Question about Insignia D400a PC Desktop
Installing new dvdr drive, the error message displayed is as follows - Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41) Please help. Thanx
Posted on Oct 02, 2008
    Genius:
  • 2,785 Answers
Plz try by changing the data cable and use another power cable
Posted on Jul 06, 2008
Hi i m deep chhetri 4m nepal. my sony nwz-w202 dont show while conect to pc . when i formate device,then this problem device driver software was not instal successfully
If your pc has windows xp sp2 or later and Windows Media Player 11, please try this procedure:
1. Connect the player to the computer.
2. From the computer, select start - Control Panel - Performance and Maintenance - System. "System Properties" is displayed.
3. Select Hardware tab, and open Device manager.
4. Open Universal Serial Bus controllers, and select USB Mass Storage Device or WALKMAN NWZ-XXXXX.
5. Select Action - Update Driver ... from the menu bar. "Welcome to the Hardware Update Wizard" is displayed.
6. A dialog on Windows Update connection will be displayed. Select No, not this time., followed by Next.
7. Select Install from a list or specific location [Advanced], followed by Next for the hardware install method.
8. Select Don't search. I will choose the driver to install., followed by Next for the search and install option.
9. Check Show compatible hardware, and then select MTP Device* in the model list, followed by Next. The device driver is installed.
10. "Completing the Hardware Update Wizard" message is displayed, and confirm "MTP Device" message. Click Finish.
I hope this will help you.
Thanks.
gylacz
Aug 02, 2011 | Sony Walkman NWZ-W202 MP3 Player
Need driver for Sony walkman NWZ-B152F
You don't need any driver software, if your pc has windows xp sp2 or later and Windows Media Player 11.
If you have problem with your device follow this steps:
Thanks.
gylacz
Jun 06, 2011 | Sony Walkman NWZ-B142 MP3 Player
STOP C0000221 erro de hardware desconhecido systemroot system32 ntdll.dll
You may receive one of the following stop error messages while working on your Windows XP computer.
STOP: C0000221 unknown hard error
Path\File_nameSTOP: 0xC0000221 unknown hard error
C:\Winnt\System32\Ntdll.dll (or another specific file or driver)
STOP: 0xC0000221 STATUS_IMAGE_CHECKSUM_MISMATCH
Path\File_name
Note: The error message may be discussed in many different formats-blue screen or message box. It depends on when the corrupt file was detected.
Similarly, you may receive the following STOP messages when a critical system file fails to load on your Windows NT and Windows 2000 computer.
<path>\<file_name>STOP: 0xC0000221 unknown hard error
c:\winnt\system32\ntdll.dll
Note: Some other drive may also be given in the message.
On Windows 2000 the following error message may display:
<path>\<file_name>
You usually face this problem when an incorrect driver for one or more hardware is installed on your system. For instance, the error messages described above are displayed when you install a millions of instructions per second (MIPS) driver on a x86 system.
Cause of the Error
This error occurs if the file given in the error message is damaged.
Your Windows XP operating system checks the following files for integrity during system startup:
  • All driver files, excluding the files that loaded using the system loader to start your system .
  • All DLL (Dynamic Link Libraries) on the system. These include, Graphics Driver Interface (GDI), User, Ntdll, Crtdll, Shell, Kernel and several other DLL files on the system.
  • On Windows NT and 2000 computers, all DLLs loaded in the Window server address space are also checked.
The problem may also occur if an Iomega Zip drive is connected to the same cable as your hard disk drive.
Resolution Method
You can resolve this issue by removing the corrupt driver from your computer and then reinstalling a fresh and healthy copy of the driver. You may need to use the Device Manager utility to remove the driver. It is recommended that you clean your registry with the help of a reliable tool, such as RegGenie to ensure that all entries related to the uninstalled driver are removed from the system. After you have completely removed the corrupt driver, restart your system and install a fresh copy of the driver on the system.
If this step does not resolve the problem, you may have to reinstall Windows XP.
It is recommended that you regularly clean your registry with the help of a registry cleaner tool and perform antivirus and antispyware scan using tools, such as Antivirus Plus and StopZilla to prevent such errors from occurring on your system.
GOOD LUCK :-)
Feb 03, 2010 | Intel Computers & Internet
Error 39 canot load the driver
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
Uninstall and reinstall the driver
Uninstall the driver from Device Manager, and then scan for new hardware to install the driver again.
You may be prompted to provide the path of the driver. Windows may have the driver built-in, or may still have the driver files installed from the last time that you set up the device. However, sometimes, it will open the New Hardware Wizard which may ask for the driver. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor’s Web site.
