Question about Microsoft Xbox 360 Controller
Xbox 360 won't recognize my controller!
I TRIED SYNCING IT MANY TIMES NEVER WORKED! I just got a replacement, same problem
  • 15 more comments
  • rvarga1 Aug 30, 2008
    I have a wireless controller well both of my controllers they sink up as far as turning on the xbox but they don't sync up as controler 1,2,3,4 it just keeps circling them.changed the batteries still nothing,another thing I just had the hard drive replaced and it worked before hard drive was replaced.
  • Anonymous Dec 15, 2008
    the controller wont conect
  • lari691 Dec 16, 2008
    wireless controller does not work
  • Anonymous Dec 26, 2008
    My controller is not syncing...
  • Anonymous Dec 27, 2008
    My remote controller won't work. Anyone know why?
  • Ntsmarkv Dec 29, 2008
    Just bought me this Xbox 360 same thing not syncing on brand new batteries, just circling...
  • metzfan Jan 05, 2009
    the xbox 360 console and the wireless controller just seems to blink when trying to sync. i have no clue how this came to be, it has been working fine but all of a sudden the controller and the headset doesnt seem to sync anymore does anybody no what happened?
  • Anonymous Jan 23, 2009
    new replacement controllers won't sync
  • Anonymous Jan 24, 2009
    My xbox 360 machine works but will not reconise the controllers please help!!!
  • Anonymous Jan 26, 2009
    i have also got the same problem please help
  • Anonymous Mar 13, 2009
    my controller wont work my xbox 360
  • Narine360 Mar 28, 2009
    I tried syncing them I press both the correct buttons and then they both start flashing together but the marker on the 360 is't there and the controller just flashes constintly!I tried well over 50 times to synce them!
    I got a new controller because old one was making my guy move without me touching anything and that was fine now there is this problem wit this one!WTF
    I even changed the batteries and same old same old plz help!!!
  • jakes2424 Mar 29, 2009
    My xbox will play games, and all that, but none of my controllers will connect to my xbox. I have 2 xbox 360's and my other one has the red ring of death. I NEED HELP WITH MY XBOX!!!!!!!!!!
  • Anonymous Apr 11, 2009
    The conroller wil not connect to the xbox 360
  • Anonymous May 15, 2009
    when i try to sync the controller with the 360, first i hit the sync botton on the 360 then i hit the sync on the contoller, then they flash opposite of each other and then nothing, im only having this problem with 1 controller, the others work fine........................just as i was gonna post that i fixed it!!!!!!!!!!!!!!!!!!! i took the chargable battey pack out and put the 2 AA battery pack it and BAM it synced up!!!!!!!!!!!!!!!
  • hehfire May 11, 2010
    I have a common issue, tried syncing bothe my two controllers, neither works. My controller has been disconnecting randomly as well over the past few days.
  • sabrinacat41
    sabrinacat41 Jul 03, 2012
    Same here. Just started doing it. At first I thought it was just my controller, which is a wired one I actually plug in, but when I tried to synch my brothers controller it wouldn't connect either.
If your controller is just blinking you must press the small button on your xbox and at the same time press the small button on the back of your xbox controller and the xbox will pick controller signal.
Posted on Mar 14, 2009
This seems to be unclear to many people. You do NOT press the main Xbox guide button. On the back of the remote between the LB/RB/LT/RT buttons is a sync button that looks exactly like the one on your Xbox 360. Hope this helps!
~Tin
Posted on May 02, 2009
  • Lisa Marzian Apr 24, 2013
    Yes! It is unclear b/c new controllers don't indicate that anywhere. ALSO the xbox console must be on B4 synching. synch button on console is on front of console to left of usb door flap. as Tin said on controller synch button is "between the LB/RB/LT/RT buttons". Steps Are: 1. Turn on Console. 2. Hit both Synch buttons simultaneously
I'm having the same problem. Came up from out of the blue. Bought a new controller and that one won't synch either, even after repeatedly using the synch buttons on the cosole and controller.
Moral of the story? Xbox SUCKS and I'm going back to Playstation.
Posted on Jan 24, 2010
I was having the same problems recently, discovered that it was the wireless router wich was only 2 feet away from the xbox. some distance between the two and/or a metal plate should fix it if you have a similar setup.
