Question about Miele Novotronic Premier 500 Front Load Washer
How to fix a Miele W1213 Touchtronics washer when the intake and drain light is blinking? power for drain motor is only 20V drain motor not working,but I am tested with 220V end is o.k.
    New Friend:
  • 128 Answers
Unfortunately you need a Service Rep out there to check the electronics - how old is the machine? - Warranty? the drain pump should be 220 or 120 depending on the model.
Posted on Nov 30, 2008
Miele W1213 intake, drain and 3 - - - faults
Have had this since 2007 or 2008. Pain in the backside.
Fixed it by:
Cleaning drain.
Unplugging from power.
Tilting forward to drain water for 1-2 mins.
Made sure that the clear plastic light ***** in the rubber opening which located at the top was tight as it tends to get loose if you have an off-balance load.
Plugged power back in.
Boom, she started up.
This is a great washer/dryer, but it's expensive to fix if you need a repairman and it's a bit of voodoo if you need to do the above.
HTH
Nov 10, 2011 | Miele Touchtronic W1213 Front Load Washer
Miele Touchtronic W1213 Front Load Washer: The washer keeps adding and then draining water continuously. One time, the cycle ended and the machine continued to add water and drain endlessly....until I...
hi - If I remember correctly this particular series had a time related sequence built into the programme, whats happening is the timer has picked up the false readings when the pressure activates the switch.
Suggestions to look into - leave power off & turn water back on - does water run into the machine (faulty valve); turn power on initiate a cycle water runs, then turn power off - is water still running? (faulty valve)
From experiences on the field, theres a slim chance that the pressure tube has a hole in it from the vibrations over time. This effect will not create enough pressure in the tube to activate the pressure switch, the only other problem would be the pressure switch itself.
May 17, 2011 | Miele Touchtronic W1213 Front Load Washer
Used too much soap...miele flooded the floor....drain fault buzzer blinking what do I do?
by using too much detergent the float for water leaks inside the unit would have lifted and triggered the light to light. to clear the fault have some towels around the front of the unit on the floor and gently tip the unit forward and allow the water to escape. the float will drop down and you will be able to use the machine again.
any remaining water in the unit will just dry up. no damage would be done it happens all the time.
May 02, 2010 | Miele Touchtronic W1213 Front Load Washer
Miele frong load washer water will not drain, what do I do
Check the hose going to and from your pump which is located on the bottom of your machine. You prob ably have a underwire preventing ytour pump from spinning.
Jan 14, 2010 | Miele Touchtronic W1213 Front Load Washer
W1213 Touchtronics intake and drain light is blinking
Foam has probably got into the logic board, and a new board is probably needed. Sorry !
Feb 02, 2018 | Miele Touchtronic W1213 Front Load Washer
G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Aug 11, 2008 | Miele 24 in. G665 Built-in Dishwasher
Miele
Clean the drain by opening the door on the bottum left.
Use the yellow plastic thingy in the front of the soap drawer to do it.
You can open the machine door by pulling the yellow tag in the bottom door.
Drain the water through the filter, clean the filter and close.
Then unplug the machine and tilt it forward by about 1 foot until you see water coming out of the bottom (put towel on floor).
Plug back in and voila!
I do think that this machine is a major pain. No spin cycle and this kind of stuff to go through. Anyone want to buy mine?
Dec 24, 2007 | Miele Touchtronic W1213 Front Load Washer
Miele Novotronic Premier 500 Front Load Washer Logo
431 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