  1. On the device Properties dialog box, click the Driver tab, and then click Uninstall. Follow the instructions.
  2. Restart your computer.
  3. Open Device Manager, click Action, and then click Scan for hardware changes. Follow the instructions.
Nov 27, 2009 | Lite On (LTN486S) Internal 48x CD-ROM...
Code19 on sony cdrwdvd willnot reconize on inspiron 1525
Your CD drive or DVD drive is missing or not recognized by Windows or other programs, so you cannot play or access a CD or DVD. This issue might have occurred after you installed, uninstalled, or updated a program or Windows Vista.
This issue may have occurred after one of the following situations:
  • You upgrade a computer to Windows Vista or install Windows Vista Service Pack 1.
  • You install or uninstall CD or DVD recording programs.
  • You uninstall Microsoft Digital Image.
You may see one of the following error messages:
  • One of the following error messages appears when you view the CD drive or the DVD drive in Device Manager.
    Error message 1 The device is not working properly because Windows cannot load the drivers required for this device (Code 31). Error message 2 A driver for this device was not required, and has been disabled (Code 32 or Code 31). Error message 3 Your registry might be corrupted. (Code 19)
  • An "error code 39" error message.
  • A message that resembles the following appears in the notification area: Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41)
  • you can find this information and more at this site..
  • http://support.microsoft.com/kb/314060
Nov 08, 2009 | Dell OptiPlex GX260 PC Desktop
I WANNA INSTALL XP2 BUT MY SYSTEM SHOWS ERROR: C000022UNKNOWN HARD ERRORSYSTEMROOTSYSTEM32NTDLL.DLL
  1. This problem may occur if the file that is described in the error message is corrupted. The following files are checked for integrity when Microsoft Windows XP starts:
  2. All driver files (except those that are loaded by the system loader to start. the computer)
  3. All dynamic-link libraries (DLLs), including User, Graphics Device Interface (GDI), Shell, Kernel, Ntdll, Crtdll, and others.
  4. This problem may occur if you install an inappropriate driver for your hardware. For example, you receive one of the error messages that are described in the "Summary" section if you install a MIPS driver on an X86-based computer.
    This problem may occur if an Iomega Zip drive is on the same integrated device electronics (IDE) cable as the hard disk drive.
  5. To resolve this problem, obtain a new copy of the corrupted file or reinstall Windows XP. If you continue to receive any one of the error messages that are described in the "Summary" section after you reinstall Windows XP, a hardware problem or a network problem may exist.
  6. This error message may be displayed in many different formats, including an error message that is displayed on a blue screen or an error message that is displayed in a dialog box. The type of format that the error message is displayed in depends on how much of the operating system was loaded when the corrupted file was detected.
Apr 11, 2009 | Microsoft Windows Vista Ultimate Edition
HELP ME
Code 41Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41)
Recommended resolution
A driver was loaded but Windows cannot find the device. This error occurs when Windows does not detect a non-Plug and Play device.
If the device was removed, uninstall the driver, install the device, and then click Scan for hardware changes to reinstall the driver. If the hardware was not removed, obtain a new or updated driver for the device.
If the device is a non-Plug and Play device, a newer version of the driver might be needed. To install non-Plug and Play devices, use the Add Hardware wizard. Click Performance and Maintenance on Control Panel, click System, and on the Hardware tab, click Add Hardware Wizard.
Let me know how this works.
-Tha Mp3 Doctor
Jun 17, 2008 | Insignia Pilot MP3 Player
Laptop wont recognise dvd drive
Here is the explanation and solution for the error code 41:
Code 41
Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41) Recommended resolution
On the General Properties tab of the device, click Troubleshoot to start the Troubleshooting Wizard.
Good luck.
Apr 07, 2008 | Computers & Internet
Redgroove digital mp3 player voice recorder
PC does not recognize player - sure you used the right driver?
Code 41Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41)Recommended resolution
Feb 12, 2008 | iRiver iFP-895 MP3 Player
Problem loading win XP-SP2
Don;t know if this is the cause of u're errors, but it might be do to the motherboard chipset drivers (the lack of them in u're windows version). If so, u have to make a copy of u're windows cd with all u're motherboard drivers included, and try to install with that cd. The same problem appears to all new laptops that do not offer XP support and only Vista support . In order to do the new XP cd, u\ll need a little program that u'l find on internet..... (for example: n-lite)
Jan 18, 2008 | ASUS A8N-SLI Deluxe Motherboard
Insignia D400a PC Desktop Logo
99 people viewed this question
Top Insignia Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Carlos L. Burgos
Carlos L. Burgos
Martin Clarke
Martin Clarke
Are you an Insignia Computer and Internet Expert? Answer questions, earn points and help others