Posted on May 04, 2009
  • SeboCypher Sep 02, 2010
    Wow i just realize i have my Xbox right next to my wireless router too. But i hooked up the controller using the wire and still it didnt work?
Press the synch button on your xbox 360 - then hold down the find/seek button on the back of your controller.
Posted on Feb 01, 2010
HOLD THE SEARCH BUTTON ON YOUR CONTROLLER !!!
  • this just worked for me, i tried everything else
Posted on Oct 22, 2010
    New Friend:
Just fixed mine. Push small sync button on Xbox. Then push middle top. Then hold small button to sync on back. Top green should start left top and circle around then stops top left green with lower right steady.
Posted on Mar 16, 2013
    New Friend:
Yes stephen adams there free unsuported servers are the best answer you dumb as$
Posted on Dec 11, 2012
Really? Still no solution for this? I'm having the same problem, never had this problem before until I traded my old 360 for the new one. Can't wait to convert back to PlayStation when the new generation consoles come out, will never make the mistake to invest in Microsoft again; lesson learned.
Posted on Dec 07, 2012
  • Jessmore Dec 11, 2012
Theres sumthing wrong with my xbox 360 none of my remotes work. i tryed everything. it works for several seconds and it disconecs...i even bought a remote with the wire and it still wont move?it plays games and plays movies and everything but i just cant use any remotes sumbody plz help
Posted on Apr 04, 2011
I just recieved this problem as well. i have one controller synced with my 360. i have two more controllers synced with other 360s though. they will not sync. the xbox says it sees them, but they wont sync. help please!
Posted on Jul 18, 2008
I got a problem where nothing will connect, I can turn my Xbox on with the controller but it will not sync as 1st player. I tried pluging in a wired controller It will turn on then right away turn off. It is not a problem with the router either. I tried turning on the console letting it sign me in then try to trun on controler nothing. I tried using AA batteries aswell. If you have a solution please help me out thanks alot.
Posted on Aug 16, 2010
  • 64 Answers
SOURCE: I have a brand new
The guide button won't work until its synced,you need to push the button on the console to look for controllers then the button on the controller and it will sync it and then it should work fine. If that doesn't work then try hitting the button on the controller first then the one on the console.
Posted on May 18, 2011
lyonzy1
  • 208 Answers
SOURCE: Xbox 360 Controller: My xbox 360 controllers wont sync at all no matter...
Try replacing the batteries in your controller. If this does not work then try the controller on another console. Failing this your controller is broken.
Best recommendation is to buy a wire and use it wired.
Posted on May 20, 2010
jerryirwin75
  • 18 Answers
SOURCE: My Xbox 360 controller will
try pushing the button on the controller first then push the button on the XBOX
Posted on Jan 15, 2009
SOURCE: Wireless XBox controller won't sync with the PC adapter
I finally found a solution that works for me (most of the time). I bought a USB hub (un-powered at the moment) and the problem seems to have disappeared. The Hub however isn't the solution. Running the controller or the hub from the rear motherboard ports is.
I was initially using the 360 wireless receiver from the front ports on the PC which are driven by a different circuit on the motherboard than those from the rear of the PC.
When the receiver is run from the rear ports or in my case a hub powered from the rear ports it works most of the time.
Ocassionally the receiver doesn't link with the 360 controller however unlike last time when pressing all kind of combinations of re-sync buttons did nothing, all I do now is press the very tiny white button on the front of the controller and it links up like it should within 1.5 seconds.
I hope this helps guys as the controller is great when working.
Cheers
Karl
Posted on Feb 12, 2009
  • 58 Answers
SOURCE: My WireLess XBox 360 Controller wont connect to my XBox 360
i had the same problem, and is a easy fix, turn on your console, dont need the controller on, and hold the sync button for approx 30 seconds, then turn the console off, take out the power lead from the console and then remove it from your mains, wait about 1-2 minuts then plug it up and switch on the console, first sync the xbox then the controller, and this should work, if it dosent try xbox support their number is on xbox.com
Posted on Jun 02, 2009
My xbox 360 will not sync with any controllers besides the one controller I've already had synced. I haven't had any problems with it until recently, and now it seems like the xbox won't...
If you have an xbox slim model then there is a button above the USB slots at the bottom. Press Start and Back on the controller until the center button lights up. Then press the button above the two USB solts and hold it for a couple secs.
