Question about Polaroid FLM-323B Television
DEAD POWER SUPPLY
Power supply won't start
  • eldenmon Jul 06, 2008
    Power adapter and cord are fine there is 159 volts on the main filter in power supply Fuse in power supply is good there is b+ to all the SMPS mosfets but the thing won't start us and run
    The power supply is inside the tv. there is power to to the switching transistors but they are not starting up. this is a dual supply and there is no voltage at the output of these. have ESR checked the electrolytics and checked all the diodes and transistors to no avail.
    Sergeant:
  • 275 Answers
I think there is some failure in your tv electronic components. i think it will be better for you to contact the shop from which you bought it. or you can visit to this link
http://www.polaroid.com/ select your country and select the support option.
Posted on Jul 06, 2008
    Sergeant:
    Champion:
  • 417 Answers
Sounds Like A Faulty Power Supply - Just Buy A New One
  • Polaroid Master
  • 19,396 Answers
If it is the tv that is not starting, and power adapter is tested and fine, then there is a problem with the tv.
    Scholar:
  • 135 Answers
Hello
i think the adapter or the power chord connecting the tv and the power socket is not working ,,
do get a replacment for that,,this will do
thanks for using fixya
  • 2 more comments
  • Harrish Mugundhan Jul 06, 2008
    Can u give your product details??
    hello sir
    till smps is fine .thats good...now i think the prob is beyond smps.i mean,,smps drives the EHT(picture valve), audio,remote sensor power etc..
    i think there shud be a problem with smps delivering power to EHT which produces high voltage to produece th picture..do chenk the motherboard n smps wheter the connection is establishe properly
    thanking u for using fixya
    hi sir,,
    yes i can gt ur problem.. i hearby conclude that ur switching transister go either short circuited or damaged..
    ur prob can be rectified by replacing al th e switching trans alomng with assosiated reistors,switching diode,
    thank u
  • Harrish Mugundhan Jul 07, 2008
    You will have to have it serviced by a tech who can properly diagnose the exact cause and replace the parts associated with the failures. Unfortunately, you can purchase a new 25 or 26 inch set for $159 and up, so you will have to decide if you want to repair or replace. Normally a set over 4 years of age is not worthy of any major repair; this because of the constant increase in repair costs and the dramatically lower prices of tv sets on the market.
    Wishing you the best,
    Genius:
  • 1,847 Answers
So what do you want from fixya?
  • Legin Varghese
    Legin Varghese Jul 06, 2008
    so what help do you want from fixya?
    need part no or where to buy etc.
  • Legin Varghese
    can you explain in detail ..
LEDs on motherboard light up but computer won't start
It still may be dead. Go here and get a PSU tester:
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=-1&IsNodeId=1&Description=psu%20tester&bop=And&Order=REVIEWS&PageSize=20
Apr 24, 2012 | Antec : True430 430W P4 ATX Power Supply...
Dictaphone transcriber won't power on
The 2720 has an internal fuse that may have blown as well.
Mar 17, 2012 | Dictaphone Audio Players & Recorders
No power
HERE'S THE ANSWER TO YOUR PROBLEM:
The main reason why your TV won't turn on is because of its power supply board. This power supply board are composed of capacitors that are the responsible for the proper supply of current to your TV. If one or many of these capacitors are already burned out or "dead" your TV won't turn on at all. Here's what you've got to do:
1. Open your TV or let somebody do it, much better a technician.
2. Check the Power Supply Board.
3. Check the capacitors. Remove the "dead" ones and replaced it with "new" ones. You can buy capacitors to the nearest hardware in your town, or to your service provider.
I would suggest you to do it with a presence of a TV technician, so that you will be guided properly. Thanks for your question. I hope it helps....
Jul 21, 2011 | Televison & Video
We have a 46 inch sharp tv model number 46SB54U won't turn on. The green timer light is flashing. We just replaced the power supply board thinking that was the problem. TV still won't turn on...
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will helpout ......
Jun 25, 2011 | Sharp LC46SB54U 46 in. LCD TV
The red light keeps blinking and tv won't turn the fan won't come on either
I hope this will help out in solving the problem....
Jun 19, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
The tv starts to turn on I hear a high pitched noise then it turns right back off. This will happen 3 times and then it won't turn on at all unless I unplug. It is a RCA model # R52WH74.
You need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where.If otherwise, Power supply board have problems,just not dead yet.Replaced the power supply board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
I hope this will help in solving the problem....
Jun 15, 2011 | Televison & Video
Won't power on
Common problem with this TV is the power supply module.
Check the power supply; look for bad caps with leaking/bulging tops, check to see if you have standby +5vdc at the power supply connector, the front red indicator will not be on if you do not have this +5vdc standby voltage due to shorted out power transistor and zener diode, if other otherwise Power supply board just die.It can be dead at anytime.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Take care in solving the problem,because it contain high voltage...
Jun 14, 2011 | Televison & Video
My Kenmark 19" tv won't
The power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this will help in solving the problem, do take in handling the fault, because it contains high voltage..
Good luck
Jun 07, 2011 | Televison & Video
81865gvmx mother board when ipress the power switch cpu fan does not start and the set remains in dead condition.
its most likely either your power button or power supply having an issue ensure the power buttons wires are all connected correctly as per the key for the motherboard and if its still not starting try using a different power supply if its still not working than its most likely a dead motherboard
Mar 30, 2010 | Intel Motherboard
Polaroid FLM-323B Television Logo
54 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
