Question about LG WM-2277HW Front Load Washer
LG WM 12230FB WASHING MACHINE
Drum will not turn if you give the belt a push it will start to turn then just stops again
  • 75 Answers
The belt which s at presently fixed is not of proper size change the belt and try it. the drum will run properly
Posted on Jul 25, 2008
How do i turn off the beeping on a LG WM-12230FB washing machine...
with this model im unsure if there is a sound button on the washer however if not then there is no way of doing this but...if you have a steady hand the speaker is behind the electronic panel with a beeper styled speaker on the back of the electronic board and can be with the absolute care and soldering iron can be removed though...i wouldn't recommend doing as warranty could be voided
Oct 12, 2016 | LG Washing Machines
My washer wont rinse or spin SE keeps coming on
Hello
LG washing machine error code SE indicates a "motor fault.
You can try resetting it by unpluging the unit for 3 min and see if it clears.
If not, it s going to need service.
Apr 08, 2011 | LG WM-12230FB Front Load Washer
Can you please advise what CL means on our washing machine (LG WD1049C)
CL usually stands for child lock , look for a button indicating LOCK or child safety maybe a childs face etc. once you locate this button push for 3-6 seconds to unlock.
Jan 12, 2011 | LG WM-12230FB Front Load Washer
Error message UE is displayed and the machine has stopped
UE means unbalanced load. This happens when the load is too small, or the appliance is tilted, laundry is gathered to one side, non distributed things are put into the drum.
Jun 16, 2009 | LG WM-12230FB Front Load Washer
Washing machine has given up
the circuit board is shorting out need to replace the circuit board
May 30, 2009 | LG WM-12230FB Front Load Washer
Wm noisy
drum bearings, check and investigate, remove drive belt and then rotate, if still noisy then yes its the drum bearings, if the noise stops when the belt removed the motor bearings are faulty costly repair on most models, sorry oh there is also the possibility there is something lodged within the drum cavity between the lining and the drum casing
Sep 25, 2007 | LG WD-16110FD Front Load Washer
LG WM-2277HW Front Load Washer Logo
70 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
