Question about Philips 20DV6942 20 in. TV/DVD Combo
Green Spot in picture
Hello Experts,
My Phillips TV has two areas (uppper Right and lower left) where the color is always Green. Can you help?
Jim in Alaska
    Problem Solver:
  • 6 Answers
Did you try unplugging TV from outlet for an hour, sounds like degaussing trouble, was there a speaker or magnet placed close to the TV?
Posted on Jul 26, 2008
Hello my Phillips 42" model
HI:
Check your componet connections to the TV, Componet cables use green,red, blue and red and white for audio, check the green cable go see if it came loose, because if it is the picture will be B
&W.
May 23, 2011 | Philips 42PF9630A 42 in. Plasma Television
Screen appears blue
Try Moving The Speaker You Have There Away From It?
www.Myspace.com/CrossRoadsToNowhere2007
Jan 05, 2009 | Sony KDF-E55A20 55 in. LCD Television
Yellow spot in lower right hand corner
You have pretty much narrowed it down to being a bad optical block. This isn;t good news, since the optical block is probably the most expensive part in the set. Your best bet is to contact Sony customer support to see if the will allow some kind of accommodation for the repairs. Sorry for the bad new; hope it doesn't effect the rating you give me for the solution. Thanks!
Nov 11, 2008 | Sony Grand WEGA KF-42SX300 42" LCD TV
Green Spot
set your tv to original default factory settings.
then apply also good resolution.
your problem is most of solved
Mar 24, 2008 | Panasonic PT-44LCX65 Television
Color separation
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Mar 03, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Picture color - it is a blue and green picture- no other color- looks artificial
update your tv with a usb drive. worked on my phillips 60PP9200D/37. get update at phillips web site. solves many problems
Jan 18, 2008 | Philips 60PP9200D Television
Discolored edges on my 36"wega sony t.v.
This is not the right model number for this TV set.
Jul 24, 2007 | Sony Part 996804671 Service Manual for...
Color issues in the lower right corner
Unplug the set overnight and plug back in and turn the set on . If the spot goes away alittle then do this again. Up to three days > if that dosent fix the problem then you have a problem in the deguissing coil curcuit. Probably a cod joint on the thermister or a bad relay , a bad coil . Not a big deal repair. Good luck
Apr 24, 2006 | Sony KV-27S42 27" TV
Philips 20DV6942 20 in. TV/DVD Combo Logo
80 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
