Question about Konica Minolta magicolor 2430 DL Laser Printer
Toner replacement The plastic tab that one pulls to lift out toner module has detatched from module. How can I lift out module without it? Any tips?
  • Konica Minolta Master
  • 19,396 Answers
Grab the toner on two sides using two screwwdrivers
Posted on Jul 06, 2008
Change toner
Step 1 Check the top of your Canon fax/copy machine to see if your specific model has a protruding extension piece from the plastic delivery tray. Push the extension piece down if one is present on your model.
Step 2
Grip the bottom edge of the paper delivery tray at the front of the machine. Lift the tray upward to reveal the rectangular, plastic toner cartridge inside the machine.
Related Reading: How to Add Toner to a Canon X25
Step 3
Grab the handle at the top of the current toner cartridge and lift the cartridge upward. Pull the toner out of the machine and set it aside.
Step 4
Set your replacement toner cartridge over the empty space in the fax/copy machine. Ensure that the arrow near the bottom of the cartridge is facing down, and line up the protruding guide piece on the left side of the cartridge with the groove inside the machine. Push the toner downward until it snaps into position.
Step 5
Push the paper delivery tray back down, and lift up the extension piece if your model uses one.
May 06, 2015 | Office Equipment & Supplies
How do i replace the toner of a canon pc 1061?
When you get the new cartridge there are instructions on how to replace the old toner cartridge .
you open the the machine in the top half slide out the old toner and put the new one in make sure to pull out the plastic tab on the new cartridge it is like a long plastic sheet release the toner into the unit
Mar 06, 2011 | Canon PC1061 Copier
HOW TO REMOVE TONER CARTRIDGE TO REPLACE WITH NEW ONE
1. Grasp the front cover of the printer and pull it toward you to open the toner door. Reach into the printer and grab the combined toner cartridge/drum assembly. Lift up slightly and pull it out of the front of the printer.
2. Place the cartridge and drum on a paper towel, spare sheet of paper, rag or other surface that can get dirty. Loose toner particles may spill from the cartridge.
3. Press the blue locking lever on the cartridge/drum unit to unlock the toner cartridge from the drum. Lift the toner cartridge up and away from the drum unit. Dispose of the old toner cartridge in accordance with your local regulations. Seal it in a plastic bag to keep loose toner from spilling.
4. Gently shake your new toner cartridge back and forth a few times to distribute the toner evenly across the width of the cartridge. Remove the plastic protective cover from the bottom of the cartridge.
5. Place the new toner cartridge onto the drum unit and press it down gently until it locks into place. The blue locking lever will automatically click into place. Verify that the toner cartridge is securely connected to the drum.
6. Locate the corona wire cleaner tab at the front of the drum unit. Slide it back and forth several times to improve the print quality of the drum. Set the tab back in the home position when finished.
7. Slide the combined toner cartridge/drum unit back into the printer and close the front cover.
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Feb 09, 2011 | Brother HL-2040 Laser Printer
How to remove drum and ink
Open the front door, latch is in the middle on top front, swing the door down.
The toner cartridge sits inside the drum unit, you must take the all drum unit out before taking the toner cartridge out.
You can see the toner cartridge sitting right inside the printer (after opening the door), lift up the "basket" that the toner cartridge is sitting in and after you lift pull it out, and lay it on a table, make sure not to expose it to the sun. Unlatch the toner cartridge by pushing on the tab on both side of the toner cartridge and lift the toner cartridge out of the drum unit ("basket").
Dec 14, 2010 | Brother HL 2140 Laser Printer
How do i change the toner on m my HL 2040 brother printer
How to Change a Toner Cart in a Brother HL 2040
The Brother HL 2040 laser printer has a toner cartridge that supplies toner to the drum assembly so that the printer can print properly. When the LED on the front of the printer indicates you are low on toner, you will need to replace the toner cartridge to maintain good print quality. Fortunately, the toner cartridge can be replaced without any special tools.
Instructions
Things You'll Need:
* Replacement toner cartridge (part number TN350 or TN360)
* Paper towel or scrap paper
Hope it helps...
Dec 02, 2010 | Brother HL-2040 Laser Printer
Change toner cartridge , how do i
Open front cover, realese the blue toner handle, pull out toner unit, put toner crg. on top toner unit, so that arrow poits to copier. Press it and then will pop out tape wich you pull out, not to the end, when it does not go further it is OK, push back the plastic cover that got out, this will realese toner crg.Remove empty toner crg, push back toner unit and lift handle.
NOTE: when toner is empty machine guides you how to change toner on lcd display, you just need to look and press next.
Jun 30, 2010 | Canon imageRUNNER 2200
Problem is out of toner/change toner i change toner but not solve problem
Did you pull the plastic tab out of the new toner cartridge and shake it gently for 5 to 10 times before installing? Most toners have a tab( or some form of tape) that you have to pull out to release the toner.
Oct 27, 2009 | Canon iR 2016i Black and White Copier
Remove toner catridge from Brother 2170W
Open the front of the face. Pull out the catridge and drum assembly carefully. Thier should be a yellow tab on the toner catridge press down and the lift the toner catridge out. Replace and reseat in printer.
Jun 04, 2009 | Brother HL-2170W Laser Printer
Canon gp335
technically you add not change toner.
open front door, swing out big black unit, ( toner hopper)
place toner on top of unit with clear plastic piece of toner sticking out, pull plastic tab all the way. When pastic pieace comes off leave for a couple of seconds then push back the black cover of the hopper( came out when pulled plastic piece)
Jul 14, 2008 | Office Equipment & Supplies
I am using the workcentre 4150 and the printer keeps giving me an error saying. "toner supply failed, remove seal tape from toner cartridge and reinstall" I can't find any tape on toner...
The seal tape might be inside the cartridge, attached to a pull-tab.
I am only specifically familiar with the HP toner cartridges, which have a colored plastic pull-tab attached to the tape which seals the toner drum during transit. You have to pull on the tab which in turns yanks the sealing tape out after it.
Each HP cartridge has a small instruction sheet included which shows the location of the pull-tab. Perhaps your Xerox cartridge came with a similar diagram sheet?
Apr 03, 2008 | Office Equipment & Supplies
Konica Minolta magicolor 2430 DL Laser Printer Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
