Question about Xerox Office Equipment & Supplies
4 h error code on my xerox xc865 - Xerox Office Equipment & Supplies
    President:
  • 2,072 Answers
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
Posted on Jul 06, 2008
XEROX COPIER XC865 HAS AN H4 ERROR CODE HOW TO RESET AND WHAT DOES IT MEAN
H4Fuser temperature too low. Must be reset in diagnostics
Dec 18, 2009 | Xerox XC356 Copier
Machine will not make copies
Your out of toner and the machine cant set up.
May 20, 2009 | Xerox Office Equipment & Supplies
Schematic of the Xerox XC865
Usually you can find the place to put the part by noticing the location of mounting holes or an obvious space on the fuser where it should go. Otherwise you might check with some of the places that sell replacement fuser assemblies. They might be able to send you an exploded view of the fuser.
Mar 10, 2009 | Office Equipment & Supplies
google The Parts Drop, Give them a call, ask for Britt he can help you most likely.
Mar 10, 2009 | Xerox CopyCentre C123 Copier
Cracked fuser drive gear for Xerox copier XC865
There is a metal clip that holds it on the roller. Look in the machine for it.
Jan 31, 2009 | Xerox CopyCentre C123 Copier
XEROX XC865 - No image
You are not getting any transfer. There are two types of transfers:
1- Corona wire; a set of very thin wires (hair thin and usually gold) that sit exactly against the drum. they are eiher broken or the unit is shorting out
2- a black spongy roller, usually don't go bad may need some recalibration
other possibility is the Developper unit,
which may be going bad look at it does it have a coat of toner on it? if no and you can see the long roller (it should be a silver magnet roller) if you can see the silver then there is not enough toner on the roller, it should have a thin solid layer of toner all the way xerox%2520xc810%2520drum%2520cartridge.gif
Aug 07, 2008 | Office Equipment & Supplies
Xerox Copier problem
Turn power on and within 4 sec.press the following sequence;clear,exposure,clear,exposure.The screen will go blank.Enter '1' and '4' then hit print.turn off. This will reset H4 if the fuser has no problems such as a bad fuser lamp or thermal fuse.And yes it,s worth fixing with the right guy working on it!
Jun 30, 2008 | Xerox Office Equipment & Supplies
162 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
