Question about One For All URC-3021 Remote Control
Blocking a channel
How do i block a channel from children viewing it
    Sergeant:
    Champion:
  • 417 Answers
You Need To Change The Parental Control
Posted on Jul 06, 2008
How to reset a password
Set up blocking schemes to block specific channels, ratings, and external viewing sources.
A password is required to gain access to this menu.
Setting up Your Password
For USA
LOCK Move Enter
Lock System : Off
Set Password
Block Channel
Movie Rating
TV Rating-Children
TV Rating-General
Downloadable Rating
Input Block
For Canada
LOCK Move Enter
Lock System : Off
Set Password
Block Channel
TV Rating-English
TV Rating-French
Downloadable Rating
Input Block
Close
Enter Password
Select LOCK.
1MENU
ENTER
Input the password.
2 Enter the password as requested.
The TV is set up with the initial password
"0-0-0-0".
Hope this helps
John
Sep 17, 2011 | LG 42LG50 42 in. LCD HDTV
Tip
Toshiba 42HP95 Channel Block Reset
Toshiba 42HP95 Plasma TV Channel Block Reset
Would you like to bypass, defeat or reset your Toshiba 42HP95 Plasma TV channel block?
Have you forgotten your channel block PIN, passcode or password?
If you forget your channel block passcode, you can view the locked channels without entering your password:
  • When your PIN is requested, simply press RECALL four times withing five seconds.
  • The channel block passcode will be reset and you can enter a new PIN if desired.
I hope that helps.
________________________________________
Download Toshiba 42HP95 Plasma TV Manual
on Jul 03, 2010 | Televison & Video
Tip
Toshiba 50HP95 Channel Block Reset
Toshiba 50HP95 Plasma TV Channel Block Reset
Would you like to bypass, defeat or reset your Toshiba 50HP95 Plasma TV channel block?
I hope that helps.
Download Toshiba 50HP95 Plasma TV Manual
How to set parental block on tv so it cant even be turned on Tv is a proscan 47lb45h
DTV parental controls include blocking of unrated programming, channel-by-channel blocking and blocking by content rating levels. You have control over what information gets displayed on the Electronic Program Guide, and can unlock controls for a particular time frame.
Initially your service uses default settings, which allow access to all programs. Ratings are set from the Main Account. Subaccounts (individual user accounts) can be set up for household members (toddlers, tweens and teens), based on their viewing needs. Once Parental Controls are activated, an icon will appear in the navigation menu.
Parental Control Settings from the Main Account
Press the Menu key on your remote control and arrow to the Settings tab. Press OK on your remote. Enter your Password, arrow to OK and press OK. Arrow to the Parental Control section and highlight Change, press OK. This takes you to the Users tab. Here ratings for Movies, TV and Content are set up along with Unlock Timeout. Each rating has a drop-down menu for age appropriate programming. The Content ratings work in addition to the Movie and TV ratings and let you block unwanted content such as *** or violence.
Tip: The Unlock Timeout lets you deactivate the Parental Controls for 30 minutes to 3 hours and after that time will automatically reactivate parental controls.
To choose your Movie settings, press OK and a drop-down menu will appear. Select the desired rating and press OK. Next you can do the same for TV Ratings, and Unlock Timeout. Arrow to Content Rating. Select the ratings you want to block, press OK and a checkmark will appear. To remove the content rating press OK again. Ensure that the Enable Parental Control box is checked. If it is not checked, Parental Control is not enabled. Arrow to Done and press OK, which takes you back to the Preferences tab. Arrow down to OK and press OK. You will be returned to your program.
NOTE: Any Parental Controls set will only take effect if you check the Enable Parental Controls option on the Main Account and exit the Preferences tab via the OK button. Otherwise, the default setting is in effect, allowing the viewing of all programs regardless of settings for individual user accounts.
