Question about GPS
Raytheon RC520 Powers up, but NO FIX appears on upper right corner of display.
  • Rooky1619 Aug 12, 2008
    My Raytheon RC 520 powers up , but, No Fix appears? Any ideas?
If you can find the white junction box where the antenna is connected take a volt meter and measure across the red and ground wire, you should have 12 volts. Across the yellow and ground wire you should see 10 to 12 volts it should also vary. This will tell you that all DC voltages and the seatalk voltages are OK. I would next secure power to the antenna, leave it off a couple minutes and then try it again. If these suggestions do not help you may need to replace the 120 GPS. The new RS125 is the replacement for this unit.
Posted on Sep 22, 2008
  • Channelman Sep 22, 2008
    re the above i had the same problem and e mailed Ray Marine who sent back the above answer, the antenna is not the 125 it is a later one which costs about £200
Remove cd player/2003 toyota avalon xls
hi,
please state the problem completely sir.What is it that you want to do?
Jul 19, 2011 | Car Audio & Video
How can i enter BIOS set up pf Compaq Armada M700
Usually the delete key or F2 will do the trick
Mar 09, 2011 | HP Compaq Armada M700 Notebook
Can anyone offer any suggestions on how to delete/remove titles displaying in the upper left hand corner of my TV screen and right hand corner? For example, if I am watching a program on CITY, the title...
I believe the "Caption Vision" is selected. By pressing the "Display" button on the remote it should toggle through the choices until "Display Off" appears. That should be all.
Mar 05, 2011 | Sony KV-32S42 32" TV
Where is the battery indicator on this camera?
The battery level indicator will appear in the upper right corner of the display when the level drops low. If nothing appears there then the level is good.
Oct 02, 2010 | Nikon COOLPIX L18 Digital Camera
Photos have a black corner. Sometimes upper right, sometimes lower right. The black corner covers approximately 5% of the width and height of the image. Can I fix this myself?
This might also come from a problem with a dealignment of one of he servo-motors (horizontal or vertical) which center the lens during anti-shake adjustment.
If your camera vibraets at start or shows a vibrating image on display then this is the problem.
Then the lens is often out of axis and black corners appear on the display and of course on the picture...
I have not found the solution but have posted a request !
It may only be some disconnected part near the lens but unfortunately nobody shows pictures of HOW to dismantle the Z5 ! and WHERE are these 'bloddy' servo-motors or alignment devices ?...
Sep 14, 2010 | Konica Minolta DiMAGE Z5 Digital Camera
Camera not displaying pictures I have taken
are you sure that the memory card is in the camera? if not, thats probably the problem!
Oct 10, 2009 | Canon PowerShot SD1000 Digital Camera
AKAI PDP4273M1 - Unit powers up then shuts down.
I just repaired one for the same trouble. The input to the main processor from the standy switch had shorted to groung. This was probably caused by static inserted when pushing the power button. The processor is not a replaceable part. The part number for the main board is E3761-058010-2. It costs between $140 and $150. I found it on-line at Shopjimmy.com.
Good Luck!
Jan 29, 2009 | Akai PDP4290 42 in. EDTV-Ready Plasma...
Oven wont work everytime we push bake E1 and F1 appear
Is the display showing E0-F5?
The Self-Cleaning latch may be interfering with the oven door causing the Self-Cleaning cycle not to work. If the oven door is open and will not lock, press Stop/Clear to clear the display, press and hold the door switch plunger (located in the upper-right corner of the oven front), and the door latch will unlock. If the oven door is closed and locked, press Stop/Clear to clear the display; apply pressure to the upper-right corner of the oven door, and the door will unlock.
Is the display showing E"#"-F"#," for example, E1-F2?
You will need to schedule service.
Aug 24, 2008 | Whirlpool Kitchen Ranges
Looks like a crack in the display
such issues have occured in the Past, Please Check if the Crack appears in the BIOS mode.Safemode also Try another Monitor to find out if it is not the wall paper because if it is then the Crack will appear in the other Displa too...
Jul 17, 2008 | Computers & Internet
GPS Logo
824 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
