Question about Dryers
I have a CTD40 Aquarius Dryer and an underwire from a bra has worked its way into the back of the drum through the dryer holes at the back of the drum. Is there an easy way into it to retrieve the item as I makes a grinding sound?
  • Friday2kuk Jul 07, 2008
    It did work, however I did have to take the back of the machine off to get to the offending article as it had wrapped itself around the spindle... No bother though, opened back there it was...
    Scholar:
  • 170 Answers
Take a pair of tweezers and a flashlight and turn the drum slowly around trying to see it and grab it with the tweezers to pull it out through one of the holes.
Posted on Jul 06, 2008
Electric Dryer Model DCSR473EVOWW has loud scraping sound when drum turning .... sounds like metal on metal
There is likely to be something stuck between the inner drum and the outer casing. In my experience this is most commonly the wire from an underwired bra! (belonging to my wife!)
If the inner drum has holes in it feel the surface carefully all over to try to detect a wire or other object protruding into the drum. If you find something it can often be pulled free with a pair of pliers or pincers.
Jan 04, 2011 | GE Dryers
Making too much noise; not motor
hi there it could be a few things, but what i would do is take the back off and look at the spindle if you manually rotate the drum and the spindle is twisting its that! or as simple as it sounds i had the same issue but it was a underwire from a bra that had gone through the holes in the drum and wrapped all the way around the spindle! it was a pain to get out but the dryer up and running perfect now!
let me know how u get on
vic x
Mar 03, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Machine very noisy when it spins. Missing bra
If you cannot here it catching, then leave well alone, if it is still catching, then you could to try to locate it by removing the lower rear cover of washer, remove the large black hose on bottom of drum, and see if you can locate it from the bottom of the drum.
Hope this helps.
Jan 16, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
DRYER IS MAKING NOISES
A common broblem with dryers and washers alike is the underwire out of womens bras coming out and getting through one of the holes in the drum wich makes a horrible racket. Open the door and use a flashlight to look inside to see if you can see the underwire in one of the holes. They also get stuck in the front seal where the drum rides around this is another good place to look.
Jan 04, 2010 | Dryers
Good morning. An underwire from my bra came out during drying and fell between the holes in the dryer drum. Now it makes an awful sound. SHould I take the back off the dryer to get to it?
You will normally need to lift the top of the dryer, usually by removing screws mounted from the underside of the door area. Unplug the dryer first. Most dryers have a spring type clips along each side of the lid within 3-6" from the front. A putty knife or flat screw driver will help you pop the lid but you must be careful not to crack the enamel finish while wedge up to pop the lid
Sep 08, 2009 | Dryers
Bra wire stuck in the drum
Are you from outside the United States? I tried running the model number in our system and it does not come up as submitted. In the GE/Hotpoint Look-up there are only three models listed...Without a good and verifiable model number, I cannot help further.....
Feb 14, 2009 | Hotpoint Aquarius WD63 Front Load...
Drum wont turn
sounds to me like the belt may have fallen off the back of the drum.
look under the lid and see. if a wd, should be simple enoughto put it back on by removing the back cover to refit.
turn the power off though.
Jan 29, 2009 | Hotpoint Aquarius WD63 Front Load...
I have a hotpoint aquarius 1100 washer dryer wd51 was making a grinding noise we turned it off and a under wire from a bra was sticking through a hole in the drum pulled it out and it is complete but now...
The bra wire bears no relation to your present problem.
Remove top cover, screws at rear, and push top cover back.
See if the belt is still on, if it is, then select final spin and see if the motor and drum go round, if it does not, then the brushes in the motor probably need replacing.
Unplug washer, and disconnect the motor. you will find the brushes at the motor plug end, depress plastic lugs, and slide brushes out, if they are less than 5mm long, then replace them
If it is the belt that has come off, you will have to remove the rear panel to refit it.
Plz rate my solution.
Thanks.
Underwire from a bra is stuck behind drum
You wouldn't believe how common that is. If you can see part of the underwire, unplug the machine first! Then, try to pull it out through the holes in the rear of the drum with needle nose pliers or vise grips. I can't stress enough the need to unplug the dryer first. On certain brands the heater is right behind the rear panel and depending on certain circumstances there could be 120-240 volts to the heater even though it is not hot and the underwire could either be shorted already or will short when you try to pull it out.
Dec 19, 2008 | Dryers
Lost a underwire from a bra
Bra underwires are one of the main engines of the appliance repair buisness.
You do need to keep a close eye out for it in the filter but it probably will do no good to call for repair. The repairman most likely will check the filter and tell you to call back if you have any trouble. Until it works it's way down there isn't much you can do without disassembling the washer.(no small feat for some of them) The only real damage that may occur is if it pokes a hole in the drain hose between the tub and pump. This has happened, but rarely. They will usually make their way to the pump and you will hear the noise, at which time you can usually remove it with no trouble.
Be sure to wash bras in a delicates bag on delicate cycle in the future.
Hope this helps.
Thanks/Mike
Nov 06, 2007 | Washing Machines
Dryers Logo
83 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
