Frigidaire Infinity front load washer This is new out of the box. It has been leveled multiple times, but during spin cycle it walks across the floor taking down items in its path!
  • whdaugherty Aug 02, 2008
    Same problem - the infinity washer vibrates so much it walks - rubber pads do not help - it is perfectly level - it is on sub-flooring not concrete but this is silly!
  • Anonymous May 19, 2009
    AN EXPENSIVE PIECE OF MESS, I HAVE A SMALL CHILD THAT IM AFRAID FOR HER SAFETY BECAUSE IT BOUNCES CROSS THE FLOOR WRECKING EVERYTHING
My washer and dryer is less then a year old and the mildew is awful.Please don`t tell me to leave the doors open to dry the inside, done that from the beginning,ruined clothes with just a touch of bleach to help with the freshness.Ready to send it back.
Posted on Jul 12, 2010
Washing machine stinks fro mildew
Posted on May 14, 2009
    President:
  • 1,462 Answers
Have you removed the transit bolts and any packing. this is the most probable cause
Posted on Jul 06, 2008
  • 97 Answers
There are so many ways to fight mildew, you can try bleach try Clorox HE try eight cups yes 8-cups ,use gloves but first remove the soap,softner and bleach dispenser look in side and clean were dispenser goes and when this is goig on spray drum with bleach as well, use gloves and have plenty of ventilation,after cleaning dispenser area,pour in bleach,use the area were you put detergent area.Now use heavy-duty cycle and hot-water,and let it run after your done wipe rubber seals cut back on softner use softner every other week and use about a tablespoon of softner.thanks i hope this works
Posted on Dec 16, 2009
Maytag washing machine walks across floor during spin cycle
Did you set the back feet before leveling? On most units to set and lock the back feet you need to pull the top towards you so that the back is raised off the floor, then set it down again, this will release the feet and lock then down. The you level the two front feet. After this is done you must make sure your load is balanced. Distribute the items as evenly as you can in the tub. Once it gets to the spin cycle if its walking or shaking a lot, stop it and redistribute the items more evenly in the tub. Also try not to overload the unit or combining many heavy items with few light ones. If this is a new machine, did you remove the shipping locks from the back before using it? They have plastic strips attached to them, make sure they have all been removed, as well as any shipping bolts.
Feb 17, 2015 | Maytag Neptune MAH6700A Front Load Washer
Model MAH9700 - Washer travels across floor in the spin cycle
I suppose that the repairmen would know than I would, but I do know that any washing machine that is not level will walk and vibrate and really shutter on the spin cycle. I would try to level (using a level on the top part of the machine that is flat, if there is such a portion) the machine so that all four feet (pads) are secure with their locking nuts up against the body so that they can't turn and cause the machine to go out of level.
Sorry I can't be of more help.
Oct 12, 2009 | Maytag Neptune MAH9700 Front Load Washer
Vibration during spin cycle - "walking" across floor
dear sir/mam
please check the floor level of your washer by using the spirit level,if there is difference please adjust the level by screwing the legs of the washer,then vibration will be stopped.
Jun 01, 2009 | Whirlpool Inglis IP4400 Washer
Front load washer shakes violently during spin cycle
On something like this you will need to remove the washer wrap to inspect the suspension springs & base assembly. Please see the link provided for accessing the inside of the washer. Be sure the shipping pins have been removed. The tub should float freely.
Apr 03, 2009 | Washing Machines
Whirpool Duet "walking"
Hi, most of the time this can be a simple as a overload that will dramatically shake this type of washer. due to its front load design, it is recommeded to load accordingly to specs. overloading this type of washer will induce walking/excessive vibration during the spin cycle.
Mar 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire front loader walking during spin cycle
Have you made sure that all the shipping bolts and stuff were removed? this happened with our Bosch and we found out we had kept three bolts installed that needed to be removed
Jan 12, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Maytag front loader MAH-3 vibrates. Level & on concrete floor.
THERE ARE SHOCK ABSORBERS IN THIS UNIT,SOUNDS LIKE ONE OF THEM IS BROKEN.HOPE THIS HELPS
Nov 16, 2008 | Maytag EPIC MFW9700S Front Load Washer
LG1812CW Walks During Spin Cycle
The rear 2 legs are fixed. The front 2 are adjustable. There are lock nuts to prevent the adjustment from coming loose. The front legs are to be adjusted to the minimum. While not running if the machine rocks, continue the adjustment. For few clothes there is a half load switch; best the read the manual well before anything. Well if the walking continues, check the rear for any shocks or springs that may hv fallen off during transport. Plug off the wall socket first.
May 28, 2007 | LG WM1812C Front Load Washer
Washing Machines Logo
2,525 people viewed this question
Top Washing Machines Experts
