Question about MSI 865PE Neo3-F Intel 865PE LGA775 DDR 400 ATX Motherboard w/SATA, LAN(Gb), USB 2.0, Audio (MM865PEN3F)
Won t start up
Coolingfan is drewing from processor but monitor don t start up and the rest also not
    Brigadier General:
  • 5,158 Answers
More information would be helpful
Robert
Posted on Aug 30, 2008
Installed a new ignation switch with the keys that don`t have chips. Motor turns but won`t crank. Also keys won`t come out of the ignation unless thr ignation is unplugged.
It's not going to start without receiving the right code from the chipped keys. You've only swapped out half the anti-theft system. The rest is in the software. No way to get past that. Fix it right or you'll be walkin'
Jul 11, 2017 | Cars & Trucks
My Nancy Drew computer game won't work
Hi longview924,
Unfortunately there is no way to make that game run on your mac. Your mac uses the older powerPC architecture (all G3, G4 and G5 macintosh machines use this architecture) but the game requires that you have a mac using the newer intel architecture.
I found the details of the system requirements here:
http://www.buzz99.com/1167/nancy-drew-trail-of-the-twister-system-requirements/
Intel and PowerPC processors are very different in how they work (Intel chips are CISC chips and powerPC chips are RISC chips), which is why there is no way around it. This is also the reason why apple dropped support for the powerPC architecture in mac OS 10.6 upwards.
Without meaning to sound harsh, it may be time to consider an upgrade - macs are very expensive but the intel macbooks are leaps and bounds faster than the powerPC range :)
Jul 03, 2012 | Video Game Consoles & Games
I have an old hp v75 desktop that the monitor won't turn on all the lights are working, fan running, nothing wrong with the power supply, but when I press the power button it turns on, but the monitor...
First remove the vga cable from the desktop and see the monitor shows no conection if showing there is no problem with ur monitor if not change the monitor if showing conect the cable back to ur desk to vga port then check the ram remove the ram clean the surface with clean cloth then rub the print using an eraser then insert the ram and switch on if still no display change the ram if still not working remove the processor heat sink na clean th surface of the processor and the heat sink apply a thin layer of heatsink solvent or thermal paste fix the heat sink then restart the computer
Jun 29, 2012 | Computers & Internet
My intel d945gcl motherboard procceser socket's pin broken during fiting procceser ..... i want early solve my problem ...
You don't want this answer but you need a new motherboard. If you've broken pins off the processor socket you won't get it working. They don't sell replacement processor sockets, you have an effectively dead motherboard.
Jul 24, 2011 | Computers & Internet
MONITOR CHIME CMV 221dI WON'T TURN ON
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Jun 18, 2011 | Chi Mei Corporation CMV-221D LCD Monitor
How to install mixer devices
I'm going to assume you mean an audio mixer and maybe an AV receiver.
The connections themselves are fairly simple but it pays to understand what happens in the loop. And since you don't name the EQ I'll make some broad generalizations that you should be able to adapt to your equipment. They're all pretty much the same for hook-up anyway.
In general, any Line-Level external processor (EQ, dynamic range expander, etc) will go into a Tape Monitor loop on a receiver. A Tape Monitor, when engaged, sends the selected stereo analog signal Out to the Processor, massages it and returns it to the receiver via the Tape Monitor IN connectors to be passed on to the receiver's internal processes (volume, tone, whatever).
Old school analog stereo-only receivers consistently work this way. Newer digital and audio/video receivers introduce a couple of problems: 1) digital sound processing to simulate a variety of soundfields; 2) multiple output channels, either discrete or digitally-generated.
The latter requires that whatever signal is being processed experiences a maximum of one analog-digital-analog conversion.
EVERYTHING analog coming into the modern digital receiver is automatically converted to a digital signal for internal processing unless you choose some form of STEREO-only or STEREO-Direct setting. Consequently, no further external analog-digital conversions would be allowed if, say, a Tape Monitor circuit was activated, and a possible feedback loop could otherwise be created in a digital-sourced selection (output to its own input), so the unit is wired to treat the Tape Monitor as the first analog step in the process and defeats any pure digital sources.
In a multichannel unit, what would happen to the other channels if you sent ONLY the Front Left & Right out for processing? The rest would NOT be processed. That logical problem also plays into the decision to defeat digital sources if the Tape Monitor is activated. I don't totally agree with the engineers but that's the way it is. Nature of the digital beast.
Okay, back to the hook-up:
It's should be clearly marked on the back of the Mixer where everything goes.
The Line IN and Line Out would go to any available Tape Loop on the receiver. Something that has Out's and In's. Obviously, Out's on one device go to In's on the next.
So, to sum up, you can only use the EQ or any outboard processor for analog stereo sources. If you actually want to use an analog recording deck or anothere processor you could place it within the typical Equalizer's own Tape Monitor loop(s). Many have two to facilitate equalized dubbing between decks and those loops can be engaged or bypassed via controls on the EQ or Processor.
May 15, 2011 | Audio Players & Recorders
Trying to hook up a yamah Eq to sony digtal audio recever
It's should clearly marked on the back of the EQ where everything goes.
May 13, 2011 | Sony Audio Players & Recorders
TRYING TO CONNECT MY EQ TO MY KLH RECEIIVER R5100 PLEASE HELP ME
Apr 22, 2011 | KLH R5100 Receiver
Aces Aspire M1640 desktop-pc starts but the monitor says NO SIGNAL. Tried various monitors and videocards without result. Can't find what mainbord is in it to have it changed. Regards, Toine
black out can be caused by series of things. Power supply is one. Second is the motherboard, memory and the processor aside from the video card. Motherboard and processor can be isolated,first is to remove the rest of the devices such as hard disk and cards and memory. Beep sound means your board is still doing fine. Re install all the devices and power on again. Good luck
Sep 12, 2010 | Acer Aspire M1640 Refurbished Intel...
MSI 865PE Neo3-F Intel 865PE LGA775 DDR 400 ATX Motherboard w/SATA, LAN(Gb), USB 2.0, Audio (MM865PEN3F) Logo
96 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
