Question about NexxTech NWOMMI Mouse
Advent ADE-EMB2 Hi, New mouse worked perfectly until next time I logged on. Cusor doesn't move at all. I disconnected the USB port and reconnected. Blue light on the usb so that seems ok. Tried the re-set button on bottom of the mouse, no luck, also tried the turning mouse off and then back on. Don't know what I'm doing wrong. I'm not very computer lit so I'm sure it's something simple!
SOURCE: My new Nexxtech NWOMMI cordless mouse is not working
Here is what I found about the Nexxtech Notebook Wireless Mouse (NWOMMI):
1. The 2 AAA batteries must be inserted correctly. Look carefully at the "+" and "-" marking on top of the battery compartment and put your batteries in accordingly. Otherwise the mouse will not work, and could be damaged. After the batteries are inserted, the red light at the bottom of the mouse should come on. More on batteries below.
2. Insert the USB receiver into a USB port. The blue light should come on. Press the little button next to the blue light and the light should start to blink,
3. Whild the blue light is blinking, press the connect button at the bottom of the mouse. It is the big black dot inside the white label. Check that the blue light on the receiver is blinking faster, and then change to a steady light.
4. Now check the function of the mouse by moving it on a texture surface.
5. If all goes well, your mouse should be working.
However, here is the bad news. Either due to bad design or some flaw in manufacturing, the mouse consume batteries like crazy. I used fully charge NiMH AAA batteries and they last for only a few hours! And the worst part is that, I checked the batteries when the mouse stop working, ONE of the batteries is COMPLETELY drained, in fact it registered a reverse voltage of -0.1 volts (a charged values is +1.2 volts). This is definitely engineering problem. Note that even when the batteries are in this state, the red light may still come on, and sometimes the re-connection seems to be ok (i.e. the blue light blink faster and then changed to steady). However, the cursor will not work when you move the mouse! Recharging the batteries and the mouse will work again.
Based on the above observation, the mouse instead of having a power-saving feature, it actually has a power-wasting feature!!!
Posted on Sep 19, 2008
SOURCE: advent ADE-AD2 drver for vista SP1?
I ignored the "doesn't support your OS" and rebooted. I then got the information icons (scroll lock, num lock, caps lock) on the taskbar. I'm happy with that.
Posted on Nov 09, 2008
  • 8637 Answers
SOURCE: My Mouse died
Did you check the batteries to see if they are good. Some individuals are having to replace the batteries sooner then they should have to. Good place to start. Hope this helps. Bud
Posted on Jan 20, 2009
  • 8637 Answers
SOURCE: mouse will not work
Press the button till mouse light comes on.
then try Normal 0 pressing the receiver button and then press the button on the mouse momentarily. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
  • 76 Answers
SOURCE: Hi, I have an Advent ADE - WD1 wireless keyboard and no receiver
Check or manufacturer web site for customer support/contact information.
Posted on Sep 12, 2009
Cannot get it to connect to hp laptop
Have you tried with a another mouse?
When you plug the mouse, something happens on the computer?
It's a special mouse who need special drivers to works?
Jan 07, 2016 | HP Computers & Internet
The mouse and keyboard randomly disconnected and will not connect weather not i put new batteries... the only way it connects is when i remove 1 battery and push the other one in twards the spring and the...
hi dirtfreak,
Good day!Did you check the remote USB connector?try detaching it from the port inserted and reinsert it in other USB port and see if it works.,change the batteries with new one if you have..then reconnect all..
Feb 08, 2011 | Logitech Cordless Desktop EX110
Does an advent ade-emb1 usb mouse require batteries in the mouse? i was using one with windows xp no problem then mouse optical light just stopped working help please
  • If it is a wireless mouse then it requires batteries.
  • In case if the advent mouse is a wired mouse then it doesn't require batteries.
Apr 06, 2010 | Computers & Internet
Wireless mouse wont connect.
Hi there.
Some wireless mice seem to go into some kind of sleep mode, in other words if you leave them for an amount of time they disconnect, the way to reconnect is to right click while moving the mouse.
Also check to make sure that the batteries in the mouse are seated properly.
Good luck
Jun 01, 2009 | Logitech Cordless Desktop EX110
Mouse is sticking and not moving
With the computer on try to unplug it from the computer, wait a few seconds and plug it back in. Many times this will do it. If not, unplug it and then plug it into a different usb port. The computer will think it is a new device and reinstall the drivers for it in that port. It's a simple solution ,but works many times. Good kuck.
Dec 09, 2008 | Microsoft 3000 Mouse
I have an Advent ADE-WLOI1 wireless mouse. Recently moved house and packed up my pc and mouse - now mouse won't work. Tried reset button - no go. My pc is virus infected and am trying to clean it - without...
This seems to be a generic mouse, usb / ps2 connectivity. User needs to press the connect / reset button on the receaver and on mouse. generally.. no drivers or cd required.
mouse has battery.
-check battery
-reconnect (receaver and mouse, if receaver doesn't have button, make sure its connected to pc and power is on, then reset.
try ps2 instead of usb or another usb port, might require adapter. (if im not mistaken it comes with the mouse)
-try another pc
= possibly faulty mouse if still not working? It should work with windows drivers, so no cd required.
Sep 23, 2008 | Computers & Internet
I have an advent ade-emb1 mouse which has stopped working and I can't seem to get it to connect with the laptop again.
I had the same problem and took it back for a refund. However the helpful 'Tech Guy' reset it by pressing the button on the USB, and the little button halfway down the underside of the mouse at the same time. It now works perfectly!!
Aug 13, 2008 | Computers & Internet
Advent ADE-EMBI mouse has stopped working even though both the USB light is on and the battery light is on. Can you help?
plz try with another mouse, if the new mouse is working then your old mouse is defective
Aug 05, 2008 | Computers & Internet
Advent ADE-AD2 Wireless keyboard and mouse
I've actually just bought a new keyboard and mouse (Today!) because I could not get my advent ade-ad2 to work at all on vista, (Previously had it on my xp).
Thought I'd give it one last try as PC world were no help this morning and previous internet searches were no help either.
Soooo. after the usual on/off...push in little button on underside etc.etc...the only thing that I did different was press the "wake" button on the keyboard.
Bloody hell, it worked!
New keyboard going back tomorrow!
Jun 01, 2008 | Computers & Internet
NexxTech NWOMMI Mouse Logo
471 people viewed this question
Top NexxTech Computers & Internet Experts
Steven Wander
Steven Wander
Alun Cox
Joe Goldman
Joe Goldman
Are you a NexxTech Computer and Internet Expert? Answer questions, earn points and help others
