You can't use component input on the tv. You have to have component output on the wii and it doesn't have it. Are you sure you don't have A/V inputs on your set? I don't know of any set that doesn't in the LCD field, even the cheap imports have them. I tried to cross your model number and it went nowhere. Could you re-check your model number and send it to me. Some models of Insignia had a hidden compartment on the sides by the antenna jack that pops out.
The tv doesn't have a/v inputs, just component. I went to gamestop and bought the component cable that you can use with the Wii. I eventually figured out my problem...for which I feel like a total idiot...there is a little black switch on the gamestop cable that is easy to overlook but that allows you to switch from "tv" (which it was on) to "HDTV" (which I switched it to) and it works like a charm.
Thank you for your help. I hope this will help others who run into the same problem I had.
