Dam that backslash
When I turn on my computer the backslash continually repeats it self on the screen. It does not appear to be stuck .When I press it it does not print, but when I let go, it prints continually. Print -I mean the screen is full of backslashes. Not literally printing on my printer. Help
Diane
  • 3,940 Answers
Definitely sounds like a stuck key.
Assuming the system is a portable, you can try this for troubleshooting. Connect an External keyboard and disconnect the cable for the internal one, see if the issue stops. If it does, the innternal keyboard is bad and needs to be replaced
Posted on Jul 06, 2008
Keyboard inserts backslashes when I type
Unless you're fairly technically adept and mechanically inclined, the easiest fix is to replace the keyboard. They aren't that hard to find and aren't all that expensive.
If you don't have a clue how to do this, then your best bet is to send it to a professional that will source out the cheapest replacement keyboard and offers inexpensive international shipping like SuperTech-IT.com
Jun 09, 2012 | Lenovo IdeaPad Z560 Notebook
How to set the timer on the nikon D 90 digital camera
Press and hold the release mode button on the top of the camera (marked with overlapping rectangles), then turn the main command dial (on the back) until the self-timer symbol (one-handed clock) appears on the command panel.
Start the self-timer by pressing the shutter release button.
To turn off the self-timer, repeat the above process to get back to single-frame, continuous low or continuous high mode.
Dec 25, 2010 | Nikon D90 Digital Camera with 18-105mm...
Computer when i turned it on said disk read erroe occured and now when i try to start it in safe mode it just keeps restatring it self
Start up your computer.
Immediately insert your Windows XP install CD. As the computer boots, a boot menu will appear (if you did not insert the CD in time, you will not see the menu; in this event, simply reboot the computer again).
Select the option to boot from the CD. A setup screen will soon appear.
Press the "R" button on your keyboard at the setup screen in order to open the repair console.
5
Type in the administrator account's log in password if you are prompted to do so. If there is no log in password, simply leave the password slot blank and continue. After this step, a command prompt will appear.
6
Type in "chkdsk" (minus the quotation marks) and press "Enter." Allow the operation to run.
7
Type "Exit" (again, minus the quotation marks) when the operation is complete, and press "Enter." If your computer boots correctly, great! If not, move on to the next step.
8
Reboot and repeat Steps 3 through 5.
9
Type "fixboot" (minus the quotation marks) and press "Enter." Once it is complete, repeat Steps 7 to 8.
10
You might need to reinstall your operating system.
Thanks.
Oct 22, 2010 | Dell Computers & Internet
The calcutor doesn't turn on from the first time. It takes too long to turn on and at random. Also the soft keyd don't work. I try to set the modes but when I press shoose nothing happens.
The following testing procedure valid for the HP 48G should work for the HP48GX. If any the tests fails the calculator requires service.
Make the calculator perform a
Self test.
  1. Turn calculator on
  2. Press and HOLD the key [ON]
  3. Press and release the key with "E" to its right (the one before last in first row)
  4. Relaese the [ON] key.
It tests the RAM and ROM. You will see various patterns on screen. Afterwards you should see
IROM OK,
IRAM OK,
HP48GX OK
The self test will continue repeatedly until you perform a
System Halt
  1. Press and HOLD the [ON] key
  2. Press and release the "C" key
  3. Release the [ON] key.
The empty stack should appear.
If you do not see IROM OK and IRAM OK, the calculator requires service.
If the above procedure is successful, you may want
to test the keyboard.
  2. Press and HOLD the [ON] key
  3. Press and release the "D" key.
  4. Release the [ON] key
  5. Press and release the "E" key. KBD 1 should appear on the top left corner of the screen.
  6. Starting at the upper left corner of the keyboard, and moving Left to right, press every key in sequence. If you follow the sequence and the keys are functioning properly you should hear a hight pitch sound at each press.
  7. If everything is OK, when you press the last key (+) the screen displays KBD 1 OK.
To exit the keyboard test proceed as described above under System Halt.
If you follow the proper sequence and a hexadecimal number appears after pressing a key, the calculator requires service.
Hope it helps.
Sep 23, 2009 | HP 48gx Calculator
Have a 48GX that stopped working, placed new doubleA batt no response... Note a wird meshed blue line at the center of the screen... Thx jsd
The following procedure valid for the HP 48G should work for the HP48GX.
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Sep 15, 2009 | HP 48gx Calculator
The #3 key sticks and won't show on the display
Try the following procedure (valid for the HP 48G should work for the HP48GX.) If any of the tests fails the calculator requires service
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Jun 30, 2009 | HP 48gx Calculator
Dam that backslash
The \ key appears to be stuck. The keyboard is about $20 part and can be purchased on EBay with ease. Takes bout 15 minutes for a novice to install. The keyboard may resolve the touchpad issue too.
If the touchpad is still erratic after the keyboard is replaced, Flash the BIOS to latest version available and see if any change. If not the palmrest assembly will need to be replaced (About an hour job) or use an external mouse
May 31, 2009 | Dell Inspiron B120 Notebook
Cant turn off panasonic PIP
To turn off the "stuck" pip on a Panasonic tv without a remote, turn off the tv. Then hold down the "Action" button on the front of the tv and press the power button. This will activate a reset and self check of the systems and voila! The pesky pip screen will be gone! This is on an approximately 10 year old regular crt "CT-xxxxx" series tv.
Jun 12, 2008 | Panasonic CT-36D32 36" TV
Computers & Internet Logo
370 people viewed this question
David Payne
David Payne