How to set up Subaccounts (Individual User Accounts)
Press the Menu key on your remote control and arrow to the Settings tab. Press the Select key on your remote. Input your Password, arrow to OK and press the Select key on your remote. If the electronic keyboard appears, just press the Select key on your remote again. Arrow to the Users tab and press Select. Arrow to Add, press Select. Arrow to New Login and press Select to display a digital keyboard. Use your remote's Arrow keys and the Select key to enter a Login Name. When done, arrow to Enter on the digital keyboard and press Select. The new Login Name will appear in the box.
Arrow to and choose the desired Movie Rating for this User and press Select. Now, arrow to and choose the desired TV Rating and press Select. Arrow to and enter New Password, Select. Arrow to Confirm Password and reenter what you typed in the New Password field, Select. Arrow to Allowance. If you would like to set a spending limit for Pay Per View events and movies, enter the amount and press Select. Arrow down to Submit and press Select. To restore TV viewing, press the Menu button on the remote twice.
TVY
All Children
This program is designed to be appropriate for all children. Whether animated or live-action, the themes and elements in this program are specifically designed for a very young audience, including children from ages 2-6. This program is not expected to frighten younger children.
TVY7
Directed to Older Children
This program is designed for children age 7 and above. It may be more appropriate for children who have acquired the developmental skills needed to distinguish between make-believe and reality. Themes and elements in this program may include mild fantasy violence or comedic violence, or may frighten children under the age of 7. Therefore, parents may wish to consider the suitability of this program for their very young children.
TVY7FV
Directed to Older Children - Fantasy Violence
For those programs where fantasy violence may be more intense or more combative than other programs in this category, such programs will be designated TV-Y7-FV.
TVG
General Audience
Most parents would find this program suitable for all ages. Although this rating does not signify a program designed specifically for children, most parents may let younger children watch this program unattended. It contains little or no violence, no strong language and little or no sexual dialogue or situations.
TVPG
Parental Guidance Suggested
This program contains material that parents may find unsuitable for younger children. Many parents may want to watch it with their younger children. The theme itself may call for parental guidance and/or the program may contain one or more of the following: some suggestive dialogue (D), infrequent coarse language (L), some sexual situations (S), or moderate violence (V).
TV14
Parents Strongly Cautioned
This program contains some material that many parents would find unsuitable for children under 14 years of age. Parents are strongly urged to exercise greater care in monitoring this program and are cautioned against letting children under the age of 14 watch unattended. This program may contain one or more of the following: intensely suggestive dialogue (D), strong coarse language (L), intense sexual situations (S), or intense violence (V).
TVMA
Mature Audience Only
This program is specifically designed to be viewed by adults and therefore may be unsuitable for children under 17. This program may contain one or more of the following: crude indecent language (L), explicit sexual activity (S), or graphic violence (V).
G
General Audiences
The motion picture contains nothing that would offend parents for viewing by their children.
PG
Parents are urged to use "parental guidance", as the motion picture may contain some material parents might not like for their younger children to view.
PG-13
Parents are urged to be cautious. Some material may be inappropriate for pre-teenagers.
R
Restricted
Contains some adult material. Parents are urged to learn more about the motion picture before taking their younger children with them. Generally, it is not appropriate for parents to bring their young children with them to r-rated motion pictures.
NC-17
No One 17 And Under Admitted
Patently adult. Children are not admitted.
Hope it helped.
Jun 02, 2011 | Proscan 47LB45H 47 in. LCD TV
Some channels are block out using 0000 or 9999 dose not help nee to cancel the c9od that in there, help
1. Select Canada V-Chip from the PARENTAL CONTROL menu.
2. Highlight English Ratings or French Ratings and press OK.
3. Determine the rating you want to block.
4. Press the down arrow button to scroll to the rating you want to change.
5. Press the OK button to change its status to block (the lock icon appears and all ratings above the one you selected change to lock). FRENCH RATINGS Go Back 18+ 16+ 13+ 8+ G
Press OK to view/block programs intended for children over the age of 8. V-Chip Movie Rating Limit Set movie rating limits by blocking movies rated above a specified level.
