Old ideal tybe b boiler piolet light working but burner not working
    Genius:
  • 1,036 Answers
There are a couple of things this may be, so will need checking to rule them out as the cause.
There is a "hot wire" sensor in the pilot flame that allows the main gas valve to come on when it gets hot.
You will need to check the output from this when cold, and when hot. It's a safety feature to prevent gas escaping when not lit.
When cold, check there is continuity in the gas valve coils. A faulty gas valve will not open. This should only be replaced by registered trades people if it is faulty.
Check the blower motor coils in the same way for continuity. If they are defective, they will not allow power to the gas valve either - or it will cause overheating.
If everything checks out ok on the boiler side, try jumping the thermostat contacts, and see if it fires up. If it does - replace the thermostat.
Thanks for using Fixya!
Posted on Jul 06, 2008
Jolly boiler
Clean ignighter and piolet
Jun 11, 2014 | Water Heaters
Ideal response 120 seems to fire up but burner light does not come on and boiler runs for a while and stops,no hot water or heating ???
If this an older style boiler remove thermostatwires
at boiler terminal board and put jumper between R and W, if boiler starts you have bad thermostat.
If it does not come on then it appers that you have
a problem with the spark ignition or glow coil is
bad
Jan 09, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
Gas boiler doesnt ignite
Clean the pilot assembly and replace the thermocouple. I suspect that the thermocouple that is installed now is getting tired and is failing. While you do that, clean any debris off the burner(s) and look for any sensors that may need a cleaning as well. You could have a bad connection on the gas valve so check all wire connections for corrosion and clean. Yes the gas valve could be bad not allowing the main burner to ignite but check everything else first.
Oct 20, 2009 | Heating & Cooling
How flem sensor works in furness
After you hearthe click from the ignitor your piolet will light. the flame sensor (mounted next to the piolet (tip in the flame) ) will sence the heat from the piolet sending a milivolt siginal back to the ignation board. once the board knows there is a piolet and the system is safe the main valve will open igniting the burner trays.
Mar 16, 2009 | Goodman GMS90703BXA Heater
No hot water from combi boiler
i have a combie bolier when i turn the hot water taps on only cold water comes out central heating working fine can any one give some advise ?and can i fix it myself.
Jan 03, 2009 | Combi Centre DX - Mango
Pilot light has gone out onmy Ideal Elan 2 Boiler
TAKE A SHPO VAC AND CLEAN AREA. MAKE SURE YOU PAY SPECIAL ATT. TO THE PILOT LIGHT. FIND BUTTON HOLD IN AND IGNITE DONT LET GO WHEN IT LIGHTS FOR AT LEAST FIFTEEN SEC.. YOU MIGHT ALSO HAVE TO TURN THE THERMASTAT OR KNOB TO PILOT FIRST. AFTER IT HAS LIT TURN UP FLAME
Oct 25, 2008 | Water Heaters
Heating & Cooling Logo
181 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