If you have n old xbox there should be a simliar button some where.
Also if you bought one of the charging packs for the controller, use the cord that came with it.
Thank you for your time, Good luck and I hope it works.
Jun 05, 2011 | Microsoft Xbox 360 Console
I have a brand new controller which came with my new xbox 360 and i have put the batteries in the correct way as instructed but when i press the xbox guide button nothing happens. I have also tried to sync...
May 18, 2011 | Microsoft Xbox 360 Controller
I went to turn on my xbox wireless drum kit and the light just came on for a second and then went out so i replaced the batteries, several times but it still wont come on
Well you can try this solution to get it too work. The thing with the XBOX 360 is that it has a hard time syncing with other controllers made by different companies. So try these steps first and see if they work if not you might have got a set of bad drums.
Step 1. Turn on XBOX 360 Step 2. Turn on drums (hold xbox button on drums). Step 3. Press sync button on 360 (XBOX ligh on console should start circling Step 4. Press sync button on drums [under D pad] (xbox light on drums should start circling)
If this doesn't work then you should RMA the drums to http://rockbandservice.ea.com to replace the bad ones.
Apr 23, 2011 | Activision Xbox 360 Guitar Hero II
None of my wireless XBox 360 controlers will connect to to my XBox 360. I have tried replacing batteries, syncing it with the system, turning my system off then on again, removing any obstructions near the...
If the wireless controllers won't connect under any circumstances even with the Charge-and-Play Cable then you most likely have a problem with a board inside your 360, i think it's like the RF board or something, mind you, the C-P cord only forces through an electrical charge and does not force the controller and console to connect, it just works when your batteries are low, in the event that your console is faulty, you can purchase RF boards and replace them yourself (voids the warranty but takes 20 minutes) or send it into XBox HQ (gives you more warranty but takes like 6 months)
Apr 16, 2011 | Microsoft Xbox 360 Controller
Wireless controler won,t connect to consol
I'm sure you have tried most of these steps but I'm going to list them any way. So we have a complete picture of the trouble shooting process.
1. Sync system first (By pressing the sync button on the system)
2. Right after you hit the sync button on the system, hit the button on the controller
Try replacing the battery's and or rechargeable battery for the controller. Repeat the sync process above.
Try another controller with your xbox or try your controller with a different xbox. Repeat sync process above of course.
If another controller works with your system than that would indicate that there is an issues with your xbox controller.
If your controller works with another xbox and no other controllers work with your xbox than there is a issue with your console.
For issues related to the xbox I would suggest contact xbox directly by calling 1800 my xbox.
I hope the info listed above has helped in some way.
If possible please rate this solution.
Aug 22, 2010 | Microsoft Xbox 360 Controller
May 18, 2010 | Microsoft Xbox 360 Controller
My Xbox 360 controller is not flashing when I try to connect
make sure you press the find button on the 360 and the one on the controller.
on the 360 it is a small circle bellow the disc tray and to the right of the two memory slots.
on the controller it is on the top its small and circlular with three semicircles near it.
if it still doesnt work then try to synce up with another persons console. if the controller still doesnt then you need a new one. if it does then use their controller to sync up with your console. if it still will not sync up with YOUR console.
then call
1-800-4MY-XBOX
1-800-469-9269
Jul 08, 2009 | Microsoft Xbox 360 Console
Maybe there was a problem with the system before you got it and that's why it was sold on ebay. If the console is still under warranty, you can send it to microsoft for repairs. If it's not under warranty you will have to pay a $140 fee to have them repair it.
May 31, 2009 | Activision Video Game Consoles & Games
XBOX 360 WIRELSS CONTROLLERS JUST BLINK WONT CONNECT
Did you try to press the sync button on both the XBOX and the controller? This should make them connect after they take a second to find out that their searching for eachother. If this doesn't work then you should call into Microsoft and talk to them because the sync system might be faulty. Try the controllers on another XBOX before calling just to make sure though.
Dec 30, 2008 | Microsoft Wireless Controller for Xbox 360...
Turn on the X-Box, turn on the controller, press the "Find" button on the X-Box, It's the 3/8" ROUND button on the consol. Press the find button on the controller. It's the 1/8" round button next to the LB button.
Dec 29, 2008 | Video Game Consoles & Games
Microsoft Xbox 360 Controller Logo
15,816 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
