Question about Saeco Primea Cappuccino Touch Plus Coffee Maker
Same problem do u have the solution already,cause mine has got the same problem,the machine doesn,t recognize a full watertank
  • 515 Answers
The printed circuit card is the problem, on some models the printed circuit card loose from the chassis.
Posted on Jul 10, 2008
The water light comes on and stops the machine from working even if water is full
There's a float (with a small magnet) in the watertank. This float should go up when the tank is filled with water.
So the float can be stuck in the bottom position, or the sensor doesn't work.
You can test the sensor.
  • Take the left cover off: two screws on the back, slide the cover backwards, then lift the bottom up and pull the toppart out downwards.
  • On the main board there's a plug right at the top, that's the cable from the watertank-sensor. With the watertank removed it shouldn't conduct.
  • Now fill the watertank, check whether the float is going up, put the tank back in the machine.
  • The sensor switch should be conducting now. It it is, then the problem is in the control board.
Hope this helps!
May 28, 2015 | DeLonghi Esclusivo Magnifica ESAM3300...
Full watertank appear all the timeand the tank is full.what is my problem .thanks
you need to resubmit your question. the spelling error makes the question un answerable
Nov 05, 2014 | Spidem Trevi Digital Coffee Maker,...
Fill watertank
hi check that programation is set off on direct water source
Mar 05, 2014 | Saeco Royal Digital Plus Coffee...
Our Comfort machine won't brew and constantly displays, "Fill Watertank" even with the tank full. In order to brew, one has to remove the water tank then gently lower it only partially down in place. As...
The magnet in the water tanks is either upside down or has sunk to the bottom of the tank. It should float to the top of the cage it is in and it should have a flat top not rounded. If its rounded side up the magnet is upside down. This is what would cause your problem.
Sep 22, 2010 | Saeco Magic Comfort Plus Espresso Machine
Screen says 'Fill Watertank' when watertank is clearly full.
Sounds like the sensor that detects system water levels has failed.
If you can see it inside try cleaning it or ask Miele for some advice via their website
Apr 14, 2010 | Miele CVA615 Espresso Machine
I have an Incanto s class de luxe and it is telling me to fill the watertank and it is already full?I have turned it off and back on, and it is still not registering that the watertank is full?
There should be a grey cylinder in the bottom of the water tank that will rise and fall with the level of the water. When the tank gets low the cylinder will sink and the water light will come on. If the cylinder is missing the light will come on also. If the magnet in the cylinder is bad the light will come on. Some time it takes replacing the water tank.
Aug 18, 2009 | Saeco Coffee Makers & Espresso Machines
The machine says fill watertank. ventilate. the
Open the hot water valve, and run about a cup of water, this will engage the pump and fill the circuit.
Jun 04, 2009 | Saeco Vienna Digital Coffee Maker,...
Saeco Royal Exclusive 30153... FILL WATERTANK
Hi Marty,
Make sure the magnet in the water tank flow up when you fill the water tank with water.
Aug 07, 2008 | Saeco Royal Exclusive 30153 Espresso...
Saeco Incanto De Luxe S-Class - Fill Watertank constantly on
The machine appears to be blocked due to limestone formation in water piping. Suggestion is decalcify following instructions of manufacturer .
Jan 13, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Primea Cappuccino Touch Plus Coffee Maker Logo
75 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
