I was cleaning the keyboard of the computer. When I had finished the keys were not typing correctly. It appears that the letters and keys do not correspond. Eg. When I type P an A comes up on screen. How can I fix this?
  • 19,396 Answers
That means a broken keyboard, if you used liquid try drying keyboard with cold hair using an hairdryer. If it is a desktop buy a replacement keyboard, as it is quite an inexpensive part.
Posted on Jul 06, 2008
I can't correct my password and get into my computer--
keyboard layout is as follows.
TOP ROW: QWERTYUIOP
MIDDLE ROW: ASDFGHJKL
BOTTOM ROW:ZXCVBNM
If you're saying you just can't see the keyboard keys, that should help. If it doesn't, I suggest getting a hold of a USB keyboard other than the malfunctioning one you have now.
May 13, 2014 | Acer Computers & Internet
The "v" key is malfunctional. It does not input if I key it alone. The letter appears when I type a word with the letter v in it, but the spelling is wrong. It shows up after three letters or so. Sometimes...
Is this a laptop, phone, or a pc keyboard?
If it's a PC keyboard you might be able to pop the key out and clean under it. I have went as far to clean PC keyboards in the dishwasher. (low heat, no soap, no high temp dry... and then shake all excess water out... and let dry for a week or two.. before you plug it back up.) But do this at your own risk.
If this is a phone, and it is on a touch screen, then try going into settings and changing from samsung keyboard to default android keyboard.. or vice versa.
Sep 25, 2017 | Samsung Computers & Internet
How to tell if caps lock is on
Some keyboards will have a light that goes on when caps lock is turned on
Unlock the Caps on Computers
The All-Caps or "Caps Lock" function causes all letters to appear as capital letters when typing into word processing documents, emails or other files.
This is convenient when needing to type numerous capital letters or All-Caps phrases, as you do not have to hold down the "Shift" button with one finger as you type the words.
When All-Caps is stuck and does not respond to the "Caps Lock" keyboard button, a simple procedure overrides and shuts down the function.
Open a word processing program.
Press the "Caps Lock" button located on the left side of the keyboard to turn Caps Lock off. Type inside the document.
If lower case letters appear in the document, Caps are successfully unlocked.
Proceed if the text is in All-Caps.
Hold down "Shift" on the keyboard. Press the letter "P."
A lower case "p" appears in the document. Release the "Shift" button.
Type the phrase "rint" directly after the lower case "P." The word "pRINT" is now in the document, and the document cursor is after the phrase's "T."
Press "Enter" on the keyboard.
The cursor goes down one line and "pRINT" becomes "Print." The "Caps Lock" function is turned off.
Restart the computer to save the setting.
Enable the Caps Lock Key
The "Caps Lock" key is loved by some and disliked by others.
The key turns all letters into capitals as you type.
While this feature is useful in some situations, a more common occurrence is that the key is accidentally hit and all the text typed is capitalized.
The person typing must then delete the capitalized type and rehit the key to turn off "Caps Lock."
If the "Caps Lock" key needs to be enabled, it indicates that someone has disabled or remapped the key.
If a user wanted to, the "Caps Lock" key can be disabled and enabled through the registry or remapped through the control panels.
Updating the registry for the keyboard will enable the "Caps Lock" key.
Open the Notepad program.
Type the following:
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout]
"Scancode Map"=-
Select "Save As" from the "File" drop down menu.
Navigate to the computer desktop as the save file location and choose "All Files" from the "Save as type:" drop-down menu at the bottom of the Save As window.
Type "enable.reg" without quotes in the "File name:" field and click "Save."
Minimize all open windows to view the desktop.
Double-click on the "enable.reg" file. A box will pop up asking if you are sure you want to run the file. Select "Run" or "Yes" and then click "Yes" for the Registry Editor warning.
Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled.
Manually Update the Registry
Click the "Start" menu, type "regedit" without the quotes and press "Enter." In older versions of Windows, Click the "Start" menu, select "Run," type "regedit" without the quotes and press "Enter." This will launch the Registry Editor.
Navigate to "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout" to view the settings.
Right click on the "Scancode Map" setting and choose "Delete." Click "Yes" to confirm the deletion.
Disable the Caps Lock Key in Windows
Your computer's Caps Lock key has likely only collected dust since you first brought the machine home.
The Caps Lock key is beneficial if you want to type a long string of words entirely in capital letters, but this form of typing is not needed often.
Consider disabling your Caps Lock key if you do not need it, or if you are tired of hitting the key accidentally while rapidly typing.
Restart your computer before beginning the process of disabling your Caps Lock key.
Download the registry file necessary to disable your Caps Lock key.
