Fijutsui air conditoner
Our system is flashing the timer green seems to be stuck in that mode and we can't get cool ai to pump out.
    Problem Solver:
  • 14 Answers
We had a similar problem. The timer light would blink 3 times, pause, then blink 3 times again, pause, and so on. The fan was blowing lots of air out, but the air was not cold. The operation light was off.
The technician came and fixed it for free, since it's actually easy to fix. He went to our circuit-breaker box, and cut power (from the box) to the air conditioners for 30 seconds. Then, he restored power - problem fixed!
It's apparently because the air con goes into a "safety" mode when there's a power surge.
Posted on Dec 16, 2008
    New Friend:
  • 14 Answers
Turn it off at the fuse board for 5
minutes then try it again This will clear the error, if it goes back
into error mode youll need to call a
tech support.
Posted on Jul 15, 2013
Fujitsu asta24jcc timer 2 green flashes
The indoor unit has the problem and it's the air thermistor. You need to replace it.
Jan 01, 2014 | Heating & Cooling
Friedrich ductless heat pump will not start up.
Did you check to see if the compressor is running? Check out start relay/capacitor.
Sep 21, 2017 | Heating & Cooling
Timer light on fujitsu heat pump flashes not heating
the light flashing indicates there is a problem. you can try reseting the system by turning the power supply off and back on again 30 sec later, if the same thing happens you need to count the number of light flashers and that relates to a fault code
Jun 20, 2012 | Fujitsu Heating & Cooling
Indoor unit runs ok outdoor unit compressor and fan do not start
Hello rfrizzell,
My unit is giving me the same alarm. If you have found the solution, please email me at
Thank you very much.
Mar 14, 2009 | Friedrich MR18Y3F Split System Air...
Ac not cooling
Try turning the main isolator off for 10 minutes to reset the system. If it doesn't clear the error, count how many times the light flashes which will give you the error code.
Oct 09, 2017 | Fujitsu Heating & Cooling
Coleman 15k will not come on
Here is the troubleshooting guide for your unit. Hope this helps.
Symptom Remedy
1. Remote does not turn on system
- Check and replace remote batteries if the display fades while
any button is activated or no display is present. - Point remote towards IR receiver during transmission. 2. System does not turn on, no green LED & no beep
- Check wiring. (see "installation instruction")
- Check modular cable to receiver.
- Check diagnostic LED status in the upper unit control box.
3. System does not turn on even when receiver green LED is on.
- Low or over voltage condition, check diagnostic LED status in the upper unit control box.
4. Fan runs but no cold air.
- Evaporator temperature sensor reaches low limit, defrost mode.
5. System runs continuously in the cool mode
- Remote was set for "I feel" mode and is left in a heated environment (sun etc.)
6. System runs continuously in the heat mode
- Remote was set for "I feel" mode and is left in a cool environment
1. Diagnostic LED (green)
(Note: Located on the control board in the upper unit control box.)
a) The LED is on when the 12VDC is adequate and communications are
b) The LED is flashing fast and steady when in the freeze mode. Evaporator has frozen and the freeze proctection switch is engaged.
c) The LED is flashing slow and steady when the delay on break timer is
d) The LED is flashing 1 cycle on and off for one second with high or low
12VDC. Check the incoming 12VDC power for OK.
e) The LED is flashing 2 cycles on and off for one second with a
communication problem. Problem with the control board in the unit and the remote.
Hope this helps.
Rate me Please!!!
Jul 29, 2008 | Coleman Mach 15 Air Conditioner
Air conditioner not working
unplug it for few minutes and then restart it. This shold reset the timer.
Jul 07, 2008 | Fujitsu Heating & Cooling
Heating & Cooling Logo
833 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
