Question about Canon Rebel XT / EOS 350D Digital Camera
CF Light My camera was working fine, I turned it on this morning and snapped one picture, I noticed it did not show on the screen. The CF light is on and the number 252 is flashing in the little window. PLEASE tell me I just need a new card. I have used the same one for two years now and in about 30 countries, so my cam has been bounced around a bit. Thanks you so much. Q
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 216 Answers
If you have pics on the card, see if you can download them to computer, then go into the Menu and format the card. If the card is okay, that should correct the problem. If it's defective, it will tell you the card cannot be used.
Posted on Jul 06, 2008
Canon rebel xt eos shows ERR CF. What do I do now?I tried a new flash card but still got the same error message. When I try to preview pictures I have already taken the screen says ¨no image¨. My...
Check that the pins in the camera that connect to the CF card are clean and not bent. You will probably need a good light and a magnifying glass to see into the card slot. If you can see a pin that is bent you could try straigtening it. BEWARE- turn off camera and use a non conducting "stick" ie cocktail or toothpick. Not sure for a Canon but a colleague paid £40 for a new pin assembly for a Nikon with similar problem.
Hope this helps.
Steve A.
May 06, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT wont fully come on
Hi
Error 99 is usually a lense error and gives the only real clue as to what is going on with your camera. You can try this simple fix which comes straight from Canon. Follow the steps to help isolate the issue. Note the fact that you are currently not getting the Error 99 is probably a good sign according to the troubleshoot.
To isolate the cause of the issue, we suggest that you do the following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the
Hope this helps. Please do rate my answer. Thanks.
Aug 09, 2009 | Canon Rebel XT / EOS 350D Digital Camera
CF light stays on, cards come out unreadable by computer
You may need to have your camera driver and software reinstalled. It seems that the internal writer capabilities are corrupted.
This is evident if each card you use ends up corrupted or unreadable, but the rest of the camera operates normal.
May 06, 2009 | Nikon D200 Digital Camera with 18-200mm...
LCD screen is very dark, Pictures taken are underexposed
If the pictures show up normal on the computer then the back light for the LCD is going bad.
Apr 05, 2009 | Canon PowerShot A640 Digital Camera
My canon rebel xti is broken?
This will happen if you have the camera set to manual and the aperture/shutter speed combination does not let in enough light. There's a wheel on the top of the camera with M, A, S, P, Auto settings - turn the wheel to select P or Auto and try again.
Also, if you're indoors, you may have to use the flash.
Mar 01, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Battery level
As Suzaku explained:
A battery icon will show up on the LCD screen of your camera when it is already low and needs recharging. It can be found at the lower right side of your LCD screen. The ready light of your camera will also blink red and your camera will turn off if the battery is exhausted.
NOTE:
The icon will not appear if the batery is sufficient and there is no TECH way of making the icon show until the batt needs charging.
Jan 04, 2009 | Kodak EASYSHARE M763 Digital Camera
Pictures are black
My 4300 works fine until this week. No picture display on the LCD screen. Settings like date, exposure, etc.. are fine on the LCD screen. Able to get into setup mode and the colour menu selection box is fine. This shows that the LCD screen is working fine. Prior to this happening, I notice that when I took pictures in zoom mode, the picture turn out to be orange. I suspect this is caused by electronic failure. Light entering the lens cannot be transmitted to the LCD screen. Some photoelectronic stuff had reached its MTBF (mean time between failure)? Is there a way to save this camera?
Mar 17, 2008 | Nikon Coolpix 4300 Digital Camera
CF Card Error
Check your memory card to see if its locked!
Jan 03, 2008 | Vivitar ViviCam 3915 Digital Camera
Incompatible JPEG format
you are most probably looking at the pictures from the camera screen.... if you use a CF card reader and view them on the PC through internet explorer or any other software they will be fine..
You get this error when the files have been changed on the CF card by anything aside from the camera
Nov 28, 2007 | Canon Rebel XT / EOS 350D Digital Camera
White Screen
I have Fuji FinePix 2650 Digital camera with same problem. I can almost guarantee this is not a firmware problem. I went mountain biking a few months ago and take pictures. I take out camera and turn on. I get lines then white screen. I banged on camera and fixed it. Later a few weeks ago I turn it on and white screen. i beat this thing and get bad menu selection screen for a moment then white again. It takes pictures well and talk to computer no problem but no LCD picture. I thinking it is loose connection for LCD. Send it for repair or if you seek adventure try to fix it yourself!
Nov 12, 2006 | Fuji FinePix S5000 Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
61 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
