Question about Tomtom GPS
I have a TOM TOM GO 520 I have installed the CD Rom - I have attached the docking station and the USB Cable ihave said yes to connect to my pc. But computer keeps telling me to connect the device no tom tom recognised, Checked my hard drive and it is set up. Really frustrated now run out of ideas what is wrong ?
  • 515 Answers
Will a kensington universal docking station work with my sony vaio pcg-7d2l
Yes it should if you are running Windows XP, Vista, 7 or 8. You just connect to the unit using a spare USB port on your laptop and a plug-plug USB cable. It has it's own power so you'll need a mains socket. This means you can unplug your laptop and leave any devices charging on the docking station USBs. Your laptop should auto-instal the station. I believe there is a table/support available which combines with this unit. There a varying prices for this unit so look around.
Good Luck
Feb 27, 2014 | Kensington SD400V USB Docking Station with...
Hello - I had to change betteries in the Harmony 520 remote. Now the remote seems to need to be re-programmed. How can I get it working again?
You need a computer and the CD rom for Harmony remote to reprogramme it.
1 Insert the rechargeable batteries into the Harmony One remote. Attach the AC cable to the charging dock and plug the AC adapter into an AC outlet.
2 Set the remote onto the charging dock to fully charge the battery. Wait until the charging indicator light is completely green before removing the remote from the charging dock.
3 Write the make and model of each device you want to program into the Harmony One remote. You need both the manufacturer and the model number for your devices to properly pair with the remote.
4 Insert the software CD into your computer's CD drive. The software will install automatically. Once installation is complete, attach the USB cable to the computer and attach the other end to the Harmony One.
5. Create an account and follow the software instructions to complete the setup process. Your account allows you to customize your remote settings whenever you desire.
6. Enter each device on the "Setup Devices" screen. Indicate how you want the devices to work with the remote. You must know how your devices are connected to pair with the remote. Update your remote by transferring software information to the Harmony One remote.
7. Test the Harmony One by following the directions on the remote LCD screen. Push the "Activities" button to test the desired activity. You may also customize and adjust your settings in this mode.
Pairing the Harmony One
1. Start the Harmony One remote software and access your account. Press the "Devices" tab. Press the "Settings" button for the piece of equipment that you want to pair.
2. Pick the "Confirm Infrared Commands" option and press the "Next" button. Press "Yes --- I have a remote for this device."
3. Connect the Harmony One to your computer to begin the communication process. Set your original remote 2 to 5 inches away from the bottom of the Harmony remote. Push the "Power Toggle" button.
Setting Date and Time
1. Pick "Options" located below the LCD screen next to "Devices" on the Harmony One remote.
2. Scroll to "Date and Time" below "Slideshow."
3. Pick the appropriate year and then choose the correct month. Select the day, hour, minutes and "AM" or "PM."
Using Device Mode
1. Access the "Activities" screen and select "Devices" located at the bottom of the LCD screen on your Harmony One remote.
2. Scroll through the list of devices and select the device you want to access.
Feb 13, 2011 | Logitech Harmony 520 LCD Remote Control
Cant comp to work,it's plugged in and when you go
Remove Any Docking Stations or Port Replicators From the Computer Note: Docking stations and port replicators are optional equipment. If you are unsure if you have a docking solution attached to your computer, refer to Table 1 and Table 2 for examples. To remove the docking station or port replicator, perform the following steps: Shut down the computer. Remove the docking station: Universal Docking Stations: Disconnect the docking station's USB cable from the computer. D/Port or D/Dock: Remove any cable locks from the security slot on the right side of the docking station. Move the slide lock forward to the unlocked position. Press the Eject button and lift the computer from the docking station. C/Port II or C/Dock II: Remove any cable locks from the security slot on the left side of the docking station. Pull the locking lever forward until it stops to eject the computer, then slide the computer out of the docking station. Dell manufactures the following docking stations and port replicators (Table 1): D-series DocksC-series DocksSpecialty Docks D/PortLatitude? C/Port IIMedia Bases D/DockLatitude? C/Dock IIInspiron? Advanced Port Replicator Table 1: Dell Docking Stations (Click an image to enlarge it) Universal docking solutions are also available from third-party manufacturers including, but not limited to, the products below (Table 2): TargusKensingtonBelkin Table 2: Universal Docking Solutions (Click an image to enlarge it) Disconnect All Peripherals from the Computer Remove all external connections from the computer. This includes but is not limited to the following devices: docking station or advanced port replicator keyboard mouse speakers or microphone printers scanners USB or 1394 devices palm pilots zip drives secondary battery Plug the AC Power Adapter into the Laptop Computer Remove the battery from the computer. Connect the AC adapter directly to the computer Verify That the AC Power Adapter Has a Solid Green or Blue Light Verify the AC power adapter displays a solid green or blue light. Older Latitude? C Series laptop computer AC adapters may not have a light. The new E series power adapter indicator light is either a blue ring or a blue dot and is located at the tip, on the DC connector, not on the power brick itself (Figure 1). Figure 1: E Series Power Adapter Indicator Light Location Numbers reference image above: E Series Power Adapter Indicator - Blue Ring E Series Power Adapter Indicator - Blue Dot D series power adapters have a green lights located on the power brick (Figure2). Figure 2: D Series Powed Adapter Indicator Light Location Numbers reference image above: D Series Power Adapter Power Brick D Series Power Adapter Power Indicator Light Shut Down the System If the computer currently is turned ON, running on the battery, shut down the system: 1 Click Start. 2 Click Shutdown. 3 Choose Shutdown from the menu. 4 Click OK. 5 Allow the system to power off. Plug the AC Adapter into a Known-Good Wall Outlet Verify the wall outlet is known-good by testing it with another device, such as a lamp. Confirm there are no power strips, surge protectors, or uninterruptible power supplies (UPS devices) connected to the power cable. UPS devices provide temporary power for a computer when there is no electricity available from the wall socket, such as during a power outage. Plug the power cable into the known-good wall outlet. Power up the system. Replace the MiniPCI Door, Rubber Feet, and System Motherboard
Nov 07, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
No desk dock came with our tomtom,spoke with Sears person and they said to contact you.
