeat your setup again and confirm all speaker are in on status-last thing defective speaker itself.(sure you replace it)
Posted on Jul 08, 2008
Can I use 1/2 x 4' x 4' sheet rock for the kitchen ceiling?
Slit the edges of the 5/8 sheetrock to separate them. Put up one first then the second one over the first
Nov 09, 2017 | The Office Equipment & Supplies
I have two JBL MRX 515 speakers at 8 ohnms and two behringer bins at 300 watts 4 ohms running off a behringer EP4000 amp, would this be ok ? and not casue any damage to the speakers
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Behringer-EP4000-Amps-manual/id/23591dj795/t/2/
http://www.raltron.com/cust/tools/parallel_resistance.asp
It's ohm's law, dude. 1/a + 1/b = 1/total. One each 8- and 4-ohm speaker in parallel per channel would be 2.7 ohms (nominal). So it will work in theory.
How you manage the potential difference in volume between dissimilar speakers on the same amp channel is a mystery.
Distortion will kill any speaker, not power. Stay within the amp's usable range.
Jun 23, 2011 | JBL MRX515 15" 2-Way Loudspeaker Main /...
Hook up lanzar 4 channel amp, directions say to use single rca cables with y connectors. my stereo has L/R rca outputs for front, rear & sub total of 3 sets =ing 6. amp has total of 4 one rca...
Well personally i would probably use two channels to run all the highs and bridge the other two channels into one mono to run the sub ..
Jun 02, 2011 | Car Audio & Video
How to run wires is series fof 3 subs
If they are single voice coil speakers (1 positive and 1 negative terminal on each speaker) then connect from amps' Positive output terminal to spkr. 1 positive terminal, THEN spkr. 1 neg. terminal to spkr. 2 positive terminal, THEN spkr. 2 negative terminal to spkr. 3 positive terminal, THEN spkr. 3 negative terminal to amps' negative output terminal.
That is 3 speakers wired in series. if each spkr is 2ohms, then you will have a total 6 ohm load. If 4 ohm spkrs., then a total 12 ohm load, if 8 ohm spkr., then a total 24 ohm load.
Be careful because amps do not like these odd ohm load totals. You might get away with a 6 ohm total load. Depends on the amp.
Mar 27, 2010 | Jl Audio 10W6v2 Car Subwoofer
Big problem with rock band 2 drumset * PLEASE READ *
if brokn dont buy it find u another 1 of ask 4 refound its that simple i had the same problem 2 but with my gutar set
Mar 05, 2010 | MTV Games Rock Band for PlayStation 2
XR 8600 what color wire on the output connects
Peavey XR 8600?? Well it's 600w per ch. at 4 ohms/per side. So, whichever mode you use (Main, or Main/Monitor) you are best to have a 4 ohm total load for each channel of amplification. Ex.--Mains only, one 4ohm speaker per channel will give you 600W per side. Or two 8ohm speakers per channel in parallel, which makes a 4 ohm total load.
Main/Monitor mode---treat it the same way. one 4ohm, or two 8 ohms parallel. per channel.
Your best situation is to have a 4 ohm total load for each channel of amplification to get your 600W.
Parallel-- 8ohms each / 2 speakers = 4 ohm
Feb 20, 2010 | Music
Which are the differents diagrams to wire two sub dvc 4 ohms
I guess this Amp is stable down to 2 ohms. 500 Watts X 1. Unfortunately there is no way possible for you to present a 2 ohm load to the output of this amplifier. Here are your options.
Speakers in series with VC in parallel = 4 ohm total Z
Speakers in parallel with VC in parallel = 1 ohm total Z (not good)
Speakers in parallel with VC in series = 4 ohm total Z ( Whats the point)
Speakers in series with VC in series = 16 ohm total Z ( Whats the Point)
So your best option to maximize power transfer from your amp to your speakers would be option 1. (Z = Impedance)
Dec 13, 2009 | Kenwood KAC-8104D Car Audio Amplifier
My realtek driver is not showing 4 channel speakers as i hav creative 4.1 speakers. i have bought a crative 4.1 speakers aspire model . out of the 4 only 2 works while the other 2 don't. i already check...
i have bought a crative 4.1 speakers aspire model . out of the 4 only 2 works while the other 2 don't. i already check that the all speakers are in correct working condition.
the problem is that my realtek driver is not giving me 4 channel speakers optiion. only 2 channel option is present . what should i do now?
Mar 29, 2009 | Creative Labs Computers & Internet
Speakers not working
are their speakers in the rear as well. does your car have a total of 6 speakers? if so, the new deck can only run 4 of them, thats why the middle speakers dont work.
Feb 26, 2009 | Kenwood 1090VR Receiver
How do I work out the standard deviation, every time I try to work it out it keeps saying error 2.
The following table shows the total prize money recieved in 2007 to date for each of 31 seeded male players at this year's wimbledon. The amounts shown are to the nearest u$100,000
27 33 7 16 9 8 7 3 4 6
4 6 7 7 4 5 3 4 4 2
7 3 6 5 2 3 4 3 3 2
Question?
Calculate the five figure summary of the total prize money recieved?
Sep 18, 2007 | Sharp EL-500LB Calculator
Bahama Sounds PTL100-G Main / Stereo Speaker Logo
98 people viewed this question
Top Bahama Sounds Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Bahama Sounds Audio Player and Recorder Expert? Answer questions, earn points and help others
