Scanner Canon 3200F using ScanGear CS software at some stage decided to show this fault: Cannot scan for these reasons: - The Original may no be set correctly - The Film Adaptor Unit Protective Sheet may be put in place - The Lamp may not be warmed up. (it needs a few minutes adjusting lamp on low temperature) Scanner driver will be closed. Code: 2,178,8 My findings are that NONE of the above are happening! Thanks for your help C.
  • gregacom Dec 20, 2008
    Code: 2,178,8
    Gr
  • Anonymous May 18, 2009
    Same problem
Do you scan on automatic mode?
Posted on Feb 24, 2009
The problem went away for me, when I reset the error message on my MP830. In this case, the message was that I was out of ink. Not a problem for scanning, yet this gave me the "lamp" message. Reset the message by pressing the "OK" button.
Posted on Nov 09, 2008
I want you people to teach me how to install and to use a network scanner on canon IR2520.
Install the scanner driver (Canon Network ScanGear) found on the bundled CD. I assume you already assigned an IP address on your copier. Run the Network ScanGear software, the one you installed earlier. Click Discover or you can manually type the IP address of your copier. If your copier is discovered, click Test Connection. Remark is displayed that your scanner is ready to use. Click OK to save the settings.
Now, run 3rd party software (eg Photoshop). In File > Acquire > (Select Canon Network ScanGear). A window will pop up and you are ready for scanning. Note: If error "Scanner is offline" occurs, go to your copier and press Scan > Remote Scan > Online.
Jul 06, 2011 | Canon iR 2016i Black and White Copier
Windows 7 does not detect CanoScan 3200F using its drivers.
Downloading Canoscan Toolbox is required in addition to the driver.
Oct 31, 2009 | Canon CanoScan 3200F Flatbed Scanner
How to get ScanGear Software?
www.canon.usa it is part of the original installation CD for your scanner
Jul 06, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Network ScanGear can't discover Canon IR 3220
Had the same problem with my Canon IR2018i... After spending about all day stuffing around and ready to give up... I read in the Color Network Scangear User Manual that
"Only scanners on the same subnet (network with the same network ID) as your computer are displayed in the list"
So I went the the TCP/IP settings on my copier and changed my subnet mask from 255.255.255.0 to 255.255.255.255 and magically my scanner appeared....
Give it a go...
Jun 24, 2009 | Canon Office Equipment & Supplies
Need a driver for a CanoScan N670U Scanner for Mac 10.5 OSX
Basically you should not scan through Photoshop but should use your scanning software as a stand-alone application
Apr 23, 2017 | Canon CanoScan N670U Flatbed Scanner
Canon ScanGear CS driver error Code: 2,252,0 - Can't preview Actually I have the Canon CanoScan LiDE 80 Flatbed Scanner - but this wasn't presented as an option, so I thought I'd try the nearest...
Canon ScanGear CS driver error Code: 2,252,0. Error when trying to Preview scan using ScanGear in your program, e.g. Word, PhotoShop...
I had the same problem, Canon Technical were clueless on this error code. Yes the problem occured when trying to preview first however I could scan but without any preview, pointless really.
I have fixed it for Windows Xp SP3, Canon Lide 80. To Fix:
You need to download the latest ScanGear driver and Deldrv.exe from the canon website. You don't need the Toolbox, http://software.canon-europe.com/
It would help if you have Tuneup 2009 (even Trail version) for the later parts of this fix: http://www.tune-up.com/download/ just click download, you don't need to give them your email address.
1. Save these on C:
2. Remove the USB cable from your scanner - make sure it is unplugged.
3. Run Deldrv.exe, select your scanner and uninstall.
4. Now you will need to go into 'C:/WINDOWS/TWAIN_32' folder; you must remove anything in this folder - safest thing to do is CUT any items and paste them on the C: or personal folder.
5. Now the register parts - you need to purge your registry of any left over values. I found out after several attempts that this final step fixed the problem for me.
Basically through Windows XP Regedit or TuneUp Reg Editor search the ENTIRE registry for first 'ScanGear', second, 'Canon' and third if you have installed previously, 'Canon Toolbox'. Find any entries relating to any Canon scanner software and delete them. I only found around 6 or 7 entries to remove.
6. If you have TuneUp run '1-Click maintence' (correct problems) and afterwards run the 'Register defragger'. Restart.
7. On the next bootup your register should be optimised. Ok, disable any Anti-virus software.
8. Run the scangear setup winzip file you saved on C:. * it will extract a folder to C:. If get an error with the extraction, try running it anywhere else except C drive. Alternatively if you have WinRar, right click and manual extract contents. The scangear setup winzip file/folder (called lide80vst7250a_xpen) only contained a readme and setupSG.exe.
9. You must run the setupSG inside this folder. And you're done. Enable your anti-virus.
9. Now connect USB to scanner, Windows should pick it up. Open Word or PhotoShop > run the scangear program to preview.
10. Done! It worked my end.
Please let me know if this helped you.
Mar 14, 2009 | Canon CanoScan LiDE 70 Flatbed Scanner
I want to download driver cd for CanoScan 3200F.
Go to:
http://software.canon-europe.com/products/0010013.asp
Select your operating system and preffered language for the driver installation and a link will pop up.
Mar 10, 2009 | Canon CanoScan 3200F Flatbed Scanner
Scanner started scanning color photographs in black and white
The problem is simple.Someone or somehow the "TYPE OF ORIGINAL" option on ur SCANGEAR CS window.Set it back to "MAGAZINE" or "PHOTO" and it should scan in color.
Oct 07, 2007 | Canon CanoScan LiDE 70 Flatbed Scanner
738 people viewed this question
jasbo
jasbo
