Question about Maytag 23 cu. ft. Side-by-Side Refrigerator MSD2356
Maytag refrigerator clicking
Not cooling, constant click. both fridge and freezer are not cooling. fan is blowing, but wont lower tempature. Any suggestions out there. 2003 model.
  • golden2401 Jul 16, 2008
    Noticed my kenmore side by side leaking, only to discover the compressor not kicking in. Compressor was very hot to the touch. Took the start switch out and then put it back, let the compressor cool and then plugged the fridge back in. The compresor went on for 15 seconds and then I heard the start switch trip. How do I know if it is the switch or the compressor not finctioning??
  • 481 Answers
It sounds like a bad:
  • ·       start switch (on the side of the compressor) or
  • ·        compressor itself
the start switch clicks  off usually when the compressor is pulling too many amps or the compressor is overheating. if the compressor is not even running then its probably not overheating.
so either the compressor is pulling too many amps (bad compressor) or the start switch is bad and cannot handle the amps required to start the compressor.
Posted on Jul 06, 2008
My kenmore 253 upright freezer/fridge is not cooling the fridge part correctly. It's cool but not cool enough to keep the food fresh. The freezer works well sometimes. And sometimes it seems that it's not...
Try this test. Set a window fan behind the fridge to constantly blow air across the lower coils at the floor. If the fridge works well after a while of this, then the lower fan on the fridge needs replaced. Sometimes though, after a while, the fan will finally start working again because the cycle has finally corrected itself with the test. Leave the window fan run on low for a few days before removing it. The hum you hear is the compressor moving the coolant and is supposed to do the hum sound. That's good. Now once the fridge is working, and you still have a good freezer section and not cool enough below in the fridge for you, there is a knob that sets the cool lower by opening flaps under the freezer to let more cold down to the fridge area. Set this knob to colder and the flaps will open more.
Nov 11, 2014 | Refrigerators
Maytag MSD2454GR
You may need to recharge the condenser unit.
Jun 16, 2008 | Maytag MSD2454G Side by Side Refrigerator
Maytag RSW2700 - S/N R923415 ... has stopped working and is blowing circut. When cirdut reset ,, fridge plugged back in .. blows circut. I have lowered the temp setting, unplugged everything else but the...
Hi, The compressor is not starting and blowing the circuit...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 19, 2011 | Maytag 25.6 Cu. Ft. Side-by-Side...
The bottom freezer works but the refrigerator will not get cold. model# MFF2557HES
Sounds like airflow fan needs to be replaced. Most fridges use a small fan that blows air from the freezer to the refridge. If that fan fails you get working freezer and non cool fridge.
May 06, 2011 | Maytag MFF2557HES Stainless Steel French...
The fan is running in the freezer constantly and frost is building up on the walls of the inside of the freezer. The fan is making a loud buzzing noise.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 28, 2010 | Maytag Refrigerators
My fridge wont get cool
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Jul 12, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
Top Freezer won't freeze--blows 50 Degrees constantly!!!
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Check the fans especially the condenser fan. the noise you hear is probably the klixon cycling because the compressor is hot. You can put a fan blowing on the condenser coil and see if this helps.
Good Luck,
Gilsh
Nov 28, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Maytag mff2557hew fridge not cooling. Freezer ok.
Sounds like the Freezer Fan is wearing out or is worn out. This fan problem is very hard to detect. The reason is that when the motor is starting to wear out the fan will spin, but at a much lower rpm. This is enough to keep the freezer cold. but will not ciculate enough air thru the freezer and the refrigerator to prevent freezer from and refrigerator from cooler. The cost to repair/replace this fan is a minimum of $300.00
Jul 27, 2009 | Maytag MBB2256G Bottom Freezer...
Fridge not cooling,compressor wont kick in
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
fsdgj
Jun 02, 2009 | Maytag MZD2665HE Stainless Steel Side by...
Refrigerators Logo
383 people viewed this question
Top Maytag Refrigerators Experts
Richard Roth
Richard Roth
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
