Canon i560 printer won't print. I've run a nozzle test which confirms I have ink. I can hear it trying to print each line of the document as normal, but nothing prints.
The print head is clogged.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If this not help you need to replace the print head.It's part number now is QY6-0064 because the old QY6-0042 is discontinued.
Double-click print centreicon.
when it opens up, select I560, then click configure.
click I560 then click select
click the down arrow to select test print.
nozzle, alignment etc...
run the tests try resolve the problem.
Was this the problem prior to changine the cartriages? If not check the contacts between the machine and the cartriges. there may be tape, ink, papaer in between.
Perhaps the CMY color heads need alignment. If you have not already done so, run a head alignment from the driver maintenance section. It will print out a page containing several lines and text, and request you select the closest-aligned images. After this is done, do another image print to check for improvements. Normally, the printer uses the black cartridge for text and the CMY inks for images (even for black on photo and specialty paper). So when you are printing normal text pages on plain paper, only the black ink is used. A good check for this would be to print a normal text page, but select photo paper in the driver to trick the printer into using the CMY inks to make a substitute black text page. If this looks ok, then you are having issues other than cartridge alignment.
I have now found the solution elsewhere in the internet: black text only prints on the Canon i560 if selct "normal paper", but not,for instance, if you have "professional photo-paper" selected.
I changed the black ink in my printer, now it will not print everything in black!, I changed it back to the old ink, but still not printing black ink, what do I do?
Hi marc, it sounds like the normal clean has not eliminated the clog you may have in back printhead. I need to know if you refil your own cartridges or not to be specific, but basically you need to remove the black ink cartridge, and clean the printers heads yourself, and right down where cartridge sits wth cotton buds and proper cleaning solution. Wipe the surface of cartridge if it has the printhead attatched (some printers have the printhead on them, some have it on the
cartridge. Replace ink, reset black ink level, cancel the alignment for now, go straight to printing. Print a test page and see how it goes.
