HT-DDW660 sony when i play regular digital tv, my speakers make a popping, cracking noise. This does not happen when I watch dvds. I have high def digital cable with comcast.
    Genius:
  • 1,175 Answers
Can you try another type of output from the Comcast box?
It could be their box.
Posted on Jul 07, 2008
Samsung blu ray will only regular dvds
Are the discs commercial or made on another computer?
Jan 19, 2014 | Samsung Ht-bd8200 Home Theater System - Bd...
Cracking and poping with Yamaha surround sound system
Try put a ground line from any metal of your stuff to the any metal direct to the ground. these eliminate noise of the speaker.
Jan 03, 2008 | Pioneer VSX-54TX Receiver
How can I get my Denon 2106 to play through my television? I'm not sure what's happened. I feel like I have the cables hooked up properly. It's worked for years. My stereo plays, so it's not the speakers....
Hello: If you are trying to get the sound from the TV to come through the receiver to your speakers and are hearing nothing, I had the same problem. For some reason, and I have the question posted, the sound level requirement is much higher for the TV. I turned my receiver up to +2 decibels and the sound was there. However, if you play high def channels through the receiver, the +2 will blow your ears off. My new problem is why does the regular TV need so much volume on the dial while the high def channels only require the lower sound level. It prevents you from switching from regular to high definition channels. So, in summary, the sound is there, just turn the volume way up.
Oct 30, 2010 | Denon AVR-2106 Receiver
Sound went out, all I get is white noise that you cannot mute. Happened when I changed from high def to regular channel. Even with everything unhooked still just white noise.
Analog regular channel TV was turned off mid 2009. You need a digital channel convertor box to receive the new digital channels... The analog ones went bye, bye in the USA. Without the box you will just get noise.
Jan 02, 2010 | Hitachi 50V720 Television
Connect powered subwoofer to system with no pre-out connector?
You will require a Line level converter... usually reserved for car audio applications - but it should work in yours as well.
It converts the speaker wires to RCAs.
45679e7.jpg There are ones made for home audio - but harder to find and a little pricier.
01259e7.jpg Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 31, 2009 | Sony HT-DDW660 Home Theater System System
Will play dvds with sound fine...but no sound from tv
You have to connect extra red & white audio cable from your TV's (or cable box, if you have one) AUDIO OUT to the Home Theater's AUX IN 2 at the back (below Video In). Set the HTS unit to AUX 2 using the AUX button on the remote control and you should be able to get sound.
Jun 14, 2009 | Samsung HT-P38 System
Popping & cracking noises
Is the popping noise coming from the speakers? If it is, lowering the volume to zero does not stop the popping from the speakers, then you have an audio output failure. If the sound is not from the speakers, you probably have a high voltage leak. If this is the case, are you in a moist environment or using the set near a window??
Mar 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No surround sound when watching TV
hdmi can only pass pcm 2.0 digital for the separate cables you may try to switch them to another output from the monitor to the receiver or if you can get your hands on a spd-if cable (one single fiberoptic cable that will go as high as 5.1 dolby surround)
Dec 27, 2007 | Televison & Video
Das TV make cracking and poping noise when you unhook it from receiver?
Sep 30, 2007 | Sony STR-DE197 Receiver
Crackling from surrond sound
I have a SONY home theater4.gif system, HT-C800DP, there is a crackling sound when playing DVDs - it is almost as if the unit overheats. Is there any solution to this? Sometimes I cannot even finish a DVD as the noise gets very loud.
Thanks,
Cindy
Aug 14, 2006 | Sony HTD-C800DP System
151 people viewed this question
 Grubhead
Grubhead
