Screen aspect ratio change
Hi Latoof:
Many thanks for your helpful comment. Unfortunately I don't have the F key you describe on my keyboard. Can you advise exactly which keyboard (make, model) your wife has.
Thanks again, Chris.
    Sergeant:
  • 287 Answers
The k/b is the standard one on the latitude 630 I think... unfortunately she is away so I cant look at it till end of week. Its' F4 or F5 from memory but it would be pretty obvious if your laptop has it I'm sure... Will try and finfd the manual though so stand by
Posted on Jul 06, 2008
  • Dave Jul 06, 2008
    I cant find the manual yet.
    what are you trying to display in the 4:3 format?
I installed VLC on my netbook, but cannot get it to work in full screen mode. It appears in a small square in the centre of the monitor screen. When I opt for full screen mode the picture does not...
Welcome to Fixya. If you want to enlarge the picture or change the aspect ratio just press "A" on the keyboard. However the picture quality will change depends on the resolution of movie that you're playing
Thanks for using Fixya.
Mar 19, 2011 | VideoLAN VLC
Have bought a second hand philips 28pw6506, it has no remote control. Do you know how to change the aspect ratio or size of picture on screen? Have looked through the menus with the button on top of the...
Hello
To change its picture aspect ratio, you have to go to its menu. As you haven't its remote control there is an option for that, mentioned in its user manual. I hereby send it to you. Do the same and access the aspect ratio.
The television set has 4 keys which are located
on the front or the top of the set depending
on the model.
The VOLUME - + (- Vol +) keys are used to
adjust sound levels.The PROGRAM - + (- P +)
keys are used to select the required programmes.
To access the menus, simultaneously hold down
the VOL- and VOL+ keys.The PROGRAM - +
keys may then be used to select an adjustment
and the - VOL+ keys to make that adjustment.
To exit from the menus, hold down the 2 VOL-
and VOL+ keys.
Note: when the Child Lock function is activated,
these keys are unavailable
OK.
Dec 21, 2010 | Philips 28PW6506 28" TV
Cannot change aspect ratio when im playing a game it cuts off part of the screen
Normal aspect ratio is 4:3, and the wide aspect ratio is 16:9. If you play a game meant for 4:3 and you change the TVs aspect ratio to 16:9; part of the picture will be cut off. It is not the fault of the TV.
Oct 15, 2010 | Sanyo DS27800 27" TV
Cannot change aspect ratio of picture when ratio button is pressed on remote. Batteries in remote are good. Everything else on remote works. Sony KP-57HW40
If you are connected to a HD cable or satellite box, the aspect ratio is set by that box. If it is set for 1080i 16:9 wide screen mode then your TV is locked at that ratio. This is good considering you have a Hi-Scan 1080i television in the Sony KP57HW40. Please take a moment to rate my answer. Thanks...
Nov 24, 2009 | Sony KP-57HW40 57" Rear Projection...
How to adjust aspect ratio on Mitsubishi VS-6043 TV?
I have the same problem and the only thing I could do was to change the name of the input on your tv to pc on the menu screen and it should set it to 1080p reduced this will fit the whole picture and set your screen res on your computer to 1920x1080
hope this helps
Aug 01, 2009 | Mitsubishi VS-6043 60" Rear Projection...
I cannot change the aspect ratio on the TV. When I go to the menu, Aspect Ratio is in red and I cannot select it. On certain channels the screen is too big and I can't see the edges of the broadcatsed...
This is a quote of what Sanyo told me: "The aspect ratio can only be changed when the unit is in the video mode." So I tried switching modes with the input button and it worked but went to like a letter box/wide screen type of picture, which doesn't help me. We have dishnetwork and on the Panasonic plasma we can adjust the ratio with their remote so I have two options there but not with my Sanyo unfortunately. Hope this helps
Jul 22, 2009 | Sanyo DS24425 24" TV
Panasonic SC-PT460 - Little black box covers half of screen
Can you describe the 'box'? Is it the top half, bottom half, a little of either? What kind of TV do you have?
I suspect you might be noticing the aspect ratio of the various source programs being presented differently on a wide screen than you are used to. DVD programs come in a variety of aspect ratios. Normal TV is 4x3, that is, 4 units wide versus 3 units tall. Wide screens are more like 16x9, so a 4x3 image presented properly on a wide sceen would have black vertical bars on both sides. That is normal.
Some people are offended by the black bars and TV's are unfortunately designed to allow gross modification of the image to fill the space. That is akin to taking a photo of yourself and stretching it to fit an improper frame. That probably wouldn't be very flattering to you and certainly wouldn't be accurate. Which is more important - the picture or the frame?
Apr 08, 2009 | Panasonic Audio Players & Recorders
I cannot get the entire picture to fit on the tv screen
unfortunately we now have four different aspect ratios, only one of which works properly on any given screen.
If you have a "picture" button on your remote, keep pressing it until the screen changes. You will have to find the correct aspect ratio in your menu settings. It is the only way to correct this
Jan 17, 2009 | Televison & Video
Aspect Ratio not responding/always in "Full" mode
Normally, when I see this problem in the customer's home, I find the main culprit to be the cable box. The remote for the cable box may have a button on it to change the format or picture size. You may have to go into the menu of the cable box to change the format setting. Hope this helps.
Apr 22, 2007 | Panasonic TH-42PWD8UK 42 in. EDTV-Ready...
Prob. with aspect ratio
The key word here is dropped,was the unit ok before? how hard was it dropped? if the tv is only a 4:3 screen then it can not give you a 16:9 AR unless the dvd can change that, it probably has the main circuit board broken somewhere and it needs professional help.Let's hope is not major damage.
Sep 19, 2006 | JVC AV-27D303 27" TV
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
