Question about Canon NP 6050 Copier
Light copies i already changed the control board but it still produces light copies.. it is using the same power voltage as before.. it used to produce clear copies until suddenly the copies became light.. is already cleaned the small glass which can be pulled out near the drum but the copy is still light..
  • 134 Answers
The optics need to be cleaned also. If you are tech savvy, then there are two screws that hold down the glass on the right side of the top of the copier. lift up the glass, power must be off. then with a soft cloth, wip the mirrors that you can see. Other wise the corona wires will need to be cleaned in side the copier.
Posted on Jul 09, 2008
TV no picture I did replaced T-Con board and Power supply board. but didn't work it no backlight but This TV had no backlifht and inverter board in the back...needed help please.
Hi Tong,
Any basis or reason to replace the two boards you replaced? Any voltage measurement? Further you have not mentioned the make and the model number.
Generally it is the inverter board that is found defective in 'no backlight' problems. If the power supply is producing necessary voltage and the main board is sending necessary command ie 'inverter on' and 'brightness control' to the inverter board and still it not producing the voltage required to drive the backlight, the inverter board is defective.
Good luck.
Apr 29, 2016 | Televison & Video
I have a hisense 55" tv the screen is really dark but is still working knowing because I did the flash light test. Would it be my power supply panel
If the back light inverters are mounted on the power supply board, then yes, the power supply board needs replacing. If the inverters are on a separate board, then replace that one. Use a voltmeter to check if the different voltages produced by the power supply are present and within +or- 5% of the expected voltage.
Sep 28, 2015 | Hisense Televison & Video
What makes the HISENSE LCD (Model LCD 42W58P1) power supply failed to produce output voltage goes to the main pc board?
First of all the power supply makes 'Stand By 5 or 3.5V which goes to main board. When we give power on command to the TV the main board sends 'stand by or Power ON' command to the power board which then makes other necessary voltage for the main board as well as other sections. If the power board does not receive 'Power On' command from main board, it will not produce the necessary voltages to operate the TV set.
May 20, 2015 | Hisense Televison & Video
When the microwave is cooking the light inside dims. When done cooking the light returns to full brightness. Is that normal or is there a problem with the microwave?
I've seen this with most microwave ovens I've had. When the microwave emitter kicks in to cook, the unit uses much more power, providing less to the internal bulb, which dims a bit. Unless it's very dramatic, for example the bulb turning off or going almost out, it's normal behavior. If the bulb is going very dim or out, it could be that the circuit it's connected to isn't providing enough amperage to adequately run the oven. In the case of your microwave, it's rated at 15 amps, so should have adequate power on a standard household circuit by itself.
Apr 09, 2014 | GE Profile Spacemaker 1.8 Cu. Ft....
I bought a second hand toshiba 5540 from a supplier here in the philippines. the problem is that the copies produced is not clear.for example, when photocopying a passbook, there is no clear copy that is...
does it copy properly when using standard paper as the medium to copy from
the reason is that many passbooks have a surface that reflects the copy light to prevent those books from being copied
May 26, 2017 | Toshiba 6560 Copier
When i turn my tv on it powers off after a few seconds
In the absence of audio and video, the likely culprit is the main power supply which services both. Plasma sets use an output of the main supply to produce the high voltage required by the plasma display which has attributes similar to the older CRT displays in the use of high voltage and internal phosphor to convert electron flow into light. The main supply may be a separate assembly. If you feel adventurous, pull the AC plug overnight and remove the back panel of the set. Look for a smaller board with fewer, but larger, components on it. There may be another separate smaller board that produces the high voltage for the display but it is probably OK but not receiving service voltage from the main supply.
If you can find an assembly number on the main supply, you may be able to buy or exchange it for a repaired unit and do the swap yourself.
Feb 09, 2011 | LG RU-42PX10 42 in. HD-Ready Plasma...
I'm dumb. Can I hook an inverater to my generator and produce more enegry than my generator produces???
Please understand that the generator produces power from fuel with an engine wheras the invertor is one which genrerates power from a stored battery using the principle of frequency switching a DC source to induct and produce AC.
Now you can have an uninterupted power supply setting with the invertor backed up by the generator so that when the battery voltage goes down you can start and charge the invertor and also supply the extra energy .
the ratings of both must also be considered.
Sep 25, 2010 | Electronics - Others
Tv keep going on standby when you turn it on
tv goes into standby all the time if a power supply is not fine, what happens is that a power supply produces two voltages, one small one powers a standby components and bigger voltage powers a line transformer which later produces more small voltages,
then later cancels the first small voltage.
chec your power supply semi conductors like, transistors, diodes and small value resistors, on your power supply. some power supply uses a IC to oscillate a ht. so check a supply at a w/shop.
Feb 07, 2009 | Goodmans 257NS 20" TV
Problem with toshiba BD6560
replace the developer and use ur enlargement feature
Jan 10, 2009 | Toshiba 6560 Copier
Low voltage
Most generators use a flyball type governor within the engine to control rpm; also there is a voltage regulator that tries to maintain voltage at about 115v. The voltage regulator varies the voltage to the armature increasing /adjusting magnetic force. Use a meter with htz or freq setting to adjust engine governor to 60 cycles. When the generator is producing 60 cycles, the engine should be turning 3600 rpm, max power range. At 3600 rpm the voltage should be 115 to 120 volts. Loading the generator will cause governor to try to maintain 3600 rpm. Check engine manual for proper adjustment of gonvernor and linkage. The governor mech should last the life of the engine, however governor system does wear out. Expensive repair. enjoy
Nov 26, 2008 | Yamaha Electrical Supplies
Canon NP 6050 Copier Logo
121 people viewed this question
old marine
old marine
