Question about Sony Ericsson W300 Cellular Phone
Bluetooth willnot activate
I follow directions in menu, but in the end isnt act8ivated
    Brigadier General:
  • 7,752 Answers
MENU/SETTINGS/CONNECTIVITY/BLUETOOTH/TURN ON/OFF
Posted on Sep 20, 2008
How to active Bluetooth on laptop
Hello, If you laptop is a newer one there should be and icon for bluetooth. If not then go to control panel and look for bluetooth. If you don't have a bluetooth problem then your laptop isnt supported bluetooth.
Jun 11, 2014 | Acer Aspire One PC Notebook
How to listen music via bluetooth headset in samsung GT S3370
Follow the following steps:
  1. Turn ON your Bluetooth Headset device. (A light may lit upon turning it on)
  2. Turn On your mobile phone's Bluetooth.
  3. On your Bluetooth menu of your phone, select "Search for devices"
  4. When finish searching, your Bluetooth headset must be on the list. Else, repeat searching until your phone can find it.
  5. If you can find it, tap Connect.
  6. Now, test your connectivity by playing some music.
Jun 20, 2011 | Cell Phones
I can't activate the bluetooth on a samsunh sgh j700
You can activate the bluetooth for this phone by following the instructions below as they come to you. If you are not clear on any part, please contact me.
1. Go to the main menu of your phone.
2. Scroll through to the application menu,
3. Open it and select bluetooth. From here, you can activate the bluetooth feature on your phone.
You have to follow the above instruction if you want to receive an item from another phone via bluetooth. Sometimes, you might be asked to pair your phone using a code, this is normal depending on the phones involved.
Also, if you want to send an item from you phone to another phone, all you need to do is to select the item and press the options button and select "send via" and the choose bluetooth from the menu.
Hope this was helpful? Please remember to check back with me if you are not sure of anything and I would explain better, Thank you for using FixYa.
May 19, 2011 | Cell Phones
How do i set the blue tooth settings on my nokia c3
From your phone's menu, select 'settings'.
Go to 'connectivity', select 'bluetooth'. Under the bluetooth menu, you would see the following sub menu
1. Blue tooth
can be set to either 'on' or 'off'.
2.conn. to audio access - you select this if yuo want to connect your phone to a bluetooth earpiece.
3. Paired device
under this, you would see 'add
new device'. You select it if there
is a new device you want to add.
4. Active devices - it shows any device that is active.
5. Phone visibility.
Select 'always visible' if you want
your device to always be visible
to any active device.
Select 'temporarily visible' if you
want to be temporarily visible.
Select 'hidden' if you want to be
hidden. To other devices.
6. My phones' name. Select this to change your phones' name from the default to any name of your choice.
Hope this was helpful? Please do indicate. Success.
Apr 11, 2011 | Nokia C3 Cell Phone
Bluetooth is not working
If you are having problems connecting to someone else's device with your Bluetooth, make sure both devices are activated and are compatible. Also make sure the distance between the two devices is not over 32 feet. There must be no walls or barriers between the devices. You may also need to make sure that the other device is not in hidden mode. If you experience problems ending a Bluetooth connection and another device is joined to your Bluetooth device, you can use that device to end the connection; or you can disable the connection by pressing the Menu button, selecting "Connect," choosing "Bluetooth" and pressing "Off."
Feb 21, 2011 | Nokia N73 Cellular Phone
Can't turn bluetooth on. If I restart the phone and then turn on bluetooth, I get a message "Switching On Bluetooth" but it doesn't turn on. After that, nothing happens when I select "on", not even the...
Set up a Bluetooth connection
Select Menu > Settings > Connectivity > Bluetooth and take the following steps:
1. Select My phone's name and enter a name for your phone.
2. To activate Bluetooth connectivity select Bluetooth > On. indicates that
Bluetooth is active.
thanks
May 16, 2010 | Nokia 6301 Cellular Phone
How to send photo from mobile to our computer
there are 3 ways
1.
You can use the USB data cable to transfer data between
the device and a compatible PC or a printer supporting
PictBridge. You can also use the USB data cable with
Nokia PC Suite.
To activate the device for data transfer or image
printing, connect the data cable. Confirm "USB data
cable connected. Select mode.
" and select from the
following options:
Nokia mode — to use the device for PC Suite
Printing & media — to use the device with a
PictBridge compatible printer or with your
compatible PC
Data storage — to connect to a PC that does not
have Nokia software and use the device as a data
storage device
To change the USB mode, select Menu > Settings >
Connectivity > USB data cable and the desired USB
mode.
2.
Bluetooth and from the following options:
Bluetooth — Select On to activate the Bluetooth
function. indicates that Bluetooth is activated.
My phone's visibility — to define how your device
is shown to other Bluetooth devices
Search for audio enhancements — to search for
compatible Bluetooth audio devices. Select the
device that you want to connect to the phone.
Active devices — to check which Bluetooth
connection is currently active
Paired devices — to search for any Bluetooth device
in range. Select New to list any Bluetooth device in
range. Select a device and Pair. Enter an agreed
Bluetooth passcode of the device (up to 16
characters) to pair the device to your device. You
must only give this passcode when you connect to
the device for the first time. Your device connects to
the other device, and you can start data transfer.
My phone's name — to set the device name for
Bluetooth connections
3. Take off you microSC memory card then read directly to your computer
cheers!
Jul 11, 2009 | Nokia 3110 Cellular Phone
Blue tooth is not installing for the ps3
Registering
1) Go to accessory settings
2) Click on Register blue-tooth device
3) Click on Headset
4) Scan, while holding down the main power button on the headset
5) Enter your 4-digit password. The default is normally 0000
6) Done
Using
1) Go to Audio Options (under accessories)
2) Click "Connect Blue-Tooth device"
3) Change everything from "Do Not Use" to your headset name
4) Done..
Mar 31, 2009 | Mad Catz PS3 Bluetooth® Headset Wireless...
Setting bluetooth on a Epson stylus SX600FW
the bluetooth dongle for your printer is sold separately. call epson store to get one.
Jan 28, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Bluetooth
I know that it is not very helpfull to say this,but you are not alone with this fault which appears to be quite common to the D500.I assume that the same notice appears when you attempt to activate IR as this is usually the case. The only suggestion that has been doing the rounds is as follows. Remove the back and look at the chassis and you will see a square IC unit near the battery connectors. Apply heavy but carefull pressure on this and try the Bluetooth again. This is said to have cleared the fault in at least two cases.
Dennis
Dec 04, 2007 | Samsung SGH-D500 Cellular Phone
Sony Ericsson W300 Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
