Home A/C, Outside unit will not come on - Heating & Cooling
Have you checked the circuit breaker? If it has been working hard, the breaker may have tripped...remember that a/c can only really affect tempurature downwards by about 20 degrees- if your outside is 100 and you are trying to bring your inside down to 70, your a/c will be working all day long and something is eventually going to make it stop (like the circuit breaker overheating).
Posted on Jul 06, 2008
Need code to check messages from another outside phone?
did you look under the unit for a sticker with the code? Sometimes it is put on the unit.
Dec 28, 2011 | AT&T CL82409 Cordless Phone
Hi it sounds like LOTs of water running in the unit. I looked in and there is LOTS or water in the bottom of the unit Is this OK ??
Yes, the a/c unit removesmoisture from the air inside the home and allows it to drain to the outside of the unit, once there the water sits in the outside of the unit and the outside fan blade has a ring on it known as a slinger ring wwhich picks up and throws water on the outside coil cooling it to inprove cooling and efficiancy.
Jul 22, 2011 | Haier Heating & Cooling
I have a Honeywell RTH230 thermostat. Ive read the manual top to bottom and have set the temperature to 70 degrees and followed all the directions. But my home is still almost 85 degrees, and even hotter...
i am assuming the unit is coming on and all... there could be an issue with the refrigerant in the system such as a leak.. need to make sure the indoor fan is coming on and also that the outside unit is coming on..there are 2 copper lines at outside unit that are refrigerant lines the larger one should be cool and the small line should be warm.. there also should be hot air blowing out of the outside unit... if this is not happening you have a problem with either the freon has leaked or the compressor may not be coming on inside the outside unit \
Jul 20, 2011 | Honeywell Programmable Thermostat Heater
WATER LEAKING
Water should come out of the back of a wind unit when it is humid out, usually a drain hole. If water is leaking inside from a window unit, check that the outside drail hole is not clogged or maybe it is not tilted downward enough outside (Usually a very slight tilt down toward the outside to help the water drasin out the back outside). Also, if you have excess water forming, you may need to clean the coil. For central air units water should be drippng outside the home via a pipe or tubing and if the drain tube or pipe is clogged with scum that forms inside the pipe water will back up and overflow in the house near the heater/air conditioning unit. Also, some units have a pump to pump the water out and it may not be working.
Aug 07, 2010 | Heating & Cooling
Unit three years old. came home yesterday and
Check your circuit breaker for the outdoor unit,seperate from the furnace.
Sep 09, 2009 | Ruud Heating & Cooling
AC BLOWS WARM AIR
Cooling comes from what is done outside, if air handler is blowing and you are hearing a sound , may be in the duct work. If you feel warm air in cooling mode then the outside unit is the prob, need more info
Jul 25, 2009 | Heating & Cooling
Got home from vacation, the outside A/C unit
I wuld recommend calling a technician, however, it could be problems with the 2 wire control wire that leads to the outside unit, or the thermostat
Jul 11, 2009 | Frigidaire FSC23R5SBK Air Conditioner
Outside unit won't run
If the inside unit is running properly, there will be a yellow wire (or blue) from the thermostat down in the furnace that needs to be hooked up to the Y terminal also there is a red and white wire in the same place in the furnace coming from the outside unit, one goes to the Y terminal also and the other would go to the C terminal in the furnace. Otherwise you may have a bigger problem.
May 29, 2009 | Carrier 38BRC036 Air Conditioner
Non-working outside unit
If your unit is blowing heat inside and it's not a heat pump. It will be most likely electric heat in your case.
Sounds like you have a split unit meaning the condenser is outside and the cooling and the heat features are inside or under your home.If your Rudd is a heat-pump the outside unit will cycle/blow cold air outside in winter and hot air will cycle/blow outside during the summer season. Now, if for some reason the heat  is not coming on inside the house, would be the only reason that you would need to be concerned. Being a heat relay or breaker of could cause that problem. Hope this helps you, Sea Breeze
Oct 27, 2007 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
93 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
