Question about Sharper Image CX602 Digital Voice Recorder
CX602 erase issue. how do i erase files?
How do i erase existing files on the recorder???
I have a shaperper Image voice recorder and I accidently found out how to erase a recording today. You first have to get to the recording you want, which ever one it is first, 1, 2, etc. Once you have located it, stop and press erase. It will then say "erase" on the screen. At that point you press erase a second time and then it will say "stop". This will erase that recording.
Hop this helps.
Posted on May 23, 2009
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Why not using Erasephone to permanently clean up everything from android ,the way is required to install it on your computer , then link your phone to the computer and turn on it , it can completely delete data on the phone , this program more efficiency and convenient than simply delete by hands,you are free to choose to delete some of the data, Android Data Eraser Wipe Everything from Android Phone or Tablet
Posted on Dec 06, 2016
How do I delete a recording off my Sony Sony - ICDBX140 - 4GB
  1. Slide the HOLD?POWER ON/OFF switch in the direction of "POWER ON/OFF" to turn on the IC recorder, or towards the center to release the IC recorder from the HOLD status. The stop mode window appears.
  2. Select the file you want to erase when the IC recorder is in the stop or playback mode.
  3. Erase a selected file. When the IC recorder is in the stop mode, press and hold ERASE.
    When the IC recorder is in the playback mode, press ERASE.
  4. Press ERASE. "ACCESS" appears in the display window and the selected file will be erased.
    When a file is erased, the remaining files will advance so that there will be no space between files.
Hint
  • To cancel erasing, press souni_stop.png(stop) in step 3.
  • To erase a part of a file, divide the file into two files first, and then proceed with steps 3 through 4.
Mar 10, 2015 | Sony Video Cameras
Olympus DS-30 recorder: memory is full but there are no files to delete
1.Press the FOLDER button to choose a folder.
Every time the FOLDER button is pressed, it cycles through folders and the List display will appear (+P20).
Press the + or button to choose the file you want to erase.
Press the ERASE button. The “Cancel” indicator flashes.
Press the + button to choose “Erase”.
5
Press the OK button. The display changes to “File Erase!” and erasing will start. “Erase Done” is displayed when the file is erased. File numbers will be reassigned automatically
Apr 04, 2008 | Olympus DS-30 Digital Voice Recorder
Hi i own a RCA digital voice recorder model# rp5030A i can not figure out how to delete recordings
Erasing selected file
You can delete a file by the following steps:
1. Select folder (A, B, C , D or )
2. Select file.
3. Press ERASE once and DELETE will blink on the screen.
4. Press and hold ERASE for 3 seconds to confirm deleting. (or press STOP to cancel erasing file)
Erasing all files in a folder
You can delete all files in a specific folder by the following steps:
1. Turn on the unit.
2. Select a folder (A, B, C , D or ).
3. In Stop mode, press FORWARD continuously until "ALL" appears on the display.
4. Press ERASE and "DELETE" will blink on the display.
5. Press and hold ERASE for about 3 seconds, all files in the selected folder will be erased completely (or press STOP to cancel erasing all files).
Tip: File numbers that come after erased one will be moved forward by one automatically.
See page 12 for more info: http://www.rcaaudiovideo.com/docs/common/RP5030/RP5030_OM.pdf
Dec 29, 2012 | RCA RP5030 Digital Voice Recorder
I need its manual
Dear Rafael_Mella
Here is a link that may provide your manual, if you cannot find it there, message me back and I will have another look for you.
http://forums.techguy.org/hardware/803733-cx-602-digital-recorder.html
Hope this helps.
Yours sincerely
Ouszen
Feb 07, 2012 | Sharper Image CX602 Digital Voice Recorder
I deleted my audio files directly from the computer. Now that I try to record again, the device says that memory is full, even though I have no files on it. How do I reset it to record again?
To erase a selected file, first press the [ERASE] button. Next, press the [+] (plus) or [-] (minus) button to select "ERASE," and then press the [ERASE] or [OK] button.
To erase all files in a folder, first select the folder and press the [ERASE] button for three seconds or longer. Next, press the [+] (plus) or [-] (minus) button to select "ALL ERASE." Finally, press the [ERASE] or [OK] button.
NOTE:
The recorder should be formatted using only by using the internal FORMAT function found in the recorder's Menu. Formatting using the computer may corrupt system files needed to run the recorder, so computer formatting is not recommended. Individual files can be deleted using the computer with no negative effects.
Feb 05, 2010 | Olympus WS-321M Digital Voice Recorder
Software
.the 'techguys' had some good links + info on this one:..
One suggestion (since SharperImage has filed for bankruptcy) is lodge a complaint with the consumer affairs people (see link below) and maybe they could either get you your software or a similar option:
http://www.consumeraffairs.com/retail/sharper_image.html
WW
Oct 06, 2009 | Sharper Image CX602 Digital Voice Recorder
CANNOT ERASE EXISTING GREETING!
Try uplugging the power adapter from the wall and remove all batteries. Wait for three to five minutes before restoring power then batteries.
Try again to erase the greeting.
May 31, 2009 | Sony SPP AQ600 Cordless Phone
Erase recorded files on my Cenix VR-P490 voice recorder
You have to select the file to erase hold the erase button and when "ERASE" blinks in the display you have to press the erase button one more time. Do this for each file you wants to erase.
Jan 20, 2009 | Panasonic RR-QR150 Digital Voice Recorder
Problem with memory/erasing discrepancy
I did erase all from the device main menue after having copied them to my computer, that cleared the remaining files and recovered part of the memory. Then I did reformat from the same menu and recovered the entire memory! ;)
Oct 20, 2008 | Sony Network Walkman NW-A3000 MP3 Player
Dont know how to erase music from your iriver
In browser mode, select the file.
Then hit the A-B and record buttons simultaneously.
Aug 19, 2008 | iRiver T10 MP3 Player
418 people viewed this question
Top Sharper Image Audio Players & Recorders Experts
woodzowl307
Tom Chichester
Are you a Sharper Image Audio Player and Recorder Expert? Answer questions, earn points and help others
