Question about Hotpoint 24 in. DWF33 Built-in Dishwasher
Drain Hose How do I remove this and put in new one. I am afraid that I will break the connection at the base of the machine.
    President:
  • 1,462 Answers
Tilt machine back and remove bottom plate. drain hose is connected direct to drain pump
Posted on Jul 06, 2008
Our WM2016CW machine's drain hose has a wire mesh filter on the end of it. The drain hose then is attached to a drain pipe which used to be connected to an old sink (no longer there). Is this mesh
This is not needed, It has been put in place maybe because of a tendency to get blockages in your drains? These machines break up the particles a lot to assist in removing them and resulting in less pump blockages so what used to collect in older machines pumps now goes down the drain.
Mar 05, 2012 | LG WM2016C
Will not drain water it might be clogged with lint
Most likely lint, or paper lodged in the drain pump. The pump is easily accessible at the base of the machine. After unplugging the machine, put down a towel or blanket and tilt the machine forward so it rests on the front. You will see the drain hose connected with a solid clamp. Remove the clamp and pull the hose off. You should see another "mounting" screw that holds the drain pump in place. Unscrewing this screw should allow you to remove the drain pump for inspection.
Once out, most debris can be cleared with a small flathead screwdriver. Once you are sure the pump is clear, reassemble and turn the machine on. In almost every case, the machine will function normally again.
NOTE: If the drain pump is clear, the problem may be either a clog in the relief tube (where the hose empties the waste water to) or a bad drain pump all together.
Sep 06, 2011 | Fisher and Paykel Washing Machines
How do I change the waste hose on a Bosch Dishwasher Model Number SMS53E12GB the existing hose has been crushed by the base of the machine. I cannot see how I can get to the connection point at the base of...
It is not the easiest thing to do,here is what you have to do;
turn off power supply and water to the dishwasher
remove screws mounting d/w to counter top
remove lower panel
disconnect water and power from d/w
lower legs
pull out from under counter
remove panels covering door hinges
remove linkage from door spring to door hinge
remove the Torx screw securing tub to base frame in the front&rear
pull on base frame to seperate tub from frame about 8-10 inches
remove drain hose from drain pump/install new hose
reassamble in reverse order
Good luck,
Gene
Aug 06, 2011 | Bosch Dishwashers
I need to replace the drain valve at the bottom of the tank,can I buy a replacement valve? Are they all the same size?
There are 2 sizes; 1/2 inch and 3/4 inch. Remove the old one after draining the water heater and shutting off the water supply then take your old one to a plumbing supply outfit like George Morlan's. Make sure you wrap the new threads with teflon tape at least 3 wraps while holding the spigot in your left hand so the tape won't come off as you install the spigot. Good luck!!
Dec 15, 2010 | RELIANCE ELECTRIC WATER HEATER
How to remove waste hose from machine?
1 Turn off the circuit breaker that controls the dishwasher.
2 Open the dishwasher door. Locate the two small screws holding the bottom valance trim piece. Remove the screws and the valance, revealing the lower pump assembly and drain-hose connection.
3 Remove the hose clamp. Disconnect the drain line by pulling the hose.
4 Find the other end of the drain line under the sink; it is connected to the drain tail piece or the garbage disposal. Remove the hose clamp and disconnect the drain line. The dishwasher drain hose is now disconnected at both ends.
5 Pull the dishwasher drain hose into the sink base through the hole between the dishwasher and the sink base.
6 Take the dishwasher drain hose outside or to a wash sink. Run hot water through the line to clean and unclog it. When you see water running freely through the hose, then it is clean. If the hose cannot be cleaned, replace it with a new drain hose of the same size and length.
7 Feed the clean dishwasher drain hose back to its original configuration. Reconnect both hose clamps. Reinstall the valance, turn on the circuit breaker and test-run the dishwasher.
Nov 29, 2010 | Smeg CSU2001 Built-in Dishwasher
Leaking water heater, the spout on the side is dripping water all over the basement floor.
You can try fixing this problem by putting a garden hose cap over end of valve.
Cap has a washer.
If leak is bad, you need to replace drain valve.
If the valve is brass, then drain water heater and put a wrench on valve and unscrew.
Buy replacement brass valve from plumbing supply or Lowes-HomeDepot
If the valve is plastic, then expect it to break off when trying to remove.
If it breaks off, then you can carefully drill out the stem, and then burn it out with a torch and use a 3/4" pipe nipple to try to cut a new thread.
If water heater will not drain ... put washing machine hose on water heater valve - run water hose between washing machine hose and outdoor spigot and turn on water for 10 seconds to break open clog inside water heater.
Oct 25, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Maytag MAV4755AWW. Water remains in clothes after spin cycle.
