Back to:
Tags:
Sony Walkman Video NWZ-S616F MP3 Player
Problem installing driver (by 3 users)
posted by nvk_vin on Jul 06, 2008
every time i plug in it shows instaling the driver after some time it shows problem installing the driver and my walkman is not detected by the pc.how can i solve it help me!!!!
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by golfer100, posted on Jul 24, 2008
Same Thing - Will not charge
Comment by Guest, posted on Jul 19, 2008
computer doesn't see mp3, no charge function or show up on media player
Best Solution
posted on Aug 24, 2008
FixYa! (100)
bagru
Rank:Apprentice Apprentice
Rating: 100%, 8 votes
I first found that when I plugged my player into my computer it registered it as a MTP (Media Transfer Protocol) device and in turn never showed up as a storage device on my computer. I fixed this by going into my Control Panel -> System Icon -> Hardware Tab -> Device Manager button. Clicking on the “System Devices” tab should have “Walkman” or MTP device. Right click on it and go to properties, now before doing anything it should say “Location — —— Location 0 (Walkman)” if not try unplugging the walkman and see if the MTP device you’re looking at is removed from the list, just to make sure it’s the right device we’re looking for.
If you’ve confirmed it’s the Walkman, click on the “Driver tab” and click on “Update Driver…”. Then click on the “Install from a list or a specific location (Advanced)” option and click “Next”. Now select the “Don’t search. I will choose the driver to install.” and click next. It should now bring up 2 driver choices, one being “MTP Device” and the other “USB Mass Storage Device”. Select the USB option and select next, it will then install your walkman as a USB storage device and after that’s done. It should be a matter of unplugging and plugging the Walkman back in and it should show up on your storage options in “My Computer”"
Comment by bagru, posted on Aug 24, 2008
nvk_vin this will solve your problem
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on problem installing driver:
I don't want to Accept this solution
Solution #2
posted on Jul 27, 2008
Helpful (85)
Sazwiz
Rating: 85%, 1 votes
I'm Using Windows XP (SP2)
I Had This Problem & found that if I Uninstalled the USB in Device Manager (Portable Devices) and rebooted the computer and let Windows redetect and install them.Some Help Below...
YOU MUST HAVE YOUR PLAYER PLUGGED INTO THE PC WHEN YOU DO WHAT'S BELOW, AS YOU NEED IT TO APPEAR IN PORTABLE DEVICES
To Get To Device Manager Quickly - Highlight My Computer On Your Desktop/Right Mouse It & Choose Properties/Choose Hardware At Top/Then Select Device Manager/Then Portable Devices/Highlight Your Player & Right Mouse Then Choose Uninstall/Exit Device Manager/Disconnect Your Player/Them Restart Computer..../When The Computers Ready Try Connecting Your Player Again It Should Work?
Thank You!
Solution #3
posted on Sep 27, 2008
Not Rated (0)
motznarf
Rating: 0%, 0 votes
What I did was go to Device Manger (per directions above). Walkman was in yellow, just need to reinstall driver and it works!
Thank You!
Can you Help with these MP3 and Digital Media Players problems?
i have transfer music to my sony walkman nwz-s616f .when i...
the video is a mp4 file but my walkman still does not play...
Recently my walkman is not registering a connection when...
I put my whole library on my walkman and it shows the...
Hey, i've been having trouble with my playlist and it...
Loading problems.
Repair Service
Find MP3 and Dig. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
