Question about JVC AM FM CD DET FACE CAR STEREO
Jvc kd g521 car cd player
I have the above cd player and although the stereo stations are stored withing the number keys when i turn my engine off and on i loose the station i was on and have to push the numbner key again to get it back . also when i switch off and on the cd i play goes back to the beginning can you help//
Have you checked the cables? It appears that you have connected the wire for ignition directly to the power in and the direct +12v to the ignition cable. When turning ignition off, the memory is then emptied.
Posted on Aug 18, 2008
I have a JVC KD-S37 car stereo and need the manual plus the remote cuz i cant change the color and setting please can you help? thanks ferrarisandra325@gmail.com
      • vcwuaaaaasuvork5cyii=
  • Attention JVC consumers!
  • JVC's Consumer Customer Care Center can help you with most product or service related questions you might have. This number is for home-use TV's, VCR's, DVD's, car audio and portable electronics:(800) 252-5722
  • JVC Pro Support Page
    Dec 05, 2014 | JVC Kd-s37 Car Audio Stereo...
    The memory on my new jvc car stereo model kd-s17 does noty work whenever i turn the key off then on i have to reset the clock and presets all of my wires are connected
    need to check the yellow constant power wire on wire harness to see
    1. connected to battery with constant 12 volts
    2. if wire has power 12 volts
    if no power check fuses to see if blown
    with out this wire working right you will never have pre set station on radio or clock
    with correct time
    Dec 22, 2010 | JVC KD-G801 CD Player
    JVC KD-G230 will not work after my battery died
    the battery probley shorted out your deck i think its time for a new one
    Jan 11, 2010 | JVC KD-G230 CD Player
    My car stereo a jvc kd-s6060 losses pre-set stations when its been turned off.
    Your wires are probably backwards. the yellow one is for memory and it gets wired to direct battery voltage to hold the memory. The red wire is for power when key is turned on.
    Oct 06, 2009 | JVC KD-S6060 CD Player
    Car stereo JVC KD-PDR40 lost manual can't set clock?
    hi my jvc kd-pdr40 cd player keeps resetting the sound to basic with no bass everytime i turn it off
    Sep 26, 2009 | JVC KD-PDR30 CD Player
    Stereo stations wont stay set
    If you have a yellow wire that is the memery wire. It needs to be hooked to a constant hot. If you do not have one you need to get a new plug for the back.
    Feb 24, 2009 | Kicker CVR12 Car Subwoofer
    JVC KD-G351 question
    It sounds like your stereo is working properly. I've never seen a car stereo that was wired properly that you could turn on and listen to while the car was off with the key removed from the ignition switch. You would have to move the ignition switch to the accessory position in order to get the stereo to work. Hope this helps. Good luck. Mike D.
    Aug 21, 2008 | Car Audio & Video
    Tuning station problem
    Try this: "Hold FM/AM and Press #5". This solution is for a different model JVC stereo, but hopefully it will work for yours as well.
    Mar 25, 2007 | JVC KD-S5050 CD Player
    JVC AM FM CD DET FACE CAR STEREO Logo
    187 people viewed this question
    Top JVC Car Audio & Video Experts
    xxxxxx xxx
    Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
