Question about Archos 605 WiFi Digital Media Player
Same problem hi im having the same problem as you with archos i cannot get past the screen telling me to repair or format... i was wondering if you found a solution. i would be really grateful if you could get back to me asap on layla_876@hotmail.co.uk
  • Quelch Jul 31, 2008
    I, too, get the same screen. Error 102.
    I've tried resetting by both methods in the manual.
    Once, I got into the memory & tried to do a hard drive format - it did nothing.
    I've tried to get to the 'blue screen' as suggested in the manual - I can't get there!
    Peter McCall
LAST HOPE !!!
ERROR CODE 102!!!
I JUST FOUND OUT THAT I HAD THAT SAME PROBLEM TOO...AND I WAS ABOUT TO THROW IT AWAY OR GIVE IT TO MY WILD CAT TO PLAY WITH !!! BUT!!! HERE IS WHAT I DID FOR MY LAST HOPE IN SOLVING THIS PROBLEM...
FIRST HERE ARE THE DETAILED PROBLEMS I HAD...
*NO RECOGNITION OF MY ARCHOS IN MY PC...
*ERROR SCREEN..."SYSTEM DAMAGE...REPAIR? NO,REPAIR,FORMAT DISK"
*SELECTED ANY OF THE OPTIONS...SAME STUFF...BACK TO THE SCREEN...NEVER ENDING STORY...
OK...THIS IS WHAT I DID...
1 DOWNLOAD THE LATEST FIRM FROM WWW.ARCHOS.COM...TO YOUR PC !!
2.AFTER DOWNLOADING THE LATEST FIRM UPDATE TO YOUR PC... PLUG IN YOUR ARCHOS TO YOUR COMPUTER...
3 YOU WILL NOTICE THE ARCHOS IS NOT DETECTED AND YOU ARE IN YOUR SCREEN ERROR STILL...OK...TURN YOUR ARCHOS OFF BY CLICKING ON THE POWER BUTTON FOR ABOUT 5 SECONDS OR UNTIL IT TURNS OFF...(NOTHING ON THE SCREEN BUT BLACK...)
4. THEN...WE ARE ABOUT TO TURN IT ON AGAIN...BUT BEFORE THAT... LEAVE ONE FINGER ON YOUR TV/LCD BUTTON PRESSED !!! HERE IS THE SECRET...THEN TURN IT ON !! BUT...DO NOT LET THE TV/LCD BUTTON RELEASED !! IS LIKE YOUR ARE GOING TO PRESS BOTH OF THEM AT THE SAME TIME...AND WAIT FOR FURTHER INSTRUCTIONS...
5. THEN ANOTHER SCREEN WILL APPEAR..SORT OF LIKE...HDD RECOVERY 2...YOU MIGHT WANT TO UNFORTUNATELY FORMAT YOUR DISK...
6. ONCE IT TELLS YOU DONE ! DO NOT PRESS ANY BUTTON... THE PC WOULD NOW RECOGNIZE YOUR ARCHOS...AS A HARD DRIVE..ETC...
7. ONCE IS DETECTED BY YOUR PC...REMEMBER THE FILE YOU DOWNLOAD IT... DRAG IT DOWN TO YOUR ARCHOS..IN THE ROOT SECTION... THAT MEANS...IN NO FOLDERS INSIDE THE ARCHOS...BUT BY ITSELF...JUST LIKE ANY OTHER FILE IN A FLASHDRIVE IF YOU MAY...
8. THEN IT MIGHT ASK YOU AGAIN YOUR PC...YOU WANT TO FORMAT THIS DRIVE...JUST SAY YES....OK...WHATEVER... AND LET IT FORMAT...
9. FINALLY AFTER THE FORMAT SITUATION HAPPENS...YOUR ARCHOS WILL ACCEPT THE FILE...AND IT WILL BE DOWNLOADED AUTOMITICALLY...THEN REOPEN IT TO MAKE SURE IS THERE ALREADY...
10. FOR THE LAST STEP... ENJOY ! MY ARCHOS IS BACK TO NORMAL..IT REBOOT AND EVERYTHING IS FACTORY MADE...HOPE THIS WORK GUYS...AS FOR ME IT DID...
