Question about Rowenta DG-980 Iron
Water leaks from the bottom of the iron. Rowenta expert GV2380M steam iron
  • Roland Wong
    Roland Wong May 11, 2010
    Does the water leak from the underside of the boiler tank housing?...there are some drain/vent holes to prevent it from filling up with water. Or is the actual iron leaking from the soleplate or hose assy? You will need security torx screw driver/bits to do minimal disassembly to inspect and locate source of the problem. The security torx tools may be obtained from Kragen Auto Supply or Harbor Freight Tools for decent quality and pricing for the DIY'ers out there.
  • Anonymous Mar 18, 2014
    My iron is leaking steam from under neat cap
Yes it is from the bottom of the boiler from a small opening, I guess a vent. Thank you for the help.
Posted on Jul 11, 2008
Rowenta superpress DG 050 leaks water while steaming all over garment. Do I need to Descale the unit?
I've had the same problem with two Rowenta irons. When set to a lower temperature, the iron has a bad habit of leaking water when the steam option is on. I have to either turn up the temperature setting or shut off the steam option.
Feb 28, 2015 | Rowenta Irons
We have Rowenta DM 890 steam iron. It dumps water. Also Why not use distilled water?
The following web blog about Rowenta steam irons has some tips on maintaining the iron:
http://www.nasa1.org/iron%20rowenta.htm
The following web blog explains the issue of not using distilled water:
http://ths.gardenweb.com/forums/load/laundry/msg011421358265.html
I guess the bottom line is that it takes a higher temperature for distilled water to boil. It also explains that will cause the unit to spit, drip, and leak.
Try affordable spring water, and you should get better results.
Jan 27, 2011 | Rowenta Irons
We have a Rowenta Model DW 8080 steam iron. Even when the steaming feature is turned off, there is a water leak in the gap between the bottom plate and the upper part of the iron.
I too have this problem. Ihave bought so my of these irons. I wish so meone else could make something that could put the steam out that this do, that would last for more than a year!!!
Nov 18, 2010 | Rowenta Irons
ROWENTA STAM IRON - NO STEAM !!!!
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
May 22, 2010 | Rowenta Commercial Garment Steamer - White
Rowenta model 1700W. Water leaks out front of iron
heatman101
Mar 23, 2009 | Rowenta DZ1700 Iron
At high temp settings water leaks out of steam holes in bottom
You want to run the self-clean mode. Fill with water, then over a sink, with the iron facing down, press the self-clean button. Steam will eject, along with sediment and water deposits. You may have to repeat numerous times. The iron requires soft water, if you don't have soft water at the tap then buy bottled water at the grocery store to prevent this problem.
You can also buy a cleaning solution that you mix into the water reservoir, or you can make your own by filling the iron half-full of water then add white vinegar to the fill line, then perform the self-clean mode or steam mode over a sink.
Here is a Rowenta suggestions:
The iron is leaking.
Water: Use tap water in the iron. If tap water is hard or high in organic matter, we recommend using bottled spring water or mix tap water with distilled. Do NOT use 100% distilled water. Many softening systems may cause issues as well.
Auto-Off: If iron is equipped with auto off, you need to move iron or gently shake it an allow it to heat back up before beginning to iron.
Overuse of Burst of Steam: Allow more time between each burst of steam.
The Rowenta site does not list a manual for your older model, but here is their link:
http://www.rowentausa.com/rowenta/frame.aspx
Mar 21, 2009 | Rowenta Powerglide DE013 Iron
Iron leaks water
heatman101
Mar 11, 2009 | Rowenta DZ9080 Iron with Auto Shut-off
Rowenta DG-980 Iron Logo
478 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