To access the Movie Rating Limit menu:
1. Press MENU on the remote control (the MAIN MENU appears).
2. Select Parental Control.
3. Select USA V-Chip.
4. Select Movie Ratings. Blocking Movie Ratings Once you are in the Movie Rating Limit menu, follow the same steps described for blocking Canadian V-Chip Ratings.
V-Chip Exempt Program Block The Exempt Prgms. option lets you decide if programs that the V-Chip recognizes as unrated can be viewed. Unrated TV programs may include news, sports, political, religious, local and weather programs, emergency bulletins, public announcements, and programs without ratings. The Exempt option applies to both USA and Canadian unrated programs and Canadian programs rated E. 20 Graphics contained within this publication are for representation only.
Using the TV's Features Unlocked All unrated programs are available. Locked All unrated programs are not available.
Nov 08, 2010 | RCA 27V530T 27" TV
Tip
I hope that helps.
on Jul 03, 2010 | Toshiba 42HP95 Television
Tip
I hope that helps.
on Jul 03, 2010 | Toshiba 50HP95 50 in. Plasma Television
How to reset the parental control code - I forgot the code and want to reset with a new one
This is what I found in the instruction manual on this and I posted it here for you. Try using 3355 for the code and everything else listed here. If that doesn't work, try the very last tip which tells you how to do a factory reset and repeat the first step using the 3355 as the code.
Here's the instructions from manual:
Parental Control
Parental Control allows you to block certain channels or programs so children cannot view
programs that are not age appropriate.
To enter the Parental Control menu, you need an
access code. The first time you enter, use access
code 3355. See "Setting an Access Code" on
page 33 for information on creating a new access
code.
You can set the following options to block
content:
• Channel Lock — Blocks selected channels
• Movie Rating — Blocks movies based on their rating (G, PG, PG-13, R, NC-17, and X)
• TV Ratings — Blocks TV shows based on their rating
• Block Options — Turns on or off all your parental control settings
NOTE: You can use Clear All to unblock the channels and programs that you have set.
NOTE: If the Block Control in the Parental Control menu is enabled, all the sub screens in POP (POP1,
POP3 and POP12) mode will be blank
Setting an Access Code m
After you enter the Parental Control menu for the first time, you can set your own four-digit access
code. If for any reason you lose or forget your access code, you can use the default code.
1 In the Parental Control menu, select Change Code.
2 Using the number pad on the remote control, enter a new access code.
3 Select Exit.
Reset the original factory defaults. Press Menu on the remote
control, select Setup, and then select Factory Reset
Jul 28, 2010 | Dell W4201C 42 in. Plasma HDTV
Magnavox child lock help
hello The parental control menu enables
you to limit access to programs that
may contain objectionable material
or are not suitable for viewing by
children. The default access code is
0711
0711.
The following table provides details
about the menu items:
Component Function Range / Options
Lock Enable
Enables the parental control lock. When
enabled, channels with objectionable viewing
content are blocked and can only be
accessed with a password. You can block
channels according to the movie or TV ratings
of the channel’s programs.
Off, On
Movie Rating Helps you block programs based on their
movie ratings. See “Movie Rating” on
page 25 for more details.
TV Rating Helps you block programs based on their TV
ratings. See “TV Rating” on page 26.
Change Code Changes the password for the parental control
lock.
Press the number keys to
change the password.
Reset Resets all channels and programs to their
default factory settings.
regards
shaun
Parental Control Menu
Lock Enable
Change Code
Reset
Back
Main Menu
Sound
Size
PIP/PBP
Parental Control
Channel Setup
Setup
Exit
Press Right to Enter
Press New Code
Off On
TV Rating
Movie
Mar 13, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Our TV Sylvania blocks some progrfams on ch. 51
Go to the TV setup menu and look for the V-Chip settings. Turn it off altogether or if you have children you may want to just raise the block up to MA, R, or X rated programs
Jan 25, 2009 | Sylvania 6427TE 27" TV
One For All URC-3021 Remote Control Logo
23 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