PS. PLEASE BE PATIENT ON THAT OPTION OF THE TV/LCD FOR IT MIGHT NOT WORK RIGHT AWAY...I TRY IT LIKE TWO TIMES BEFORE IT LET ME FORMAT EVERYTHING...BECAUSE YOU MIGHT GET ERROR MESSAGES LIKE..."MEDIA FAILED" ETC... JUST KEEP ON TRYING UNTIL IT ACCEPTS IT.. LET ME KNOW WHAT HAPPENED...
Posted on Jul 11, 2008
Recovery (code 104)
From Archos' support website FAQ:
When I switch on my Archos device, the following message is displayed: "Would you like to recover your system?" What does it mean and what should I do?
You are on the recovery mode screen. It means that your hard drive has been damaged and must be repaired or formatted.
With this system recovery mode, you will have to select between "Repair Disk" and "Format Disk".
Start by selecting "Repair Disk" and follow the instructions displayed on the screen. See the full PDF manual (available on the Archos web site) on how to use the Repair and Format options.
If repairing the disk did not work, try formatting the disk by selecting "Format Disk". Note that the formatting will erase all data.
If you still cannot restart your Archos after trying a system recovery, you should contact Archos technical support.
http://www.archos.com/support/support_tech/faqs/en/faq_Archos405.html?country=us&lang=en
Feb 17, 2011 | Archos 405 Digital Media Player
Archos Av500 startup problems
its a HDD or OS failure
ull have to ask the company for a replacement if its under the warranty period
make sure to register ur device on the Archos website to get a 'Technical Support Passcode.'call Archos to tell them ur problem and if ur lucky they wud repair it free of charge
if u want to try it urself...i found this one of the forums on the net..
1.remove all the screws, and remove the battery.
2. Remove the hard disk from the player by disconnecting the ribbon connector carefully from the mainboard.
3. Try to startup the player after putting the battery back in place. This time, instead of turning off, the player showed a "cannot read hard disk" error with the option of formatting it. Made me realise that the hard disk was the culprit. However, I had heard the hard disk noises previously, and they sounded fine, so I realised it was a software issue (file system was corrupted)
4. Try to connect it back, same problem as before... Also it is very difficult to first start the player & then connect the hard disk, as the player is designed to shut off in that situation.
5. The best option after this would be to get a drive enclosure designed specifically for 1.8 hitachi hard disks to connect the disk directly to the computer using USB and format it.
6. However since I didn't have a specialised enclosure, I did a lot of trail and error with the player itself (running off mains while connecting the hard disk after starting the player without releasing the power button etc etc etc) which Im sure wasnt too kind on the hard disk, but voila, I managed to start it up fine WITH the hard disk in place without the player turning off using some weird combination of holding down the power button and connecting the ribbon on the bootup screen)
7. After this, he was able to select "format", and the player began working fine he lost all the data on the player itself, but luckily he had backups of everything!
Thanks for using Fixya
Jul 16, 2008 | Archos AV 500 400-Hours Video Recorder
My Archos 5 is displaying a Code 101 error message. How can i fix that? I can't get to go past this message?
Your system is somehow corrupted, could be music downloaded from the net, whatever it is easy fixable.
A) Download the firmware from Archos and save it to your desktop (Make sure the file name on the desktop hasn't changed from the original download file name)
B) The Archos 5 or 7:
1- Plug the unit to you computer via the USB cable.
2- The unit should start automatically and open the following page:
3- From the recovery console (the screen that asks for repair or format etc…)
4- Select "Repair" by scrolling up and down with the volume control on the right of the unit (Do not press "Format" at any time)
5- Now that you are on "Repair" press the on and off button, shortly to validate your selection
6- The unit will go to "Plug the unit etc…" but it is already plugged from point 1 - DO NOT press anything anymore on the Archos
8- Wait until Pc should recognizes your Archos (around 5 seconds)
C) Computer
1- From your computer select the firmware file you downloaded from the net and put it in your Archos (in the root folder, nowhere else, where it has the folders, music, videos, pictures etc… as a file)
D) On the Archos 5 or 7
1- Select "Ok" on the Archos (on & off button) shortly to select and confirm the file is now on the Archos
2- you are done! The Archos 5 or 7 should now read through the file you have transferred and repair the system
3- DO NOT DISCONNECT the USB cable until the process is finished
4- when done safely disconnect (as you usually do, for Mac trash the letter of the Archos to the bin or for PC's: right click the green icon bottom right of the screen for xp & vista)
5- Press on/off button to reboot
Your unit should restart with a fresh repaired, updated system like day one.
