Question about Gaggia Classic Brushed Stainless Steel Espresso Machine
Gaggia cffee machine will not pump water through th coffee
My gaggia coffee machine, will not pump water trough the coffee. I see the water going back in the reservoir. I used the cleaner cafiza, but no help. Please help.
Thank you
Posted on Oct 01, 2008
  • porsiaf Oct 01, 2008
    filters are clean, I also changed the pump {?}
    Filter is clean, also changed the pump. (?)
  • 515 Answers
Check you filter and make sure it´s clean.
Posted on Jul 13, 2008
Gagging espresso maker does not pump water
Hi There,
It's either the pump or the solenoid.
When you turn of the coffee switch after there should be a discharge into the water tank - if this happens - the solenoid is blocked but the pump is not.
It is an easy fix.
( This happens when the machine has not been descaled and the solenoid is blocked.)Usually its not the pump.!
Vibration pump Gaggia Saeco Gaggia classic solenoid
Oct 17, 2017 | Gaggia Baby Coffee Makers & Espresso...
Low flow, pump starts normal and within a few second becomes quiete
Hi There,
Try descaling - sounds like the the solenoid is blocked with lime - don't use vinegar! Try that 1st.
If machine is more that 2 years - not regularly descaled or no water filter replaced regularly, it probably the solenoid.
It the machines is 4 years + replacing both would be a good idea. Gaggia classic solenoid Vibration pump Gaggia Rancillio
Jul 06, 2017 | Gaggia Baby Coffee Makers & Espresso...
Doesnt make coffe . i can hear it running but nothing happens no cffee comes ut. aso leas water smetimes.
Your water pump or volumetric counter can be clogged. Or the 3 way valve on the back of the unit is stock on the closed position or bad.
Jan 19, 2011 | Lavazza Espresso Point Capsule Machine
Hi, My Gaggia Classic is not working. No water
try to clean the group shower which it can be ansrew by one cetrer screw and if you can you can open the machine and remove to clean also the coffee group solenoid valve. Bothe the valve and shower can be full of dry coffee that can blocked the way of water coming to the grounded coffee.
If you manage to clean everything above and the machine work ok so from now on in order to avoid the problem again try to flush water from the group many times without any coffee. With this is like you wash the group shower and valve from any remai coffee.
Good luck
Jun 29, 2010 | Gaggia Classic Espresso Machine
Brand new Gaggia Syncrony Compact will not pump water. Red light no. 27 flashes, and machine makes sounds as if trying to pump.
Open the hot water valve, if it flows for a second and stops, then pusi in on the knob if that works, call up support and ask for a new stainless steel valve for your machine.
Aug 01, 2009 | Gaggia Syncrony Compact Coffee...
My Gaggia Baby C coffee maker has stopped pumping water
From what you have asked the only thing I can suggest is that the pump needs to be replaced. Do you hear the pump vibrating? The lines from the pump may be blocked. Have you tried to descale the machine.
Jun 06, 2009 | Gaggia Baby Espresso Machine
Pump problem on a Gaggia Espresso Evolution
You need a bellows pump or similar, when you start the pump you need to set the pump to the water inlet and press in the water with force.
Jul 09, 2008 | Gaggia Evolution Espresso Machine
Gaggia Espresso Machine bought about 10 years ago
  1. if it is fine ground coffee sometimes you get this result at machines.
  2. low pressure pump = you get water from it but only when handle is out or steam valve open.
  3. pump with non return valve broken = in this case you get water if you open tea valve during pump works. this pump can work long even she has 1 valve damaged, only when she is empty you need to open steam valve and leave pump running while you don't get water from valve.
Feb 15, 2008 | Gaggia Espresso De Luxe Espresso Machine
Machine Does not draw water into the boiler
I have had this same problem - it is due to an airlock in the boiler/tubes. Simple solution is to use a syringe or similar and gently force some water up the intake hose from the tank, then try the pump again.
May 21, 2007 | Gaggia Evolution Espresso Machine
Gaggia Classic Brushed Stainless Steel Espresso Machine Logo
784 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Michael Vincent Cruz
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
