Question about SanDisk Sansa e250 MP3 Player
Sansa Fuze I charged my sansa last night and used it this morning and it turned off on its own, so i went to charge it again and it will not even turn on now. Wont even show that i am charging it.
  • 8,596 Answers
Probably a hardware/power supply issue (would require a replacement), but you can try my soft fixes:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jul 06, 2008
Can't get sandisk sansa fuze+ to turn on, what do I do
Hold the on/off slider for 30-40 seconds and then release to reset the device. Then try turning it on. Also, sometimes if the battery is low/dead it will take longer than 3 hours to charge up. If it does not turn on after the reset you might try letting it charge for a day or so and try again. If it doesn't work after all of this, it should be returned to where ever you bought it for a replacement.
Aug 13, 2014 | SanDisk Sansa Fuze MP3 Player
Sansa fuze will not turn on
This will happen if the battery is drained below the min. operation voltage.
To bypass the problem = Press and hold the ON button and the Play Button ( >||) for 20 seconds it should override the low voltage and power-up
Jan 19, 2010 | SanDisk Sansa Fuze MP3 Player
Sansa Fuze went dead after charging; dropped about 18'' onto carpet earlier, but saw no problem until after charging.
sansa fuze mp3 players are notoriously pieces of ****. they malfunction randomly, and most of the time, unfortunately, cannot be fixed. i have experienced this first hand. even though it's actually a problem with their software, or the hardware in it. my advice is seek third party repair help.
Dec 29, 2009 | SanDisk Sansa Fuze MP3 Player
Sansa fuze 4g isn't recognized by computer...won't charge, screen only shows "writing" screen when body of mp3 player is pressed together...any ideas?
When i plug my Fuze in the pc, it turns on, but doesnt charge, and isnt even recongnized by my pc. So i cant put anything on it and it doesnt even show up in device manager.
Dec 26, 2009 | SanDisk Sansa Fuze MP3 Player
My SanDisk Fuze was charging and froze its a 8gb
Try holding the power button for 10 seconds to do a soft reset.
Aug 21, 2009 | SanDisk Sansa Fuze MP3 Player
Sansa fuze 2gb wont turn on or charge
Mine did the exact same thing, (Even the going to bed thing) I'm glad you posted your question. Incidentally enough after trying to turn-off and on for ten minutes, I pressed all the buttons a whole bunch to show it my frustration.....then it worked. (?) I don't know why, but I think that the computer going into hibernation or shutting off affected it.
Jun 23, 2009 | SanDisk Sansa Fuze MP3 Player
My sansa screen went white
Try resetting the device by holding teh power switch in the ON position for about 15 seconds, then while it's OFF, slide the power switch DOWN to the HOLD position. Now for the tricky part, let's force a manual MSC connection. Press and hold the center button while plugging in to the USB port. Let us know if the screen lights, and the battery begins charging in this mode. If it's charging, let her charge for a while to give the battery a chance. Then, open a Windows Explorer window. I like to use [Windows key] + E, or go to My Computer. See if the Fuze appears under "devices with removable storage". If it's communicating, you have the options of formatting the device and reloading the firmware.
Jun 06, 2009 | SanDisk Sansa Fuze MP3 Player
Sansa fuze player
I kept on searching everywhere and I finally found a link after I had gone too sansa website a few times.The link was right I downloaded save it and I put the video on my player today. Thanks a lot.
Jul 22, 2008 | Audio Players & Recorders
Sansa Fuze not working anymore
My friend give me a sansa mp3 player BB0703UBB. When i charge it in my PC and i forgot to unplug sansa mp3 player BB0703UBB after half hour i plug it. But the power is not working. i cannot open and play it anymore. I try to insert it on my PC but then it says unknown device. HELP!
Jul 17, 2008 | Audio Players & Recorders
SanDisk Sansa e250 MP3 Player Logo
60 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
