Question about GE DCSR483EA Electric Dryer
Problem with my GE dryer
Hi, I have a GE dryer and today when I when to start my dryer sensor dryer cycle light came on but would not start. Any help would be appreciated.
Thanks,
Todd Peffer
  • nbostp Jul 07, 2008
    I got it fixed. There was lint underneath the actual lint trap that needed taken out. When I did that it started to run again. But thanks for your help everyone.
    Genius:
  • 1,224 Answers
Push start button needs replacement even when every thing is in place it doesnt start the push buttons points inside have warn out
ive worked on this model several times people tend to push the button a little harder so the plastic clips in side break and doesnt make its connection
the part is 12.84 easy to install as long as you do one wire at time
Posted on Jul 07, 2008
  • 481 Answers
  • turn your circuit breaker off then back on. sometimes the only one side of the dual 220v breaker will trip leaving you with a non functioning machine thats seems to have electricity going to it.
  • another thing to check is the door switch.
Posted on Jul 06, 2008
  • Mike Durland
    Mike Durland Jul 07, 2008
    • none of my free suggestions have helped you at all?
    •  if you feel the issue with the machine is something else let me know, i will try to help you figure it out.
    Mike
When i use my ge profile dryer on sensor setting it works for about 7 minutes then shut down like you unpluged it
I would check the moister sensor or thermistor, and the thermostats the hi limit and the cycling a well as thermal cut off
Apr 02, 2015 | GE Dryers
Need to replace safety thermostat in GE dryer
The limit you want is a WE4X800. It mounts on the dryer heater. Looks like this:
Here is a home video which shows how to get into the machine and check various components:
Oct 08, 2012 | GE DBSR453EBWW Electric Dryer
Ge dryer - buzzes when the start button is pushed but the dryer motor doesn't start or the dryer drum moves. could be a jam or the motor? Motor didn't seem to be a problem before today.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 16, 2011 | GE 5.8 Cu. Ft. 2-Cycle Extra-Large...
I have a GE dvlr223eg6ww dryer. Sometimes it stops after a few minutes of drying. The clothes still wet. I just push the start button and it start again. Sometimes I have to repeat this several times. ...
Today's dryers have many sensors and a fuse to prevent overheating and possibility of a fire. This is good.
Unfortunately, today's factories are often highly automated, and today's machines seem to collect a lot more lint deep inside because of looser fitting components. This lint seeps into the whole machine, and causes those many sensors to "pop".
Someone needs to dismantle the whole machine and clean out the lint.
Be blessed.
Mar 22, 2011 | GE Washing Machines
I have a kennmore elite dryer and I was very happy with it. Today morning no dryer cycle starts though all other usual lights etc. turn on as normal. After choosing the dryer cycle when I press start it...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Dec 17, 2010 | Kenmore Dryers
Ge front load dryer wont start but all the lights work and you can pick a cycle it also makes clicking noise when you push start.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 06, 2010 | GE Dryers
My GE Harmony Dryer is making a LOUD noise during entire cycle
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
yue
Jan 26, 2010 | GE Profile Harmony DPGT750EC Electric...
How do you light pilot light?
Dryer does not have pilot light.  There is an ignitor that glows when the dryer is started and lights the flame when the gas begins to flow.  With the front of the dryer off start it up and look for the glow. when it glows hot enough (or on a newer model it might be a spark) the gas should ignite.  When the flame sensor sees that the gas is ignited it shuts off the ignitor and keeps the gas valve open until the temperature sensor gets high and shuts it off.  When the temp sensor cools down the cycle repeats.
If no glow or spark-->bad ignitor If no gas flow-->bad flame sensor or bad gas valve coil If gas comes on and goes off quickly-->lint filter and/or vent pipe or outlet may be clogged or bad flame sensor.
May 29, 2009 | Whirlpool Dryers
GE gas dryer sensor light not working
I would venture to say that they failed to plug it in when re-assembling the unit, however if you do call them back out and you don't know what they are doing, they can easily say that it was something else and bill you again to cover themselves. Be careful, good luck
May 11, 2017 | GE DBSR453GBWW Gas Dryer
GE DCSR483EA Electric Dryer Logo
128 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