You have the option to disable your Caps Lock key or change the key to a number of different keystrokes.
For example, you may choose to use the "ChangeCapsToShift" registry file if you want the Caps Lock button to function as a shift key.
Double-click the registry file you have downloaded.
A prompt will appear on your screen asking if you would like to add the registry file to your computer's registry.
Select "Yes" to install the registry file.
Restart your computer, once again, to complete the registry change.
Upon reboot, your Caps Lock key will no longer function as a traditional Caps Lock key.
Disable the Caps Lock Key on a Computer
The Caps Lock is an easy key to hit by accident, and often the user does not realize it immediately.
When this mistake occurs, usually you must correct some text errors and your time is wasted.
If you think the Caps Lock key is more of an aggravation than it is good, follow these steps to disable your Caps Lock key.
Click on "Start" and select "Run". Type "regedit" into the textbox and hit "OK". This command will open the "Registry Editor" window.
Select "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control".
Double click on "Keyboard Layout" to open the folder.
Open the "Edit" menu and choose "New" then "Binary Value".
A new file will appear on the right side of your screen with the file name highlighted.
Type "Scancode Map" for the new file name.
Double click to open and type in "00000000 00000000 0200000000 003A00 00000000" into the Value data box. Hit the "OK" button.
Close the "Registry Editor" by selecting "Exit" from the "File" menu.
Restart your computer for the change to go into effect and enjoy life without the Caps Lock Key.
Hope this helps
Nov 05, 2012 | Computers & Internet
Different letters appear when typing a certain letter for example when typing letter s letter w will also appear
I see that when typing in on the keyboard some letters appear as well like for "s' the letter "w" shows up as well.
Was there any liquid spilled on the keyboard? if none then you can try cleaning OFF any unwanted software on you computer, then perform a disk defragmentation on the machine just to have everything in proper order for the windows side.
After doing what was said above restart the computer and try the keyboard again if still the issue is the same, i suggest that you back up any personal stuff like pictures and emails if ever because reformatting the Hard drive and windows back to factory defaults will be next to see if the issue will still be the same after reinstalling windows back to defaults.
If the issue is still the same after reinstalling windows then this is going to be considered a hardware failure to the keyboard and replacing the keyboard will be the next best thing to be done.
Unless Liquid was the cause then the issue may differ if the motherboard was the one causing the letters to type in with other letters which is not common.
Oct 07, 2011 | HEWLETT-PACKARD G56-141US Notebook
Hi, my acer aspire 4930's keyboard not functioning correctly.. when i press letter "a" it appear as "A1" same as "Q" appears "Q1".. pls help me
Hi.
Try cleaning the keyboard with a clean, dry paintbrush just in case there is anything stuck under the keys. Once you have cleaned the keyboard try typing keys to see if it does the same thing. If the keys type as normal then you have resolved the problem.
If the keys still type other characters along with the letter then there is a strong possibility that the keyboard needs to be replaced.
This usually happens when something has been spilt on the keyboard causing it to type random characters or the characters directly above or below them.
Seeing as the keyboard is a laptop keyboard you can use a wireles/wired keyboard or you can use the on-screen keyboard if you can't get the keyboard to work.
If there is anything else please post back.
Good luck.
Jun 07, 2011 | Computers & Internet
Numbers take precedence over letters on shared keys
On my keybard I have a FN function key and F13 locks it. It lights an indicator.
Carl
Jan 11, 2010 | Acer NSK8458AN Keyboard
A key (which one?) changes the letters all keys type
You're hitting SHIFT and CTRL -- which changes the keyboard input method, i.e., for French keyboard, or for DVORAK keyboard, or for Scandinavian keyboard.
Access CONTROL PANEL, and use REGIONAL settings to "uninstall" all keyboard-layouts that you _never_ use.
Jul 01, 2009 | Microsoft Natural Ergonomic 4000
Cannot type certain letters
Verify that the key is not working in more than one application. It is possible that some keys may not be used in all programs. This generally always applies to the Function keys F1 through F12. If not all keys are working in all programs and you have Windows, attempt to boot the computer to a MS-DOS prompt or Safe Mode and test the keyboard in DOS.
If it appears that a substance has been spilt into the computer.
If any type of liquid has been spilt within the keyboard you can attempt to clean it . however, because of the dramatic decrease of cost with computer keyboards, it is recommended that you simply replace the keyboard to help prevent frustration and possibility of failure again in the future.
Thanks,
CF
Jun 25, 2009 | Sony VAIO VGC-LS20E Notebook
Keyboard trouble
ok in the keyboard there is fn right. Hold FN+Number lock (num lk) then it should transfer back to letters
Jan 02, 2009 | Computers & Internet
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
