Your camera is programed for SD memory cards from 8MB through to 2gig if you have put a SD card in the camera larger then 2gig it can't read it. If you are under the 2gig maximum then it's possible the SD card is in the lock position. At the top left corner there is a little white slider type switch make sure this switch is pushed forward to the top of the card in the direction of the gold contacts. Also a new card will need to be formatted for the camera to read the card properly. See page 11 screen shot I have provided for correct card installation.
Also page 12 for the formatting of the memory card.
Hope this is a help Robert in Canada
"No SD memory card inserted" messages appears when using digital cameras,
"A media card hard been inserted that contains errors. Do you wish to repair the Media Card now?"
You can read the files on SD memory card, but you cannot write new files or you cannot edit files on SD memory card,
"Access denied", when SD card is corrupted or broken,
you can fix sd memory card errors first and them format you sd card.
