Question about GE A730 Digital Camera
Connection Error I'm having a hard time connecting my A730 Digital Camera to my PC. I tried the arcsoft installer as well as installing the is730 enu (an OS camera driver for Windows 98, 2000, and XP) and yet the camera is not being recognized by the PC. I also followed the instructions posted in the GE support website (including the FAQs and technical support advisory) and yet it still fails the connection. Please help... Thank you.
  • 153 Answers
The Arcsoft CD will not help you as it is not a driver disc. No driver disc is needed. Sometimes the camera gives a false connection error message. The easiest way to tell if it is connected is to go to My Computer and see if any Removable Discs show up.
Trevor Gordon
Senior Customer Tech
General Imaging Company
(Exclusive GE Digital Camera Licensee)
Posted on Oct 28, 2008
Can't download the photos from the MiCam Junior Digital Camera. Software has been correctly installed, laptop recognises camera but when try to download error message "there is a connection...
I have uploaded the installation CD here (188.81Mb): http://depositfiles.com/files/qmc5ykx6p
I have uploaded the user manual here (2.6Mb): http://www.filejumbo.com/Download/26D632AAF285B1D0
Acquiring images from a TWAIN Device PhotoImpression accepts images acquired via standard TWAIN devices. 1. Click the Get Photo button on the Main Screen, and select Camera/Scanner. A list of your TWAIN devices will appear. 2. Select your desired device from the Select Source pull-down. 3. Select the album to which you wish to link the acquired image(s). 4. Click the Acquire Options button to set your acquire parameters: a. Specify the file format for the acquired images. b. Specify the save directory for the acquired images. c. Choose whether or not to retain the original file format (for example, some cameras may save in a specific format-you can have the program convert the files to an option of your choice, or retain the original format). d. Set the file names for the incoming files. You can choose to have the program automatically name the files using the current date, or you can specify your own unique file name. 5. Click the Acquire button if you are capturing from a still camera or scanner; click the Video Camera button if you are capturing a still from a video. Follow the procedures specific to your device to import the image into PhotoImpression.
Updates for the Arcsoft application "PhotoImpression" are available from Arcsoft
If there are connection errors, that could be from:
  1. USB connection error
  2. Hardware issue
Try plugging the camera (via USB) to a different port on the computer, then acquire the pictures using the included software, or your own photo editing software that is capable of acquiring images from a TWAIN device.
Hope this helps!
Guy
Dec 31, 2010 | Cameras
I have an A730 digital camera and when i plug it into the computer it says connection failed. What am i doing wrong?
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Dec 24, 2010 | GE A730 Digital Camera
Just says lens error and wont stop making grinding noise
Try one of these two fixes, if they dont work for you follow the link below for further troubleshooting.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
Jun 16, 2010 | GE A730 Digital Camera
HP Webcam Deluxe KQ246AA Not working correctly in XP
No solution, but I have precisely the same issue. I've reinstalled and removed ArcSoft many times, being careful to clean registries, etc but to no avail. The camera actually worked with Skype initially (plug and play), UNTIL I installed ArcSoft. So I think that ArcSoft "stepped" on a driver somewhere that I can't detect or repair. (I'm using "Driver Detective" but so far it hasn't helped) Will update if I find a fix.
Dec 04, 2009 | HP KQ246AA Deluxe Webcam
Downloading pictures to computer from a730 what do i need to do?
you need to install the appropiate software that goes with this camera or connect your camera to your pc via USB it will automatically detect the presence of your camera and from there you can see some option how to download
Aug 01, 2008 | GE A730 Digital Camera
WHERE DO I GET DRIVERS FROM
WHERE DO IGET DRIVERS FOR GE A730 DIGITAL CAMERS .I LOST DRIVERS DISK
Jun 26, 2008 | GE A730 Digital Camera
Make sure DigiKam, usbmount, and usbview are installed.  Set the camera usb mode settings to PC (PTP).  Plug the usb to camera cable into the back of the PC.  Now with the camera off plug in the cable into the camera. Turn on the camera and the Linux PC should pick up the camera as a usb memory device. Know you can transfer the photos to your PC.
Jun 03, 2008 | GE A730 Digital Camera
Cannot connect to PC
I have a mac. And i wan to download some pic off a vivitar mini digital camera i got i put in the .EOTQXXC Digital camera arcsoft photo impression4.0 but it won't let me. What i'am i doing wrong?
Apr 11, 2008 | Cameras
Wrote to GE about the problem. Win2000 is required. Looks like they aren't interested in getting a driver written for Win98.
However, they suggested I transfer the pics to an SD card and then use an SD card reader (cheap enough) to transfer the pics to my computer. IT WORKS but I would much rather transfer directly from the A830 camera to the Win98SE computer via the USB cable..
Mar 01, 2008 | GE A830 Digital Camera
Camera connection turns pc screen blue
A typical issue if the host PC's motherboard drivers were never installed. This and more at http://www.usbman.com Sadly, you didn't tell the make/model/chipset of the host PC so I can't comment further.
Sep 08, 2005 | Samsung Digimax 401 Digital Camera
GE A730 Digital Camera Logo
Top GE Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a GE Camera Expert? Answer questions, earn points and help others