Tomtoms usually use a mini-usb connector. So you should be able to use a mini-usb to usb cable instead of docking station
Aug 12, 2009 | Tomtom GO 730 Car GPS Receiver
710c cable will not fit in new docking station
Need to buy a new USB to Parallel converter kit (is just a cable and a cd with the installation drivers) cost around $20
Jul 27, 2009 | HP DeskJet 710c InkJet Printer
How does a USB docking station work w/ a regular docking station
the older pc probably needs a usb 2.0 port to run docking station. the manual on the docking station should tell you. you may need to install a usb 2.0 pci card in your older computer for it to work.
Mar 18, 2009 | Dell Inspiron 5160 Notebook
Tom tom home does not see my tom tom go 520
Hi canal_boat_m
Try this solution:
STEP 1 Un-install Tom Tom Home from your PC
STEP 2 Click on the link below:
This will download a little removal program for the Tom Tom Home program.
A Black window will appear briefly then close.
• Make sure that you have got Administrator rights on the PC. Otherwise you may not be allowed to connect new hardware (especially the case when using office computers)
• Reboot your PC
STEP 3 Visit Tom Tom website and download the current new version of Tom Tom Home and install it to your PC
STEP 4 Connect the TomTom
• Make sure the device is fully charged before connecting it to the computer. Ideally a mininum of 4 hours charge.
• Reset the device using a paper clip (see When resetting, keep the reset button pushed in for at least 20 seconds, but DO NOT turn the device back on just yet.
• Ensure that your TomTom has power connected to it. There should be a green light on the TomTom unit. If your device came with a Home Charger, please make sure that is plugged in to the TomTom also.
Your Tom Tom should ask you to 'Connect to Computer' if it does tap YES.
Your unit should now be recognized by your PC.
IF IT DOESN'T then follow the instructions below:
1. Connect your unit to your PC;
2. Copy two folders to your PC (namely 'Raster' and the one which holds all your maps - probably called 'United Kingdom and Eire';
3. Using Windows Utility, right click on the Tom Tom drive unit and select Fomat;
4. Switch off the unit and soft-reset it with a paper clip (but hold it in for at least 20 mins) and then re-connect it and power it up;
5. Tom Tom Home should now detect the unit and your unit should ask you to 'Connect to Computer' so tap YES;
6. Tom Tom Home will now say your device needs updating - and if you apply all the changes it will restore it to Factory Finished!
7. Then all's needed is to replace the two folders you backed up and any other items like mp3's and sounds, pics, etc.
Feb 27, 2009 | Tomtom GO 520 GPS Receiver
What is the docking station for?
a usb cable will work... the docking stations are handy as you just put the camera/camcorder into the docking station ... no extra cord... often has the charger built in as well
Jan 19, 2009 | Sony HDR-SR11 Flash Media Camcorder
I have an HP zv5000 Pavilion with HP original Docking station. I it large and doesn't allow me enough length of connection to move my laptop out of the dock. Because of this docking station the monitor...
At this point, you can't find any such cable, since it is outdated. The only thing I could suggest is try to disassemble the dock to remove the cable, the only problem is you would now need desk space to hold the computer...
Nov 25, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Problem with conection tomtom 910 to PC
Complain to Tom Tom ,you may have a lemon,look for law suit soon
Feb 22, 2008 | Tomtom GO 910 GPS Receiver
GPS Logo
52 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
