Question about Hotpoint Washing Machines
I have a hotpoint wma66 the clothes softner doesn't drain away
    President:
  • 1,462 Answers
Check filter which is hidden away. disconnect electricity.take bottom panel off at back and you will see a large diameter hose going from bottom of machine to pump. undo this hose at the machine end and the filter is inside. pull out and clean
be warned - water will come out so make sure it doesn't go all over motor
Posted on Jul 06, 2008
Schaublorenz wa 5005
Try pulling out the soap / softener drawer completely from the Machine and thorough cleaning all the parts. The little siphon plastic pipes get blocked and cause this on my Hotpoint.
Aug 01, 2014 | Washing Machines
Control Module problem?
It sounds like the pump or drain hose is blocked by something, and if the water does not drain away it will not spin properly.
The last resort would be the control module which is about one hundred and fifteen pounds, so check everything else first.
Jun 13, 2014 | Hotpoint WMA66 Front Load Washer
Fabric softner not draining away on my hotpoint aquarius
take out your soap draw and in side there on the top you will see all black gunk that need cleaning i use a toilet brush with hot water ok
Oct 19, 2012 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint WMA66 Drum Bearings gone. Drum will not ...
Here are a series of free videos to help you with your bearing problems and how to fix them
For all your free videos on appliance repairs remember to mark us down and leave feed back please
For all your parts visit our site http://www.apart4u.co.uk
This first video shows you how to diagnose the problem
The next Hotpoint video is on how to take the drum out
This Hotpoint video will show you how to change the bearings in the drum tub
the last one will show you how to change the spider or drum support as they are known
May 20, 2010 | Hotpoint WMA66 Front Load Washer
Hotpoint WMA66 starts to fill but instead of beginning to agitate it begins to spin for a second or two and then drains!
Sounds like a tacho fault. Could be you have a broken wire on the motor circuit. Tilt the machine back and take a look underneath at the wires leading to the motor. This is just to give you an idea if it is a broken wire, you shouln't try to repair it like this, you would need to remove the front panel to allow yourself enough space to affect a repair. For a workshop manual on the WMA66 which would give additional help and advice on dismantling and rebuilding as well as fault finding click on the link.
Mar 17, 2010 | Hotpoint WMA66 Front Load Washer
Hotpoint Ultima WMA66. It goes thru the wash cycle but doesn't drain to go on to rinse/spin. It continues to turn and when the timer run's out it just stop's and is still full of water. Any ideas??
This must be a European model. If it wil not spin and water will not go out it has to be something stuck in the drain pump. You shoud have access through the bottom panel.If you have one remove it you should see drain pump.
Jul 24, 2008 | Washing Machines
Hotpoint ultima wma66
Sounds like the PCB is Freaking out. All you can do is Check all the connections between the Main board and Display board and if you still have the problem - then i'm afraid it is probably the Main Board gone Faulty.
Mar 14, 2008 | Washing Machines
Softner still in the draw
The detergent/softner dispenser is located above the detergent drawer. A water pipe is connected to it and water entrance and distribution to drawer's cells (following the programmed cycle)are done by a lever's movement (part of the dispenser). The lever movement is controlled by two solenoids that received their power from the timer. By opening upper machine's cover you will have an access to the dispenser. Disconnect the power cable from the machine before moving to next step !!!! Look first that they are not any disconnected wires. Move manually dispenser's lever and see if water running to all cells (depend on your movement). In case it doesn't work properly remove the unit from the machine and try to clean it (I hope it will help, otherwise you should replace the unit). In case it works properly (manually) - you should test with a multi-tester solenoid's resistance. the one that doesn't have a resistance measurement should be replaced. Good luck !!
Aug 03, 2007 | Hotpoint WF645 Front Load Washer
Washing Machines Logo
70 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