Apr 15, 2009 | Archos Internet Media Tablet MP3 Player
File system error FAT is corrupted
Hi
This is the best solution i found so far...
i have an Archos 5....i went to : TOOLS - SETTINGS - CUSTOMER ASSISTANCE - REPAIR and FORMATTING TOOLS - REPAIR SYSTEM - clear temporary system files and cache..! (At the repair system page, you will get all options like "Reset Settings;Format harddrive;Full reinitialization etc...So u can choose what suits you best, n ALAS! Your achos will be back to normal....
Cheerz..
Roscoe
Mar 16, 2009 | Archos 405 Digital Media Player
Just got Archos 5 goes into error 101...
Hi there, these instructions are for the archos 705 but they are the same for the 605.
B) The Archos 705:
1- Connect the unit to its power source.
2- Start the unit in recovery mode: Press the TV button first then the power on/off and keep pressing TV button (do not release it)
3- The recovery mode will start (the screen that asks for repair or format etc…)
4- Select "Repair" by scrolling up and down with the TV Button (it is all explained to move through the menu at the top of the Archos screen) (Do not press "Format" at any time)
5- Now that you are on "Repair" select it to validate your selection
6- The unit will go to "Plug the unit etc…" plug it with the USB cable to the computer
C) Computer
D) On the Archos 705:
2- you are done! The Archos 705 should now read through the file you have transferred and repair the system
3- DO NOT DISCONNECT the power cable until the process is finished
4- When done safely disconnect (as you usually do, for Mac trash the letter of the Archos to the bin or for PC's: right click the green icon bottom right of the screen for xp & vista)
Jan 21, 2009 | Archos 605 WiFi Digital Media Player
Hdd_recovery 2
LAST HOPE !!!
ERROR CODE 102!!!
Jul 16, 2008 | Archos 605 WiFi Digital Media Player
Archos 605 160G Error cod 102
Hi everybody i just got off with archos USA tech support there is no other way but to send it in and they wil replace the HDD with a new one. If the archos is not under warranty repair cost is $ 172.50 i think you can buy another one for that price. Although they give you 90 days warranty for their fix.
Jun 29, 2008 | Archos 605 WiFi Digital Media Player
Archos seems to have Bricked itself
my archos just goes back to code 102 and i have tried it several times
what do i do now
please help
Apr 23, 2008 | Archos 605 WiFi Digital Media Player
Good morning can u tell
Try using a professional ripping program, I have used DVD Ripper from Jesterware, put in the DVD select your device (if listed) or what output you want and away it goes. By adjusting the settings (include duplicate frames, etc I have managed to output all my film collection (250) to a Divx format and put it on to a portable 2.5 media player. I can watcg them anywhere now.
Apr 06, 2008 | Televison & Video
Archos 605 Recovery code 108
In order to fix this issue, we are going to need to force the unit into a
recovery application. In order to do this please make sure that the unit is
completely shut off. When the unit is off, you are going to want to press and
hold the TV/LCD button and the power button at the same time until a recovery
code 101 pops onto the screen. As soon as you see this, let the buttons go.
Once you got this screen up, you are going to want to repair the operating
system by arrowing down and clicking repair. After this is done it is going
to ask you to connect your device to the computer and install an update file.
In order to do this, you are going to want to go to www.archos.com and go to
downloads. You are going to want to download the firmware for your unit.
After the firmware is saved to your desktop, plug the unit into the computer
and open up "My computer" and you should see the Archos in the list
of drives.
Your going to want to copy the firmware onto the root directory and not in
any file folders. Once the firmware is on the Root directory, go ahead and
unplug the unit from the computer. It should still say Please plug your
device into the computer and install an update file. Click OK. After this is
done, it is going to tell you to please connect DC or USB in to continue with
the update. Go ahead and let the unit install and reboot. After this is
done, you should be able to use the unit properly. If the unit still does not
work properly, we are going to have to create an RMA for the Archos. If you
need anything else, Please feel free to contact us via Email or at
877.300.8879.
Jan 10, 2008 | Archos 605 WiFi Digital Media Player
Archos 605 WiFi Digital Media Player Logo
341 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
Jim Goldsmith
Jim Goldsmith
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
