I have new Prolectrix turntable USB Direct and tone arm leaves record before end of playing record. Hope you can help. Thanks
  • voorhees Nov 20, 2008
    Just bought one of these today and it has the exact same problem, stylus lifts up before end of album/single etc
I have the same problem and i can't find this black-head screw.
can you help thanks.
Posted on Sep 19, 2012
  • Les S Nov 19, 2012
    Me too. I have the same problem and can't find the blak headed screw. Anyone else any ideas
Turning the return position adjustment (the flat black-headed screw next to the tone arm) a little clockvise will probably fix your problem.
Posted on Dec 17, 2010
My turntable a Crosley CR49 is about 14 years old. It plays just fine, but have to manually reset, clicking the tone arm after every record I play, either 45s or 33 1/3. How Can I fix this?
You will need to get to the underside of the turntable. There you should find that the arm when it gets to the centre of the record it will push on a switch. This switch might be out of position or just get stuck by grease or dirt. Correcting it should solve the problem.
Dec 08, 2015 | Crosley Audio Players & Recorders
THE TONE ARM ON MY ROCKOLA 459 SLIDES OVER THE RECORD WITHOUT PLAYING.
Hi
It sounds as if the tone arm has become unbalanced. Make sure the turntable is on a firm flat horizontal surface and at the opposite end of the arm from the needle there will be a weight and a means of altering the position of weight on the tone arm. This weight keeps the needle on the record but only lightly when positioned correctly. If positioned too far from the pivot post the needle will as you have experience skip virtually straight across the record. You need to adjust the weight so that the needle just sits in the groove and plays without being too heavy. It is best to use a record you are not too worried about for this testing as the test record can sometimes get scratched.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 11, 2014 | Audio Players & Recorders
How can I stop the tone arm from returning too early on smaller records?
Type Crosley Model # of your device user manual " into search engine and it will show sites to get manual. In it there might be a way to help you
Jun 14, 2014 | Crosley 0187SST Turntable
In my DENON DP-300F tone arm don't come back after playing record. It just stays in the end of record? How can i fix it?
A lot of decks don't actually do that anyway. But if it previously did this then it's probably a mechanical problem. Removing the bottom of the turntable might show up the cause of the problem.
Dec 08, 2012 | Denon DP-300F Turntable
Denon DP-297 Turntable Tone Arm Skating
There should be a weight on the end of the arm, this needs to be adjusted. Some have numbers on them, increase the number shown. To get it to work right you will have to do it by trial and error. Increasing the weight in small steps, then playing a record. The trick being so it stays in the groove, but not too much so it rumbles on the sound. You will need to repeat the process several times till it sounds right and stays in the groove.
Jan 10, 2012 | Denon DP-29F Turntable
I have an old Califone 1400 all records skip new needle
There's not enough pressure to keep the stylus down in the grooves. Increase the weight (on the end of the arm).
Feb 10, 2010 | Audio Players & Recorders
My prolectrix usb turntable won't play properly
i also have the same problem, im sure its something to do with the tone arm, like at the start of playing a 12'inch you have to hold the arm at the end of the vinyl for 5 seconds, have i answered my own question, i'll let u know ......
Jan 06, 2009 | Audio Players & Recorders
Tone Arm skips past first song
Hello, A. Do not try to close the case when there is a record inside!! The fact that the turntable cannot do this is not a design flaw--you'll be hard pressed to find a portable turntable that can close with a record inside because if you were to pick up the player with one inside, it could easily slip off of the spindle and scratch against the sides of the player.
B. Are you using the cueing lever to lift the tone arm before you place it on the record? Read the instructions to see where the cuing lever is (it's a little switch on the right side of the tone arm). When you lift it, the tone arm will lift up and allow you to position it wherever you want on a record, then you depress the lever to make the tone arm touch the record and being playing.
I hope that helps!
Jan 04, 2009 | Crosley CR249TA Turntable
NSM Hit120 Jukebox.
there is an opto sensor the gets blocked when the tone arm is at the end of the song. It looks like a black u mounted on a circuit board. The flag that interupts the sensor is on the tone arm. The opto must be dirty so it thinks it's at the end of the song and continues to the unload sequence dispite the tone arm having just started playing.
Jan 03, 2009 | Audio Players & Recorders
Sony PS-LX500 Linear tracking turntable
I think it's kind of cheap to ask someone to pay $10 for an answer to one question. Sheesh!
I haven't gotten the answer yet, but a local stereo store pointed me in the right direction. Thanks anyway.
Regards,
Tom
Sep 19, 2008 | Sony PS-LX250H Turntable
518 people viewed this question
 Grubhead
Grubhead
