I've got a Linsys Wireless G 2.4, 54 Mbps, model WRT54G. I live a a house where other houses a a fair distance away. The strongest signal from a lynksys now shows it as secure whreas before it was unsecure and that is how we originally set it up a couple years ago. We bought a new laptop and intiially it work fine on the wireless. Now all the sudden we can't connect or when we do it connects on another signal that is unsecure but very very weak. I can't access the strong signal because I don't have the password. I started reinstalling the linksys router software but it doesn't seem to have anything about connecting with Vista which my new desktop has. Frustrating. Can somebody give me a suggestion on how to proceed. It seems like the new laptop would connect if I just had a strong signal.
  • 63 Answers
Factory reset the router using the small reset whole on the back then go into your browser, type into the address bar 192.168.1.1 and user name and password box will show up, from memeory leave the username blank and the default password will be admin, enter your connection settings - away you go.
manual here if it is one of the blue routers, there is a newer silver model: http://www.linksys.com/servlet/Satellite?blobcol=urldata&blobheadername1=Content-Type&blobheadername2=Content-Disposition&blobheadervalue1=application%2Fpdf&blobheadervalue2=inline%3B+filename%3DWRT54G_UG_WEB_20070529.pdf&blobkey=id&blobtable=MungoBlobs&blobwhere=1193775701174&ssbinary=true&lid=0703200349B05
Posted on Jul 06, 2008
Can not connect to the internet...Model LC40iF60CN...iSymphony
you say all other appliances in the house are working fine, my first thought to your question was that 75ft is too far to pick up a wireless router, are all the other aplliances the same distance away. ( i would recomend about 15 - 20ft ). hope this helps,
Aug 02, 2012 | iSymphony 40" Class 1080p 60hz LCD Smart...
We now have dial up service in a small home office outside the house. There is cable DSL in the house. The outbuilding is 234 feet from the modem in the house. Can we use a router for this distance? If...
It might be a stretch to do that distance, especially if there are a lot of walls or other obstructions in the way. However, if you still want to try this, you can purchase a device that plugs into a USB port that can receive wireless signal. They sell them at many different retailers and if you ask an associate, they should be able to find one for you. My recommendation for a router would be a Linksys WRT54G (any model in this series) because if you have some good technical skills and a little time, you can change the firmware to DD-WRT (http://www.dd-wrt.com/site/index) and have a ton of settings to mess with, including boosting the signal range. Even if you don't want DD-WRT on your router, the Linksys WRT54G model is a great, reliable model and you could probably find one for less expensive than other routers out there. Hope this helps!
Aug 25, 2011 | Belkin Basic Wireless Router
How do you connect the internet to the wii i have wireless in the house and it still wont connect
First, you have to go through the Internet connection setup process through the console and you've made no mention that you've attempted that so I wanted to make you aware of that. On the main menu, go to the lower left corner and click on the round Wii button. A new menu will appear with two options: Data Management and Wii Settings. Select Wii Settings. Go to the second page and choose Internet. Select Connection 1: None. Select Wireless Connection. Select Search For An Access Point. A network list will appear, select yours. You will then be prompted to enter the password/network key that you established when you set up your wireless router. The Wii will attempt to test the connection. If successful save your settings.
Second, simply because you have Wireless in the house it doesn't mean that it your wireless router has signal strength to reach the WIi. Various factors affect this including signal strength, distance from the wireless router to the console and obstacles such as walls and ceilings that interfere with the signal. If you're using a G router and you have your Wii is too far away or, has obstacles in the way, it will not connect. You should use an N-Router if there is a significant distance between the console and the router or if there are obstacles. Here is everything you need to know about connecting your Wii to the Internet.
http://www.nintendo.com/consumer/systems/wii/en_na/online.jsp
May 08, 2011 | Nintendo Wii Console
I have an AT&&T 2701HG-B Gateway 2Wire wireless router w/DSL modem. My Mac G5 computer is attached with an ethernet cable (my computer does not have wireless capability). All this is in my home...
there is an adaptor that you can buy
it is plugged into the power socket for the house , connected to the ether net connection
you have a second plug in connection that plugs into any other power point and that runs a ethernet cable to the pc or modem
I have such a system running from the shed computer to the house computer and modem distance of 100 yards
it is called a TP-Link and is available fro Jaycar or like electronic shops
it works by using the house wiring to transmit the data signal along with the house power
Mar 23, 2017 | 2wire (1000-400108-001) Router
How do i hook up one router to get a signal from another one
You can set up a sort of siamese-twinning of routers to share a WAN connection through the use of what is called WDS. Information on how this works can be found here:http://www.keenansystems.com/newug/bblog/?postid=17.However, WDS slows down your internet connection by half, works only over relatively short distances, and doesn't work between different brands and models of router.A better general solution to setting up a point-to-point connection (example: to extend your wireless network from your house to an outbuilding workshop) uses a bridge instead of a second router. A router is an access point, while a bridge is like a more powerful version of the wireless card in your computer. Engenius makes relatively inexpensive indoor/outdoor bridge units (such as the model 1650). Since they are directional, you can point them directly at the house and extend your network over very long distances with very little power.
Oct 27, 2009 | Linksys Wireless-G WRT54G Router
Need to amplify incoming internet signal
Install a wireless access point at the strongest signal spot you have. This will repeat the signal throughout the rest of the house, or an addition length as necessary. You can purchase a good linksys wireless access point at bestbuy for $83 or cheaper from a trusted ebay dealer. Setup is fairly easy, follow manual.
Apr 16, 2009 | HP Compaq Presario V2000 Notebook
Wifi signal cannot reach back of house
I had similiar problem when setting up his wireless network! I fixed the problem by changing the Wireless channel from 6 to 11 and he can recive it in his apartment on top of the garage and in the house and on the backside of the house! lemme know how it works ou!
Dec 27, 2008 | Computers & Internet
Satellite internet-''G'' router-no signal less than 100feet away
The metal barn serves as a wireless interference. It reflects back the signal from your mom's house. What you can do to get a wireless signal if either buy a Wireless Access Point to extend the signal from your mom's house or just relocate the position of the satellite transmitter.
Nov 18, 2008 | Linksys Wireless-G Broadband Router
Signal strength very low. Belkin ADSL2 modem with wireless g router F 507632-4
signal is bouncing off doors and walls to get to your comp
move comp closer to modem if it increases and your signal strength increases then you know youll have to be close to modem
other problem someone taped your signal and it working off of it call your provider to come out test the wireless signal strength and or password your wireless router settings so some one cant interfere with signal
i dont like wireless myself in the home i go straight cable with ether net cord this always has strenght and cannot be tapped
May 09, 2008 | Computers & Internet
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
