Question about Whirlpool Dishwashers
Our whirlpool estate diswasher will not drain the water after a wash cycle. I have removed internal parts down to the drain and cleared the path. Moreover, I have removed the drain tube and clean it. Still water will not drain. I assume it is the pump. Can the pump motor be easily replaced? Thank you, Jim
    Sergeant:
    Champion:
  • 330 Answers
You hve to find the right pump first
Posted on Jul 06, 2008
My whirlpool Estate washer is not draining or spinning but aggitates, what can be the problem?
Sounds like a cycle switch problem. The switch is not turning and making contact with the next cycle. It needs to be changed!
Jan 09, 2013 | Whirlpool Washing Machines
My estate washing machine will not spin out, all of the other cycles work correctly.
Hello
Try to clean the magnetic door switch,some windex and a paper towell.Just do the part on the door or lid and where the lid meets the top of the magnet.Make sure this is not loose and is seated in the machine.
You may need to unplug machine and remove the door switch,take both wires and tie them togther so they make contact.Then try a wash cycle or try the spin cycle.
The door switches in the estate washers fall apart and get corroded and can stop the spin cycle.
If the machine works with the switch taken out then you will need to get a new one from whirlpool.
Mar 25, 2011 | Estate Washing Machines
Water does not drain completely in Estate Whirlpool top loading machine
Your drain pump is attached to the front of the drive motor.
The drain pump has lint/sock or some other garment stuck in it blocking water flow.
Remove the cabinet,then remove the drain pump to clear the blockage.
Cut and paste this Factory service manual to help in your repair.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Aug 08, 2010 | Washing Machines
Whirlpool washer machine model TAWX700JQ1 will wash cycle and will not go to next cycle and will not drain the water
I had the same problem, I replaced the timer part no 3953146 and that solved the problem.
Jun 12, 2010 | Whirlpool Washing Machines
Water won't drain after cycle is done. Leaves 1-2 inches of water in bottom. Checked hose and its clear. Put hose going to disposal in bucket and water comes out when diswasher is cycling
it is easy track this path of water from bottom of m/c it will b afilter then small hoses to drain pump thenouter hoses <
thanks
Jul 13, 2009 | Dishwashers
Dishwasher will not drain water. Put Drain-O in did not work,ran short cycle water on floor. HELP
My Whirlpool Diswasher did not drain water. The same water has been recycling from washing thru rinsing and sitting there after done.
Model: S62NXPLP-7624
Oct 03, 2008 | Dishwashers
Final spin cycle
Lots of possibilities to check out before considering a problem with the machine: Is the load unsorted, too big or off balance? Drain restricted or too high? Oversudsed? Water draining completely out before going into spin?
Jan 08, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Dishwasher will not run. clean light flashes seven times
I tried the button sequence described by guest #1 but nothing happened.... is there anything more to it?
Jan 20, 2007 | Whirlpool 24 in. DU1055XTP Built-in...
Dishwashers Logo
88 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
