Fault is the circular element found the fan. take back plate off inside oven and element is exposed. often but not always, you can see the damage to the element. element is easy to replace - usually held in by 2 - 7mm nuts on posts from the element base plate
If the fan is working o/k then it is likely to be a faulty oven element if it is a
electrically heated oven.
If it were the timer, not even the fan would work.
fan oven element video.1, If the fan motor . in the
back of the oven is going round and the temperature light is on (normally
little red light), but there is no heat then you will probably need a new oven
element, these are generally very easy to fit and readily available from our
website these can be tested with a electric meter. To gain access to the element .you will
have to remove the back plate from inside the oven. Once removed you will see
the fan and element,. if you
look closely at the element .you will
probably see a small hole burnt in it where it has blown. Sometimes however
there is no evidence of a fault but the elementis open circuit ie:
broken inside the element casing, either way it will need replacing. Some
elements will are fixed from inside the oven and some are held in place by nuts
from the rear of the machine. 2, If your fan oven is getting warm but takes a very
long time to cook or is burning the food more on one side than the other, then
you need to check if your oven fan motoris working you will
see the blade turning fast if it is ok. if the element is heating but the fan motoris not blowing the heat into the oven then
you need To replace the oven fan motoris a little more
expensive and a bit more involved. 3. If you have the opposite problem ie: your oven is over heating
and burning everything then you will need to replace your oven thermostat 4, A quite common and easily overlooked answer is if your oven
is not working at all ie: no heat and no fan then the chances are that someone
has put the oven timerinto AUTO mode,
simply put oven back to MANUAL mode and all should be working again. For all Free appliance repair videos visit our VIDEO
TUTORIALS
The power to the fan and thermostat is the fault. You will need to trace wiring from these elements to power source and I suspect that where the power cord meets the oven is where you'll find the cause.
one of three things are possible:either you are missing part of your 240volts at input power,or a bad neutral power wire to heating element,an oven temp control,or the thermocouple that controls oven temp
Forall Free appliance repair videos visit ourVIDEOTUTORIALS A fan oven that has stopped heating up is probably the mostcommon oven fault that professional engineer is called to. The cause inmost cases is simply a faulty fan oven element. To employ the services of arepair company is going to cost you in the region of £60 - £100 to complete thejob. With a little time, though and our FREE fan oven element videoitshould take less than half an hour to repair, and the element can be purchasedfrom us for as little as £20 ! Why not Save yourself some money and read on 1, If thefan motorin the back of the oven isgoing round and the temperature light is on (normally little red light), butthere is no heat then you will probably need a new oven element, these aregenerally very easy to fit and readily available from our website these can betested with a electric meter. To gain access to theelementyou will haveto remove the back plate from inside the oven. Once removed you will seethe fanandelement, if you look closely at theelementyou will probablysee a small hole burnt in it where it has blown. Sometimes however there is noevidence of a fault but theelementis open circuit ie: brokeninside the element casing, either way it will need replacing. Some elementswill are fixed from inside the oven and some are held in place by nuts from therear of the machine. 2, If yourfan oven is getting warm but takes a very long time tocook or is burning the food more on one side than the other, then you need tocheck if your ovenfan motoris workingyou will see the blade turning fast if it is ok. if the element is heating butthefan motoris notblowing the heat into the oven then you need To replace the ovenfan motoris alittle more expensive and a bit more involved. 3. If you have the opposite problem ie: your ovenis over heating and burning everything then you will need to replace youroventhermostat 4, A quite common and easily overlooked answer isif youroven is not working atall ie: no heat and no fan then the chances are that someone has put the oventimerinto AUTOmode, simply put oven back to MANUAL mode and all should be working again.
It sounds like you have either one of the following things that need attention. First, turn off both breakers to the oven and then back on. Next check the wiring from the receptacle to the back of the oven. Next, check your internal fuses. Most ovens have them. Last, check the wiring to the elements and control switches. Somewhere you have a wire burned off the terminals or control switch. That smell you referred to is probably one of the wires that may be burned.
i have had this problem twice. once was the heating element actually had shorted out because the little ceramic holders had broken, this necessitated getting new element. can be checked out with an ohmmeter by yourself or by taking element into appliance repair place. the other time, it was that the manual reset switch had tripped after a self-clean cycle. actually at the moment, that has happened again- design flaw perhaps in the RSD30 range? so anyone who can tell a reasonable competent refrigeration/HVAC technician where the manual reset switch is would be appreciated.
We have the same problem with our oven, AEG B2190-1.It started on on Christmas day[worst day of year]gets up to temperature after 10-15 minutes cuts out everything switches off until the oven has cooled down, The oven is only 18 months old. We have been told that it is a thermostat problem.
Thank you for your speedy reply
