Sorry to tell you this needs to have the code reset once you remove the battery the stereo needs to be reset only a garage can do that there is no doubt about it. Hope this helps Best wishes, Malcolm Campbell.
just replace it with a aftermarket stereo and dont forget to get both harness for easy diy install.thats what i did and it works fine & the best thing about it is i dont ever need a code again.
You need to get the code from the dealer to unlock the stereo. right now it 'thinks' it has been stolen (happens when the power supply is removed from the stereo).
Some radios have an antitheft feature bulit in. When the power is disconnected (like in replacing a battery or if the radio was stolen from a car) then you have to enter a code to activate it. Call the dealer and ask if they can help you with the code and proceedures. Your owner's manual should have the proceedure listed in it but the code should have been in the papers that cae with your car when it was new. Again the dealer is your best bet. They will need your vehicle VIN and maybe even the radio serial number
you will have to have the stereo removed by a dealer and show them proof of ownership of vehicle and pay them to get the codes and enter them the good thing is they will give you the code for your records so you dont have to do it again
Carefully remove the cloumn housin, there are two wires which actually go up into the steering wheel if so disconnect them, if it has stereo controls etc on the the wheel, there is a plastic pushfit connector. Disconnect it. Behind the wheel the should be 4 bolts, undo the bolts and carefully, with a soft robber hammer, tap the wheel off the spline.
