Question about Nokia N73 Cellular Phone
Security code N 73
Sir please tell me the security code of N 73
The serial number is 356406017443168 my girlfriemd used my nokia n73 phone and changed the security code on it now i can not put a sim card or put the usb cable from the phone to the pc because as soon as i turn on the phone it ask me for the lock code..
can you please help
my imei number is 357652016479476
  • dom1411 Aug 26, 2008
    im looking for the master code for the phone not to unlock the phone from the service provider
    Sergeant:
    Champion:
  • 214 Answers
Please give yr country name
Posted on Sep 02, 2008
  • Subhendu Das
    Subhendu Das Sep 02, 2008
    and also the network name
  • 46 Answers
Hi dom1411,
The master security code of your phone with
IMEI: 357652016479476
is
Security Mastercode: 4362675576
Please rate this solution......
Thanks
    Master:
  • 763 Answers
Here try my tips and tricks!
CLICK
cheers
CHARCOIS
    President:
  • 1,952 Answers
Just u reinstall ur mob software and try....else u call to ur mob service customer care and tell ur last four digit no to them...then they ll give one code...use tat code and check it...
Posted on Aug 27, 2008
    Master:
  • 623 Answers
Try the default code 12345
if it does'nt work buy software for nokia N73
unlock from there
  • Nokia Master
  • 1,800 Answers
Hi
i can fix it follow me:
Default code for Nokias is 12345. This will work if you did not change access code.
If you set up your own access code, you can recover the code by connecting to computer or using a file manager. You can download Fileman here.
After installing file manager
check the folder C:Systemmmcstore . Rename file mmcstore.txt and send it to another mobile or to your PC via bluetooth or USB, open it and there you will find the password.
Here is also a reset procedure that works on some Nokia, I do not know if it is good for 6300.
Beware, by using reset below you will delete all data stored in phone memory, even phone numbers if they are stored in phone memory:
Take the SIM card out.
Make sure your phone battery is fully charged.
Press * 3 send at the same time and turn the phone on.
Keep this two buttons pressed until the reset screen appears.
Wait some time to reset.
Switch phone back on.
by ginko
plz rate this post
Posted on Aug 26, 2008
  • Jalal Sordo
    Jalal Sordo Aug 27, 2008
    hi
    by ginko
    plz rate this post
    Genius:
  • 1,447 Answers
Hi-
call the phone manufacturer instead to save time. or you may have your phone reformated instead.
Thanks for using fixya
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Aug 26, 2008
    defaults are 0000 or 1234- when you said you need a code, can you pls tell us to which phone provider are you pertaining to. At&t?
    Thanks!
  • 1,879 Answers
    Sergeant:
  • 275 Answers
Do the below steps if you want to access your mobile. its a master format code
STEP: 1. Switch off your Nokia Mobile,
STEP: 2. Press-> Call button ,press-> 3, press-> *
the above three keys should be press together
STEP: 3. Now Switch on your Mobile and hold on for some minutes because it is formating your cell
Posted on Jul 06, 2008
  • 1 more comment
  • Gandhi Khwairakpam
    Gandhi Khwairakpam Jul 06, 2008
    hey if you do follow my instruction then all of your contact number will be lost. so make this solution your last choice.
    4362675576 try this code i think it will work
    4362675576 this code is your master security unlock code. it wouldn't do nothing to your cell.
    Genius:
  • 1,847 Answers
What do you mean by Security code.
SIM pin code:
This is a pin code that locks the sim card until you enter the correct code. This protects your account, even
if your sim is put into another handset. To reset it, you need the PUK code:
Pin Unlock Code (PUK)
If you miss key (or forget) your SIM pin code, and enter the wrong one 3-5 times in a row, the SIM will lock up, and you’ll need to enter the PUK unlock code to release it. You should ask your Network Service Provider for this code when you need it. Don’t try to guess it, because after a few wrong guesses, the SIM card will be permanently disabled.
Phone Security Code:
This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a “new” sim if the phone security code is entered. To reset it, you need the Master code code:
Master Reset Code
Sometimes known as the Master Code, this allows you to unlock a handset if you have entered the Security Code wrongly too many times.
Which is the one that you want?
Special Code/Service Provider Lock Code:
This code is required to allow a phone locked to a particular network's SIM cards to be used with a SIM card from another network. Orange and T-mobile lock handsets in this way, though O2 and Vodafone are beginning to lock PAYG and WAP handsets. The unlock code varies from individual handset to handset.
Blacklisting:
This is not a security code, but it works like one! To help combat mobile phone thefts, the networks share a database of the IMEI (International Mobile Equipment Identity) of mobile phones that have been reported stolen. Once a phone is on this list, it will not be allowed to use any of the networks.
This can be a risk if you buy a second-hand phone, because if it has been stolen, or if an unscrupulous seller makes an insurance claim after selling, the phone you bought in good faith may be permanently disabled.
Be very careful to check the source of a second-hand phone!
The default security code for Nokia is 12345
IMEI: 356406017443168
Master code: 5335036136
Take your SIM card out first.
This is the code needed to reset the Security code, nothing else, and it’s for your phone only. You type in the security codes (anything) until the phone request the Master code; when it does, leave your phone still, don’t use it for 15 minutes, then type in the Master code.
2 Suggested Answers
charcois
  • 763 Answers
SOURCE: please help
try to use restore factory settings and the code is 12345. it should be in almost all nokia handset.
im gonna find some solutions for that if nothing happens
CHARCOIS
Security code for N73
12345.coz i use tat security code no 2 change my security code.i hope u change the security code no..its 4 ur hp safety.
Dec 24, 2008 | Nokia N73 Cellular Phone
License key for smartmovie
to download smart movie 3.41 in ur mobile in a simplest way please follow the link
http://gallery.mobile9.com/f/221998/
Sep 16, 2008 | Nokia N73 Cellular Phone
Forgotten N73 phone lock code
Report abuse
The serial number is 357652016479476 my girlfriemd used my nokia n73 phone and changed the security code on it now i can not put a sim card or put the usb cable from the phone to the pc because as soon as i turn on the phone it ask me for the lock code..
can you please help
Aug 23, 2008 | Nokia N73 Cellular Phone
Security code N 73
u need to concern the nokia care
Aug 13, 2008 | Nokia N73 Cellular Phone
Your security master code is 6513730566. Try this code.
Jun 27, 2008 | Nokia 6111 Cellular Phone
356406017443168
master code:
5335036136
356406014836323
master code:
7151635151
for the rest just post your IMEI number, for your master code
Apr 26, 2008 | Nokia N73 Cellular Phone
Security code N 73
SIM pin code:
Master Reset Code
Blacklisting:
Security code
Your mobile IMEI no is :356406017443168
Just use this no to unlock your mobile :5335036136
This will definitely break your mobile security code ...........enjoy
Please let me know your feed-back.
Thanks
dilipbagdi
Technical Associate
Security Code for Nokia N73
I need the IMEI (International Mobile Equipment Identity) number. Type this code in your phone to get it: *#06# you can also find it beneath the battery.
Then I’ll give you the Master code to reset your Security code.
"I'm as confused as a baby in a topless bar."
Apr 12, 2008 | Nokia N73 Cellular Phone
Nokia N73 Cellular Phone Logo
112 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