Check the drain hose for kinks and clear it from any clogging. If no clogging or kink is found, drain the water manually.
Remove the rear access panel to access the drain pump. Press the hose clamps and move it away from the pump. Remove the hoses from the pump and drain the remaining water from the tub drain hose into a shallow pan.
Lay the machine on its side on a cushioned surface to allow easy access and removal of the drive belt.
Remove the three screws securing the drain pump to the base of the machine. Check the pump impeller for any damage and clear it from any debris that may be preventing it to pump the water out. Replace the drain pump (part #35-6780) if the impeller is damaged. Secure the new drain pump to the base of the machine with the three screws and reinstall the drive belt and the rear access panel.
Note: Disconnect the machine from the power outlet before servicing to avoid the hazard of electric shock.
Feb 22, 2010 | Maytag MAV4755A Top Load Washer
Water wont drain during spin
Check the drain hose, drain pump and the drain sump for any object that might be blocking the passage of water.
Drain Problem Troubleshooting Guide for Frigidaire Front Load Washers
  1. Safety first. Unplug the machine.
  2. Remove the drain hose from the drainage.
  3. Cushion the top rear edge of the machine with a thick cloth then lean it back against the wall.
  4. Remove the two screws holding the front access panel to the base of the machine.
  5. Pull the front access panel down and out.
  6. Lay a towel under the drain sump to prevent flooding the base of the machine.
  7. Remove the drain sump from the tub by loosening the clamp holding it..
  8. Remove the drain hose from the pump by loosening the clamp holding it.
  9. Remove the two screws holding the pump housing to the base of the machine.
  10. Disconnect the wiring harness from the pump motor terminals then pull the pump out of the machine.
  11. Remove the drain sump from the pump by loosening the clamp holding it.
  12. Check the drain sump and the drain hose for any clogging and clean it.
  13. Replace the drain pump if the drain hose and drain sump are not clogged. Install the new pump on reverse of the removal steps above.
Feel free to ask for further assistance if necessary.
Jan 23, 2010 | Frigidaire ATF6000ES Front Load Washer
OE error
First, open the small access door at the lower left on the front of the machine. Use the small hose to drain the remaining water out of the machine. Then, unscrew the big knob to remove the filter and clean out any obstructions there. If you have the "OE" error code, which is really a "DE" (drain error) code, and you have checked the filter and it is clear, then most likely the impeller has come off the pump motor shaft. You can disassemble and push it back on, but it will come off again. I don't know if some type of adhesive would work, but I just replace the pump motor.
Drain water from small drain hose (or by removing filter) Remove the screw in the plastic recess by the filter, then use a putty knife on the left or right side to pop out the recess. Remove two more screws holding pump body to front frame of washer. Pull washer about 18 inches away from wall and tilt it back to lean against wall. You can reach through the large hole in the bottom of the washer base to access the pump. There is a plastic locking tab holding the pump body to the plastic washer base, but don't worry if you break that, as the screws (removed earlier) will hold the pump back on just fine. Pump motor is held onto pump body with three more screws. Replace pump motor with a new one and reassemble. On a difficulty scale of 1 -10, this one might rate a 5.5 or a 6.
May 01, 2009 | LG WM2688HWM TROMM SteamWasher
Blocked drainage hose in Fisher and Paykel top dishdrawer DD603
Hello there..
How do you know the hose is blocked at all? It's rare for that to happen, I work on these machines daily as I am a Factory Authorized tech. You need to be careful in your approach to this, that is an expensive machine and it can be damaged by improper service procedures.
For starters, there is a flap valve on the end of the drain hose that would prevent you from introducing any sort of pressure backwards into the machine via the drain hose. For example, if you took and tried to blow air thru the drain hose outlet end, you would force that flap closed and create pressure in the hose. Also putting caustic drain cleaning substances is very, very bad for your machine and can cause some serious damage.
I will be happy to try to assist you, but let's start at the begining, shall we? What prompted you to conclude that the drain hose is 90% blocked? The first thing you should do is take out the rack, wash arm and tha large stainless steel filter plate. Next, pull the rotor up and out of the pump base (none of these procedures require tools) and make sure the grey impeller is not "freewheeling" or has become detached from the rotor shaft. The blue wash impeller on the top and the grey drain impeller on the bottom must be "one to one" meaning they are firmly connected to the shaft of the motor and turn together.
Next, check the tube or passageway in the drawer between the sump (where that small removeable filter screen is) and the pump's sump area (where you pulled up the rotor)
If you have any blockage, it will be in that tube.
There is some glitch here where I do not get notified of response to questions, so I will check back to this post.
Dec 14, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Hotpoint 24 in. DWF33 Built-in Dishwasher Logo
193 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
