I have a foxconn base unit and i have had to move the motherboard into a new case however when i plug all the wires onto the motherboard its not switching on have i plugged the wires in correctly or could the motherboard have blown ?
    Genius:
  • 2,785 Answers
Plz check take out *********** board and keep a paper below and try to boot, if it is booting then your motherboard is touching with some metal part, if not then check the power supply, if it is ok then *********** board is gone
Posted on Jul 06, 2008
DIY foxconn tower caseTSAA891 connection to abit NF7-S Motherboard
What are you asking for assistance with? Connecting the wires (if so which ones) or finding a manual?
What cables are you having trouble with? If it is the power supply cables you are having problems with, bear in mind that most modern motherboards/PSU's use a 20+4 pin arrangement. Some older PSU's have a different connector.
It could be that you need to update the PSU to match the requirements of the motherboard
Oct 11, 2007 | Computers & Internet
Gateway dx4300
One of two possibilities; the Motherboard or power supply. In my case it was the Motherboard. Those cheap capacitors tend to go bad over time without being used. I purchased a replacement motherboard(Foxconn RS 780 "bengal") from a place in WI. Skyline on Ebay. I would do a search on Ebay for Gateway Foxconn Bengal RS780 Motherboard. Then get the number and call. You can use the old processor, ram, and maybe the graphics card, but I'd run the onboard graphics first(if you do happen to have replaced the motherboard) to make sure the graphics card isn't causing an issue. You will need to do some research and reading on the net about installing new motherboards and hardware. If the motherboard is the same, Windows should still work with it. Do your homework first as this is only a suggestion as to your problem. It is what happened to my Gateway DX4300-03. Check all power supply related, graphics card and wire connections first before you consider the motherboard thing.
Oct 12, 2012 | Gateway DX4300 Acer Foxconn Bengal RS780...
Sound cable connection
Look more closely at your motherboard, for a 4-pin "PC Speaker" label.
The "HD Audio" is _OUTPUT_ (left front, sub-woofer, right front, left back, right back) to Surround Sound speakers.
Dec 31, 2009 | Foxconn (945G7MA-8KS2) Motherboard
Connect power swithc and led cables to foxconn n15235
Still have your Foxconn manual? Turn to page 19. See figure FP1.
Download manual from Foxconn, click on the link provided;
http://www.foxconnchannel.com/en-us/product/Motherboards/detail_overview.aspx?ID=en-gb0000154
System cases vary when it comes to wire colors. The most common wire colors for positive are, solid blue, light blue, solid red, solid green, light green. Negative wire colors. Each led, IDE-LED, Reset, PWR-LED and PWRBTN should share a negative colored wire. Common is the solid color white but this can vary from case to case.
Mike
Nov 10, 2009 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Front panel connections
can someone help me on how to wire fp1 on foxconn motherboard
Sep 16, 2008 | Foxconn 848P7MB-S Motherboard
MoBo Winfast 6100M2MA-RS2H
This board is made by FoxConn.
Looking up towards the CPU from the bottom the front panel connector is the third connector up from the bottom right and/or should be labeled as show.
This motherboard is made primarily by FoxConn
This is the link to the English Manual download page.
Regards,
Worldvet
Jun 17, 2008 | Computers & Internet
Toshiba Satellite P105 S6124 Power goes off. Jiggling electrical cord at base of computer gets it back on but when it's moved, it goes off again. Someone looked at it and tried a new cord. Determined...
First, the power cord connects to the Power Unit not the Motherboard, so if jiggling the wire causes the fault, it is either the Power Supply Unit or just the plug and wiring that the power cord plugs into.
If you must open the casing, try replacing the Power Unit, but the best solution is to get a computer repair person to look at it.
If you pull the unit apart and start poking around in there, you will almost certainly blow something up with static electricity (and then maybe your Motherboard will need replacing!). Note The voltage of Static Electricity (which you probably can't feel) is THOUSANDS of times higher than the Voltage that your computer components runs on. For comparison connect up a Mains Supply to a 12 volt globe and see what happens (and this is only 10-20 time higher than the required voltage.
Good luck.
Apr 13, 2008 | Computers & Internet
Foxconn moterboard
Does the system not even start up the power supply? That most likely means you've wired up your power button incorrectly. Also it could be possible that you're grounding the motherboard to the case. Make sure it is screwed onto the case correctly.
Aug 06, 2007 | Foxconn 845GV4MR-ES Motherboard
Computers & Internet Logo
David Payne
David Payne
